Skyhunter66
Airfix 1:72 Nimrod - any good?
I've been thinking about doing this kit for a while but I don't think it gets a good press. I wondered what people thought of it and what the main issues with the kit are?
thanks
Chris
Well, it's not like there are a lot of other options if you want a 1/72 Nimrod (or in any other scale for that matter). The kit appears to have been tooled by Trumpeter and fit is quite good and the surface detail is appropriately petite. There are some issues with the intakes so you would be advised to try to track down the Alley Cat intake set:
http://www.hyperscale.com/2009/reviews/accessories/ac72006creviewbg_1.htm
There are also a number of Eduard photo-etch sets for the exterior and interior:
http://www.eduard.com/store/Eduard/BAe-Nimrod-1-72.html
Intakes, nose light and landing lights all need adjusting for accuracy. As said above, have a look at the Alley Cat sets.
The kit decals are pants. They go on really badly, or they did on the one I built. Get some aftermarket decals.
thanks
Mike
There is a replacement resin weapons bay as well, I would recommend getting this if you plan on displaying it open as the kit one is a bit sparse.
Rich
thanks
Mike
I forgot how bad the decals were in this kit. This was before Airfix started using Cartograf to print their decals. There are alternate markings and stencils on several sheets available at Hannants:
https://www.hannants.co.uk/search/index.php?adv=1&product_category_id=&product_division_id=&manufacturer_id=&product_type_id=&code=&scale_id=956&keyword_search=nimrod&setPerPage=25&sort=0&search_direction=0&save_search_name=&save_search=
Blast! I wanted to do the CORPORATE option in the kit, don't think there's aftermarket for it.
One note on the Alley Cat engine sections: for my money, the intakes are worse than the kit's. They're too like a Comet's in shape. The Nimrod had odd intakes that I can only describe as the shape of a squished TV screen (the old type before we all got flat screens). The kit's aren't ideal either, but they're closer, so when it comes to it I shall be grafting them onto the front of the Alley Cat bits, which are otherwise top-hole.
A replacement windscreen is a good idea too - improves on the shapes of the glazing and sorts out the slightly dodgy reinforcement plates. DMold went mad and did a set for the entire front end.
Replacement decals: the main player is Model Alliance, who did markings and stencilling separately. There's also Xtradecal. All plentiful at the Big Yellow Model Shop.
May I suggest you avoid the hemp and all-grey schemes, on account of they're 'orrid?
A couple of pics wot I took at Bruntingthorpe showing the Nimrod and Comet intakes..... for your modelling pleasure.
Hope these help.....
Ken
I made one for a friend who is an instructor at Cosford and actually worked on the aircraft during Operation Corporate. He wasn't particularly bothered about the inaccuracies of the kit, I don't think he noticed but he was absolutely made up when I took it to him. He offered advice on what options he wanted, flaps down, bay open, what ordnance to fit. He did recount tales of one of the maintenance staff cutting a main wiring loom too short and re-routing it to make it fit. I did a little modification using wire and string to simulate pipes and cables. A pilot friend of his who actually flew them was equally enthusiastic about the model. So, endorsement from the men who know the aircraft from the inside out is good enough for me. I still have one being prepped for construction for my own display. I know it's not perfect but now I've made one it should help me to do a better job.
http://s980.photobucket.com/user/eoslensman/slideshow/Airfix%20Nimrod?sort=3
Also technically you can't really do the dropped flap version as the kit only deals with the wing flaps and forgets about the split flaps under the engines.
Ex Nimrod rigger.
I've made one nimrod and have another waiting in the wings. I would recommend using the Alleycat replacement canopy, as the kits
cockpit windows just look wrong; the set also includes paint masks and some photo-etch windscreen wipers. I didn't bother with the resin
intakes, instead I just sanded them to a more square shape. The Eduard exterior photo-etch set adds a nice bot to of detail and as others have said you'll definately be needing a new decal sheet.
Hopes this helps, gazza l
Totally agree, In fact I would say if you can only afford one after market for this kit, the canopy is essential. The Airfix rendition really spoils the look of the finished model.
Ken
thanks Ken and yes these are really helpful. I live not far from Elvington so this is a good excuse to go down there for some research!
chris
Ok this is good stuff so thanks everyone.
So key points are replace or modify the intakes but definitely replace the canopy and decals. And it looks like Martin @ RAM has got the latter covered for me!
So I will get these items and then search around for a decently priced kit
thanks
chris
I got one off e-bay from a shop for 35quid a couple of weeks ago, Seems cheap compared to a cheaper example from US or Canada when you take into account P&P, if you are in the UK :
http://www.ebay.co.uk/itm/Airfix-1-72-Aircraft-Military-New-Plastic-Model-Kit-1-72-/171961029454?var=&hash=item2809ad134e:m:mCqUXIW52CmjAnDP5sk1hvA
He's still got 2 left.
cheers - in fact i got one from Kingkit the other day for £29 and it just arrived! Lovely big kit isn't it!
Superb - thanks for sharing
Thanks, guys, I have the Nimrod; have read of some of the problems. Wasn't aware of the decal problems; but, thanks for the info on after-market(knew about Xtradecals Nimrod sheets) ones. Especially the stencil sheets! I have checked out the Alley Cat parts; will get them in the near future.
Hi all, I realise this is an old topic in your discussion here but I am currently building an MR2 and are baffled as to what, where to and why is item 29D ? There doesn’t seem to be any positioning marks nor cut outs. If any one can remember it would be much appreciated.
Thanks. Gary
Thanks. Gary
Hmm, looks a bit weird, I wonder if it’s meant to go on the underside?
Edited by Dave Fleming
There is a slot in the rear port fuselage just before and below the port tailplane. It might go there. Mine has an empty slot as I missed that bit out for some reason.
Thanks guys, I’ve located the slot but what orientation it goes is anyone’s guess. Especially as the part isn’t square one end and the curvature doesn’t seem match. Oh well worse comes to worse I will have to fill.
Thanks again.
29D is the backing for the SCP exhaust on the port side of the lower rear fuselage and mine was a horror to fit too.  IIRC Airfix have the slot in the wrong place and the associated intake is undersized.  Fortunately Alley Cat come to the rescue with an appropriately-sized intake.  If you’re doing an MR. 1 it’s redundant as the SCP wasn’t installed and the exhaust slot didn’t exist, nor did the intake just ahead of the port tailplane root.
