IPMS19 Posted February 26, 2016 Share Posted February 26, 2016 -OK Romain and now ? What else ??? T 'en es ou ? Link to comment Share on other sites More sharing options...
rom1 Posted February 26, 2016 Author Share Posted February 26, 2016 I just glued the vertical fins Next week, I will get the corrected exhausts from my friend. I will be able to carry on with this build. Thanks for your interest 1 Link to comment Share on other sites More sharing options...
rom1 Posted March 12, 2016 Author Share Posted March 12, 2016 Hello Micro update with the work on the wings. You have to plug wing extensions. very curious that the contact do not follow a panel line.KH offers a very interesting crenel like fit. It will need some CA glue and putty: Moreover, the plug is thicker than the wing.Sanding needed... Then, we got heat shrink on the external surfaces: So... putty: And sanding: Cheers Romain 1 Link to comment Share on other sites More sharing options...
Hetzer123 Posted March 14, 2016 Share Posted March 14, 2016 Hello Romian, Russian aircrafts are not perfect. Why should this kit be ☺️ Good job 2 Link to comment Share on other sites More sharing options...
rom1 Posted April 16, 2016 Author Share Posted April 16, 2016 Hello Small update My friend raphael did an amazing job correcting the exhausts.He shortened the outer petals and detailed the inner ones. Outer petals: Inner Petals: Cutting of the support: You have to remove the plastic ring: I find the parts very convincing.Cant wait to paint them to reveal the details. I also filled the huge trenches at the fin bases: Cheers! Romain 6 Link to comment Share on other sites More sharing options...
James G Posted April 21, 2016 Share Posted April 21, 2016 Super work Rom! 1 Link to comment Share on other sites More sharing options...
valen1969 Posted April 21, 2016 Share Posted April 21, 2016 Fantastic job!!! 1 Link to comment Share on other sites More sharing options...
rom1 Posted October 25, 2016 Author Share Posted October 25, 2016 Hi ! I couldnt resist to buy the impressive barracuda's exhausts. It is truly impressive detailled resin parts. So, then I couldnt resit to chop of the parts from their blocks, and to do dry fit testing. Sadly, I had to remove the Afterburner ducts because it does not fit with Barracuda exhauts. It was tricky but I finaly managed to extract them. After some triming, I could have pu the resin on the Foxbat: I hope to be able to continue this build soon! Romain 3 Link to comment Share on other sites More sharing options...
SimonR2800 Posted October 25, 2016 Share Posted October 25, 2016 I can't wait to see this model completed. The Foxbat is definitely my favourite Russian military jet. Good luck with the rest of the build. Link to comment Share on other sites More sharing options...
Uncle Uncool Posted October 25, 2016 Share Posted October 25, 2016 Wow, Rom! Howdy? Say, whut's with 'em Barracuda ducts, mate? No way they will fit the Kitty Hawk kit? Strange! Or is it that ya fitted just the Barracuda exhausts to the kit's ducts instead? Nay likely. Cheers, Unc2 Link to comment Share on other sites More sharing options...
rom1 Posted November 3, 2016 Author Share Posted November 3, 2016 Hi! Uncle, the barracuda exhausts go to far in the rear fuselage. It hits against Kittyhawks AB ducts. I had to remove them with a little help of violence Cheers Romain Link to comment Share on other sites More sharing options...
Zippo the Zipdrive Posted November 3, 2016 Share Posted November 3, 2016 Fantastic work Romain. I didnt know there was so much work on the kittyhawk kit :,( But you seem like you are on top of things. GL HF \\Dan 1 Link to comment Share on other sites More sharing options...
girolamo69 Posted November 3, 2016 Share Posted November 3, 2016 fantastic job on the nose 1 Link to comment Share on other sites More sharing options...
rom1 Posted February 27, 2017 Author Share Posted February 27, 2017 Hello just a very tiny update... I filled some recessed panel lines with stretched sprue, in order to depicts actual raised weld lines: I also bought the nice MAster pitot: cheers! 1 Link to comment Share on other sites More sharing options...
rom1 Posted March 13, 2017 Author Share Posted March 13, 2017 Hello Some news again. Some scratch in the canopy: Then painted and weathered: I added som PE parts too: Romain 2 Link to comment Share on other sites More sharing options...
Jaffajake Posted March 13, 2017 Share Posted March 13, 2017 That's going to look the business once the primer is on! 1 Link to comment Share on other sites More sharing options...
rom1 Posted March 24, 2017 Author Share Posted March 24, 2017 Hello I sprayed Alclad grey primer on the whole aircraft. The coat was a bit rough so I sanded it smooth wit fine abrasive sponge. Seams reappeared at the wingtip junctions. I had to sand it again... Next, I sprayed Alclad gloss black primer on the future metallic areas. After primer is full dry, black coat is polished with Micromesh abrasives clothes. I used grades 6000 8000 and 12000: Surfaces are very smooth and shiny! Romain 3 Link to comment Share on other sites More sharing options...
David H Posted March 26, 2017 Share Posted March 26, 2017 Wow! Cool! -d- Link to comment Share on other sites More sharing options...
Ilan Posted March 26, 2017 Share Posted March 26, 2017 Very nice work! Link to comment Share on other sites More sharing options...
Biggles87 Posted March 26, 2017 Share Posted March 26, 2017 You're doing a fantastic job ' remanufacturing ' this kit. John Link to comment Share on other sites More sharing options...
Sid de Koning Posted March 26, 2017 Share Posted March 26, 2017 Very nice work but such a shame that it's necessary.. in this day and age that should not be happening.. Keep up the good work! Link to comment Share on other sites More sharing options...
rom1 Posted March 26, 2017 Author Share Posted March 26, 2017 Thanks guys! Yes Sid. This kit is screwed from pitot to exhausts. But, while being endless, extra work is rather interesting at the end... Cheers Link to comment Share on other sites More sharing options...
rom1 Posted March 29, 2017 Author Share Posted March 29, 2017 Hello Vallejo metal acrylics are sprayed on gloss black. An aluminium coat is first sprayed, then lines and surfaces are enhanced with a mix of alu+steel+bronze. cheers Romain 2 Link to comment Share on other sites More sharing options...
SallysDad Posted April 2, 2017 Share Posted April 2, 2017 This looks great. Link to comment Share on other sites More sharing options...
rom1 Posted June 3, 2017 Author Share Posted June 3, 2017 Hello Some news with big missiles. R-40 RD and TD resin missiles from Plus Model. They are very wharp and detailed. Good value for money.TS26 Tamiya Pure white is sprayed with the airbrush, then, white areas are masked. After masking, black is sprayed as a base for several sprays of acrylic Metal from Vallejo. Tutanium Blue oxydation is done using tamiya pastel. Decals from PLusModel: Black wash using Tamiya enamel product. KittyHawk pylons. Stencils are from Begemot stencils decal sheet nb 48011.A metal rod is inserted in a drilled hole, in order to give a stronger assembly: Final Assembly: Next is dealing with landing gears. Cheers Romain 4 Link to comment Share on other sites More sharing options...
