You made that look too easy Rob. Especially the part where you 'bent it to the correct shape using tweezers'. That step is suspiciously close to Stew's 'just paint the faces on' figure painting technique. It works great if you're Stew Dapple, but not so well for me!
Nicely done.
Well done with the brake lines, but can you see them now that the wheel is on?
John
Well of course John! If you pick it up turn it over face it away from you and angle it slightly... They are perfectly visible 😀
Cookie, it looks easy as it was surprisingly so!! I just had good chisel ended tweezers so it held the wire flat while a curved it with the point.... Does that make sense?? We will have to see if the others go the same!
Cheers stew, I am glad you liked the how too, there wasn't much howing in there really...
Ced, I hope so I can't put up a shelf for toffee so I may need to add them to all my models!😃
Cheers all its appreciated
Rob
Edited by rob85
Hi Rob, you mentioned using Micromesh on your paintwork a couple of pages ago, do you use it wet or dry?
When I was a regular brush painter many years ago I used toothpaste on a cloth for getting rid of buildups, it was quite messy and required a lot of cleaning up afterwards.
John
Toothpaste on a cloth makes sense, it's a fine abrasive.... Very cunning of you John!
I used the micromesh dry is this the correct way? Would making it wet not take all the paint off?? it's in long strips and grey, the grits I have are 3600, 4000, 6000 and 8000
Rob
Thanks, I have to admit that the toothpaste idea was not originally mine, I think It was one of Alan Hall's many innovations.
I think you're right about using it dry, it probably would take the paint off used wet. I'm off to try it now, if it doesn't work it's your fault, ha ha.
John
John
oh ummmm eeeerrrrrr..... I have only used it dry so couldn't say but using it wet with acrylic paint which can be thinned with water would mean it would get taken off quicker and then if not fully cleaned away would dry as a wash around the area.... Not that I have tried it! Dry it appears to polish well and the 8000 grit has worked well for me as a pre transfer prep. (Idea stolen from Joe aka fatboydim)
You could use it wet with enamels I guess.... But again not something I have tried.
Let me know how it goes 😄
Rob
Edited by rob85
Nice job on the brake lines Rob, they look good.
Just started using Micro Mesh myself, just for smoothing out filler and that stuff I made with melted sprue,
always wondered about using it on the paint before decals, must try your method,
Sean
Sean
Hey Sean, yeah give it a bash! It's not my method, I picked it up from a much better modeller, Joe/fatboydim! It's a great idea and if you use the fine stuff you will see the paint start to shine
Rob
Hi Rob. Hope you are well. Lovely progress again. The wheels with the break cables look great! Very nicely done. :goodjob:
Kind regards,
Stix
Edited by PlaStix
Chere's stix!
So a bit more progress over the last two days, first up was finishing off the Undercarriage for the GR-U and it's brake cables!
I found some of this in the good lady's art supplies...
F2122EEE-571E-4D1B-8484-B2D04D2C0961_zps
Which looked a much better idea than bending copper painting and glueing in place, this way just bend and glue
84911520-754D-488F-A644-D1A22B11CB1E_zps
Glued in place, same process used with the last ones to bend. I also added a wash to the above and the below
9AAD4C40-4AE0-4CF7-BC34-3F9F082B1BD6_zps
7E7E29EB-3915-481F-B21F-603B55AD7F60_zps
After that I got them both on their feet
32624050-3C90-4D7B-9E5E-C92FDF51E613_zps
Didn't get a pic of the other one!
After that I hit the transferring of the PR XIX hard! If you notice what has irritated me then you win a prize, it's not any of the silvering. ... and it was my fault.
73251960-1D0C-4B30-ABAA-6BA67586CCB3_zps
1D0D7538-A8C6-4850-B14A-A4DC358CD04E_zps
05FEBF30-3499-432C-8946-C785D70E0891_zps
Also the pic of the undersides hs James on as that is my nephews name and had a poor finish as it was taken with a wet satin coat on.
So to relax after that, oh I also didn't use any solution for the transfers I used hot water and Simon shout of nearly boiling water and cotton wool to press them down, worked a treat.... anyway after that I did the painted on camo coat, two coats and done
2DB0149B-7295-42F3-AF86-324B286F7D20_zps
So how did I get two different shades of brown again from the same pot? Never mind. A good micromesh and then get the transfers on.
Cheers chaps
Rob
Port side wing roundel? And black walkway lines ... I hate those kind of decals :badmood: , that's why I paint them on. But I guess you should have probably put them on first, then the roundels
Great progress, nonetheless :clap: Wheel wells look great, and so does the newly supplied brake line material :thumbsup:
Ciao
Yes well done you win pride, pride in the fact you have keen eyes and quick fingers...
I was sooooo pleased with how the roundles and walk ways had gone! (Giemme I too HATE walkway transfers and may steal yours or cookies ideas to paint them! ) I gave it a coat of satin to protect it, should have left it to dry longer! When I did the JAMES transfers across the lower wing my finger pulled the roundle and walkway off.... Lots of bad words and delicate work to get that mistake to what you see above.... Bigger
Rob
Thumbs... always getting in the way. First place I look when I lose decals...sorry ... transfers.
Nice touch putting James' name on
Sean
Stix I agree it's the only bit of the spitfire I dislike, it's walkway markings. They would have been fine however if it was not for me.... It's not really the fault of the transfer.... Even if they are stupid
Sean, cheers mate, I have done three models now for my last three nephews swordfish for Hugo, Hamden for Redford and now a spitfire for James (yes all name are real and not made up to sound posh...which, lets be clear, I am not). It is a blatant attempt at trying to get them into modelling and aircraft early! A tried and tested method that my grandad and uncle were firm believers in... Like collecting all the take of mags so I could build the gulf war tornado (I still have the mags and wish I had the kit and decals now! ) or buying me an 'extra gift' at xmas or birthdays which was always a ww ii aircraft...the last tactic which I feel is the most potent, take them to a really good model shop, the best are ones will shelf after shelf of kits stacked to the ceiling (most of you can go look at your stash to get the idea) as say 'pick what you want....just don't bring it to me if it hasn't got wings'....
Cookie, I remember you saying about the walk ways on after roundles... Was that the 92 Sqn I/ii b?? You saved it to make an outstanding model if memory serves...I wish to replicate this with mine! Lol!
Cheers for the comments and if you have stuck with this post long enough to get to here 👏🏼
Rob
Nice idea for getting the younger ones interested Rob. Of course you could get them some kits and if
they're not really interested you'll get to make them anyway.... result :thumbsup:
Sean
