Academy 1 48 Messerschmitt Bf109 G6 - Completed!
giemme
Hi Giemme. That paintwork is looking great. The pre-shading is showing through very nicely. How are you thinking of doing the mottling?
Kind regards,
Stix
Cameo looks good
Rick
Cheers Rick, thanks! :thumbsup:
Thanks Stix! :thumbsup2: As for the mottling, I'm not sure yet: I'm going to try freehand on an old kit, but I'm also considering a cardboard template. Maybe I'll end up with a mix of the two
Ah, German Measles Giemme, looking forward to seeing how this turns out.
Splendid work so far mate :thumbsup::thumbsup::thumbsup:
Simon.
Cheers Simon, thanks! :thumbsup2: I'm looking forward to it too, but I'll have to wait till tomorrow before I get back to this
Looks great G. You going to do the mottle free hand or use a template? Being a brush painter myself, the mottle proves elusive to me :banghead: so good luck with the next stage.
Thanks Greg! :thumbsup: See above for the mottling, I'll probably use a combination of the two, but I'm going first to try it on an old model, anyway.
Ciao
Hi Giemme. With regards mottling - before I say anything else I need to state I have never done any - but I was wondering if it may work using stippling brushes and very thinned paint? When I was building the German tanks I thought at the time when I was applying the camo colours, using stippling brushes, that, to start with, it did look like mottled camo on planes. I thought even back then that if I were to build some WW2 German aircraft, I would have a way of doing the mottled camo. If you built it up thinly getting more layers towards the centre it may create the right impression. I know some have done it with airbrushes but that's not an option open to me. Anyway.....just a thought. Whatever way you chose to do it make sure you practice lots on something you're not worried about ruining!
Kind regards,
Stix
Thanks Stix, that could be an option too! :thumbsup2:
... Whatever way you chose to do it make sure you practice lots on something you're not worried about ruining!
No worries, there's an old 1/48 F-16 awaiting to be tortured ... :whip:
Ciao
Nice work so far Giemme, airbrushing the mottle isn't as bad as it seems, just need a good paint mix and a gentle trigger finger on the airbrush. My G-6 and FW 190 are both on the RFI pages and both are mottled. :winkgrin:
Thanks Julian :thumbsup: Both your G-6 and FW190 are looking great :clap: ; my only doubt about airbrushing freehand the mottling is the scale effect. In 1/32 the soft edges you get look absolutely right, I want to see the effect on 1/48 though, hence my experimenting. The idea of spraying through a template is of somewhat being able to regulate those soft edges by keeping the template closer or at a distance from the model.
Anyway, tonight I should be able to do some testing, first of which will be freehand airbrushing; if it turns out half as good as yours, I'd be more than happy!!
Thanks again for commenting
Ciao
Hi everybody; mottling, what a delight .... :hobbyhorse: I did a few test last night, and decided that using a template was not the way to go. I went for freehand airbrushing, instead, although I felt like Spiderman casting his webs, sometimes :banghead:
Before that: here's a pic with a quick dryfit of the propeller/spinner assembly in place
Back to mottling: here's my tortured and vexed F16
I started with RLM75
sprayed at a very low pressure (around 0.3, 0.4 bar), very thinned mix (IPA and Tamiya Flow Retarder), very easy on the trigger - although as I said I lost control a couple of times and had some annoying spider webs running around.
Then it was time for RLM74
Here I had a lot of trouble: I couldn't find a correct combination of thinning/air pressure (going from almost 0 up to 2 bar !!), I kept having paint running around (on the F16, of course). So I eventually tried thinning the base color (which was already quite a diluted mix) with cellulose thinner: that way I got a better flow control (but also got some occasional solid paint spitting :badmood: )
So I had to get around those mottles with some RLM76 to overpaint some of the webs
That wasn't enough, so there was also some stippling brush involved (thanks again Stix for the tip :thumbsup:) but forgot to take photo of that.
So, what do you guys think? BTW, the kind of mottling I tried to reproduce is shown (sort of) here (photo posted only for modelling discussion purposes, will remove if asked for):
Ciao
Giemme, nice work mate.
