Very nice detail. When will we be painting this? :wicked:
It's going to be while, still a ton of PE yet to add and resin, Indi track links and I've got too correct the running gear and suspension.
The Tamiya stock suspension sits a few mm too high so I suspect that they measured up just an empty hull with no inner components.
Don't want too put a time frame on it just yet :)
Dan
Small update, front PE headlight guards
are now soldered up, quite fiddly to get these lined up as
they have some gentle curves, still i'm quite chuffed on how they came out.
Nuts and bolts with a rear support to be added yet.
Dan
Utterly, utterly superb attention to detail! :hypnotised:
Great work as always Dan nice and clean finish, mine seems to be messy:(
Darren
You haven't seen him with his pinnie & feather duster before every photo-shoot. No clothes, just the pinnie :puke:
Nice work on those swoopy cages & the tiny bolts mate :)
Thank you chaps, build is still going on slowly, and the lack of updates is down to
An outage with BT infinity, looks like a burst water main has knocked out part of the fibre network
For most of the day, no internet access until now.
I've done the other light guard and support bracket now and now I'm working on the headlights with a view
Of replacing the lens with MV items.
Pictures later
Dan
I do wonder how a water main manages to burst when it's not even cold. :hmmm: Hydraulic erosion? :shrug:
We had no water first thing this morning and upon checking the Internet found that it was down also, rumour has it that the water board
Dug through the fibre trying to fix the water main. So an eventful day all in all.
Dan
That sounds about right. Did you have the passing-of-the-buck that usually happens with internet problems? It's surprising how quickly that sort of thing gobbles up your day, talking to :wall: after :wall::boom:
Both headlight guards are now done and in place.
New travel lock bracket added for the new travel lock.
More to follow later.
Dan
Those headlight guards are a work of art on their own! :goodjob:
How far away from the paint booth (back door) are we? :)
2/3 weeks I reckon, I've just sprayed the interior of the drivers compartment black :)
loads to do on the running gear yet like correcting the bump stops and rebuilding the shock absorbers, not too mention the
putting the fruil tracks together.
Dan
Dan
So you have not set yourself to much to do then :evil_laugh:
Lights and guards look good
Roger
