Dads203 Posted December 15, 2015 Author Share Posted December 15, 2015 Cheers Guys, Still working on it Foxy, just slowly mate So I made the safety rail ( interrupter )that stops the commander shooting off the IR searchlight with the .50 This was a whole heap of fun to solder up and make, this was the easy bit as I have to make the base for it now. The kit part, not bad but not right. This is just the upper part. Also Added the smoke grenade stowage boxes to the turret sides. And one of front mud guards More later folks Dan 4 Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2015 Author Share Posted December 15, 2015 Lower bracket added, just the ironwork to hold the guard needs adding. And the gunners telescope sight , just to left of the main gun. Cheers Dan 6 Link to comment Share on other sites More sharing options...
mixup_1 Posted December 16, 2015 Share Posted December 16, 2015 Keep going...Im hooked! Link to comment Share on other sites More sharing options...
Dads203 Posted December 18, 2015 Author Share Posted December 18, 2015 Keep going...Im hooked! Cheers fella So I've decided to model a M60 on exercise, this means the Hoffmann device fitting to the fume extractor, A M85 BFA Barrel on the commanders cupola and a few other temp mods. I've bodged the BFA Barrel for the .50 cal using the Browning .50 that comes with the Academy M113, you get two guns, one with a BFA and one without. The support rods are the .3 black carbon antennas from Accurate Armour and the barrel was modified to fit the kit perforated barrel cooling jacket. The black carbon rods need trimming yet but once the glue has dried. Fender supports are being done and soldered when I can. And the headlights have been detailed up and fitted. More later folks Dan 6 Link to comment Share on other sites More sharing options...
Mike Posted December 18, 2015 Share Posted December 18, 2015 Nice work Mr Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 18, 2015 Author Share Posted December 18, 2015 Cheers Mike. Hoffman device added to the fume extractor, all this is a main gun simulator. Cheers Dan 7 Link to comment Share on other sites More sharing options...
Ascoteer Posted December 18, 2015 Share Posted December 18, 2015 Now that's looking very nice. That short main gun barrel, is that for the Shillelagh ATGW? Link to comment Share on other sites More sharing options...
Dads203 Posted December 18, 2015 Author Share Posted December 18, 2015 Now that's looking very nice. That short main gun barrel, is that for the Shillelagh ATGW? Thanks Debs, The M60A2 starship was the tank that used the Shillelagh launcher, saw very limited service and didn't really go into full production. I've left the end of the 105mm barrel off so my build does look like a A2, its just to aid adding the Hoffman device and other small bits. Regards Dan Link to comment Share on other sites More sharing options...
adt70hk Posted December 19, 2015 Share Posted December 19, 2015 This really is an amazing job!! Link to comment Share on other sites More sharing options...
PlaStix Posted December 21, 2015 Share Posted December 21, 2015 Hi Dan. I need to ask you a question - are you quite sure this is a 1/35 kit? I'm pretty sure, looking at the detailing you are doing, that it's probably 1/16 or bigger. There must have been a mix up when the kit was packed in the box. Phenomenal modelling. I'm attempting my first proper 1/35 kit, as you know, over in the Vietnam GB section and I couldn't even contemplate being able to add some of the stuff you are doing. Brilliant!! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Dads203 Posted December 22, 2015 Author Share Posted December 22, 2015 Cheers Stix, I wish this was 1/16th So the fender supports, complicated little beggars, loads of PE and resin parts the small resin nuts are a real pain. Only two more to do now. Cheers for looking Dan 3 Link to comment Share on other sites More sharing options...
Dads203 Posted December 23, 2015 Author Share Posted December 23, 2015 Another small update, had an hour today at the bench so not much done, All the fender supports are complete now. I've worked on the antenna base or one of them, and it took a couple of attempts to get it looking right. Made from micro steel tubing, ally foil and lead wire. The US military tend to tie back the whips are they are long, low power lines and radios do not really mix so well and can give you a really bad day so I wanted to do this with my build, getting the bend in the spring was fun. First attempt... And the second final version. Please enjoy Dan 6 Link to comment Share on other sites More sharing options...
