BrianI Posted November 4, 2015 Share Posted November 4, 2015 At the moment I use a pin vice for drilling small holes up to 2mm.I've also got a challenge extreme dremel clone, but the slowest speed it does is 8000rpmI do have a Bosch IXO electric screwdriver which takes standard 1/4" hex bits. If I could get something which would allow me to fit drill bits / etc, this would be ideal for slow speed drilling / cutting / polishingNow google suggests you can get keyless chucks which fit drill sizes up to 7mm, which have a standard 1/4" hex fitting e.g: Has anyone tried one? Is it worth while? I don't really need a full size 18V battery driver / drill. 1 Link to comment Share on other sites More sharing options...
BrianI Posted November 4, 2015 Author Share Posted November 4, 2015 Well, just took a punt on one from ebay, for £3.99 inc p&p. Link to comment Share on other sites More sharing options...
BritJet Posted November 4, 2015 Share Posted November 4, 2015 I've got one like that and it does the job nicely. Only thing to watch out for is the flywheel effect of the chuck as it keeps spinning longer than normal after you turn the power off! Steve Link to comment Share on other sites More sharing options...
S5 modeller Posted November 6, 2015 Share Posted November 6, 2015 The only problems I forsee could be run out, due to cheap production and large tolerances on the components, and chucking size, might not close up enough to hold small diameter drills. I've tried using my multi tool for small drills, but the jaws on the chuck have large chamfers on them, and when fully closed the resulting gap in the jaws is too large to hold micro drills. Just my two penneths worth. Matt Link to comment Share on other sites More sharing options...
BrianI Posted November 7, 2015 Author Share Posted November 7, 2015 Got the chuck in the post today. It is a bit wibbly wobbly. The 1/4" hex shank is a bit loose on the bosch ixo screwdriver head. Also a bit slow and torquey for using as a drill However I have fitted a 5mm drill bit into it, and successfully managed to enlarge the central hole in one of the wheel hubs for my 1:12 airfix blower bentley build. This has allowed me to insert a 5mm diameter alloy tube, which should make relacing the spokes a little easier. But that's a topic for another thread! I'm just planning on using this hex chuck for drilling holes in the 2 - 5mm range, anything smaller I'll use pin vice with appropriate mini drill bit. Can't complain for a fiver though! Link to comment Share on other sites More sharing options...
S5 modeller Posted November 9, 2015 Share Posted November 9, 2015 At the end of the day, you get what you pay for. Perhapse using a sliver of plasticard superglued to each of the six flats might make it a tighter fit in your hex shank. Link to comment Share on other sites More sharing options...
BrianI Posted December 5, 2015 Author Share Posted December 5, 2015 I might try that. Haven't really used the drill in anger though s5modeller! Still at least it was cheap Link to comment Share on other sites More sharing options...
