That sucks.
I have used the AFV Club set on that kit. Looks good and they fit!
G
Cheers G,
Had these in the stash for a while just didn't like the ejector pins and the way that they are put together tbh.. Going to use them now
and they fit perfect :)
I was just being lazy in not using them and I was a bit worried about how robust they were.
I feel a Sunday track bash is in order
Dan
Bummer about the Bronco tracks mate. On the other hand the AFV Club ones look the part.
I had thought about trying the Bronco ones, but might save up and get frills instead.
Al
Thats better mate,
A quick question...do you need to glue all the end connectors or just push them on to join the track links together?
Never used aftermarket kit before, just curious...
Nick
A word of caution with using those AFV Club tracks. The vinyl end connectors will SPLIT if you use thinners/ white spirit etc for washes and weathering and the tracks will fall apart. I found this out the hard way on my M728 CEV conversion a few years ago and since then I only use IPA when weathering the tracks with pigments.
Hope this helps!
Cheers Chaps,
I've done the other side now so chuffed. As for the fit the end connectors are just a push fit,
they do feel quite robust and that they shouldn't fall apart just by looking at them.
As for the painting and weathering I'll treat these the same as the Bronco tracks, any spirt based products really trash the plastic
and they do fall apart.
Cheers for the pointers and advice chaps :)
Dan
Looks like you're back on track Dan
Interested to see how you handle the MERDC camouflage scheme.
Cheers Chaps,
I'm hoping this will help with the cam scheme, been waiting to use this since November. :)
Dan
Looks good Dan-o :) Are the figures just roughly put together to get a feel for their pose? Is that filler or Blutak on their shoulders? :hmmm:
Cheers Mike,
It's just Bluetak at this point just to get the pose right and they are still pretty dynamic at this stage, playing with swapping out arms and
possibly sculpting some new ones.
Dan
Cheers Mike,It's just Bluetak at this point just to get the pose right and they are still pretty dynamic at this stage, playing with swapping out arms andpossibly sculpting some new ones.CheersDan
Could you turn the commander's head to the left so he is looking at the loader/tea maker: from the position of his right arm and hand it looks like he has just tapped on the side of the turret to attract his attention?
As suggested by Richard...
Glued the arms on and cleaned up all the seams on the parts. Using again my favourite epoxy putty, Green Stuff to blend in the new limbs.
Commander will get the treatment next
Dan
Cheers Chaps/
A bit more progress for you.
More work done on the figures
Cast effect redone on the front decks.
Jerry cans added
More work done on the rear
Cheers for looking
Dan