Mike Posted December 23, 2015 Share Posted December 23, 2015 Third time lucky Link to comment Share on other sites More sharing options...
Dads203 Posted December 23, 2015 Author Share Posted December 23, 2015 Added the crew heater exhaust and the mounting brackets. Also made the eye protector for the tip of the whip antenna. Cheers All Dan 4 Link to comment Share on other sites More sharing options...
PlaStix Posted December 23, 2015 Share Posted December 23, 2015 I seriously have no clue how you have the patience to do the amazingly detailed modelling that you do! 2 Link to comment Share on other sites More sharing options...
Widow 65 Posted December 23, 2015 Share Posted December 23, 2015 Yet again another masterpiece in the making Dan. Merry Christmas. Nick 1 Link to comment Share on other sites More sharing options...
adt70hk Posted December 23, 2015 Share Posted December 23, 2015 Dan This really is a stunning job already - and you're still a long way from being finished!! Have you thought about leaving it unpainted, so people can see the amount of work you've put in - and I mean it!! That level of skill deserves to seen!! Brilliant, simply brilliant!!!! Merry Chritmas Andrew 1 Link to comment Share on other sites More sharing options...
Hamden Posted December 25, 2015 Share Posted December 25, 2015 MERRY CHRISTMAS to you M60 looks more and more lifelike with each update! Roger Link to comment Share on other sites More sharing options...
Dads203 Posted December 27, 2015 Author Share Posted December 27, 2015 Thank you guys, hope you all had a good Xmas So a small update today. Been working on the smoke grenade launcher brackets, soldered up and one fitted with the welds added, I have to make the armoured cable housing for both yet and fit the launchers. Also started on the lower hull, filling the damper mounting holes to start, then adding the correct shape bump stops to the hull and each axle. Regards Dan 3 Link to comment Share on other sites More sharing options...
DogTeeth Posted December 27, 2015 Share Posted December 27, 2015 Another...raise the bar build from dads. Absolute joy to follow. Thank you for posting. 1 Link to comment Share on other sites More sharing options...
Engineer66 Posted December 27, 2015 Share Posted December 27, 2015 Hi Dan, cracking work as usual... Is this any good for the armoured cable to the smoke launchers? http://www.hiroboy.com/120124_Flexible_Metal_Mesh_Hose_Braided_Hose_Style_10mm__P968--product--3749.html Their site is worth checking out for other useful bits and pieces. Cheers Al 1 Link to comment Share on other sites More sharing options...
Dads203 Posted December 29, 2015 Author Share Posted December 29, 2015 Hi Dan, cracking work as usual... Is this any good for the armoured cable to the smoke launchers? http://www.hiroboy.com/120124_Flexible_Metal_Mesh_Hose_Braided_Hose_Style_10mm__P968--product--3749.html Their site is worth checking out for other useful bits and pieces. Cheers Al Cheers Al, I did look at the braided cables and I think they might be a bit on the thick side, Going to use some .4 lead wire for the leads and roll them softly with a flat file, that should give the impression that They are armoured cables. Regards Dan Link to comment Share on other sites More sharing options...
Dads203 Posted January 4, 2016 Author Share Posted January 4, 2016 Small update, Not had much time to get stuck in with this lately so another small update. Suspension work mainly, adding the missing bump stops, not gong to mad on this one as the underside of the Tamiya kit is not accurate at all, I could put it right but I really cant be bothered with the extra work required. Also the plastic is really brittle now, I've cracked the lower hull a few times just removing soft detail and reworking the suspension might end up in destroying it. turret tie downs added. clean up of the resin roadwheels , you can see the kit part with the floating hub Enjoy Dan 6 Link to comment Share on other sites More sharing options...
The_Lancaster Posted January 4, 2016 Share Posted January 4, 2016 Very impressive work there! The Resin road wheels are definately an improvement when it comes to the hub! 1 Link to comment Share on other sites More sharing options...
longshanks Posted January 4, 2016 Share Posted January 4, 2016 Think its probably a smart move to step back from any potential plastic explosions. Kev 1 Link to comment Share on other sites More sharing options...