Looking at the reference pic you added, you are on the right track.
A lot of those measles are darker in the pic so I would not worry too much.
Remember that these schemes were painted in the field.
Simon.
Thanks Simon! :thumbsup:
I'm not too worried about colors; it's hard to tell from a pic like that, not only because is B/W, but it's also taken in full sunlight and the definition isn't the best.
Anyway now he pan is to paint on the crosses and probably the numbers and the yellow tail band; after that I'll see if I want to add a few more measles (I like that word, really gives you the idea of what it looks like :D )
Ciao
Edited by giemme
Hi Giemme. For your first attempt at mottling I'd say that has turned out remarkably well - not that I ever doubted it wouldn't!! It all seems to tie in well with the rest of the paintwork. :thumbsup:
I do feel sorry for the F-16 though!
Kind regards,
Stix
Thanks Stix, I'm glad you like it! :thumbsup:
I don't. It's a very old attempt at modelling, with lots of issues and and awful paint job. But serves very well as a test bench :winkgrin:
I like it Giemme, that looks good. The "mottle" takes quite a lot of effort to get a good result, probably the reason i haven't managed it :winkgrin:
Cheers Greg, thanks :thumbsup2: Mottling does take a lot of effort, I was literally sweating while airbrushing it, despite being in my garage at 16°C!! :jump_fire:
Ciao
Hi everybody: lots of photos for this WE report, although I feel like it was more of a setback rather than a progress ... :banghead:
Anyway, back to where I left it: here's a couple of pics after tidying up the mottling, plus some paint chipping on the wing leading edges and a thin Future coat:
So, I decided to cut my own masks for insignias and numbers, here's a quick sequence of how I do that; using Tamiya Masking Sheet (never learn from my mistakes ... but later for that :banghead: )
Next pic shows how I handle the mask prior to applying it to the model; this way it doesn't curl nor stick to itself
For this wavy pattern, I tried printing straight on the masking sheet, but the ink would come easily off, so I actually photocopied the decal sheet on regular paper, stuck a cut out of Tamiya sheet on top of the selected area and upon removal, got the pattern on it:
So after cutting with an Exacto knife (should have used a sharper blade, again never learning from my mistakes :badmood: ), I placed the masks on the model
I then airbrushed a coat of off-white (Tamiya Flat White with a bit of Sky Grey) all over the masked areas; the crosses were then given a pure Flat White coat, while numbers and wavy patterns received a Flat Yellow one.
A this point, I thought it was a good idea to reproduce the black outlining of the yellow parts using a fine tipped marker:
Then I masked the under-wing crosses to spray the black internal ones:
What could possibly go wrong? :evil_laugh: Long list, I'm afraid .... let's see the pics first:
Black outlining sounded like a good idea ... not when one manages to put a finger on top of it to hold the kit for marking the opposite side ... ink spread all over the yellow, respraying and all of that ... definitely messy! :badmood:
Plus the yellow paint leaked a bit underneath the masks, while the black ink just followed their edge :banghead::banghead:
But here's even worse:
Basically Tamiya Masking Sheet is much thinner than regular Tamiya tape, and gets very wet when spraying a thinned paint mix (I don't like to spray thick paint when painting with masks, as you risk to get annoying edges along the borders). As it gets wet, it also starts lifting up, thus allowing the paint to leak underneath (forgot to mention that I had sprayed a Future coat on all the masks to seal them, before starting the actual painting - to no avail, as you can see).
I had the same problem in my recent Spitfire build, hence why I said I never learn from my mistakes ...
Bottom crosses, on the other hand, turned out not that bad:
On with the touch-ups:
I'm confident (but I should rather say: I hope) that after weathering and the clear coats, all those touch-ups will tie in properly ... fingers crossed!
Next pic is there just because I liked the pose:
Last bit of painting: the yellow band. I masked the wavy things using the cutouts coming from their masks:
This is needing some touch-ups too, but I'll do all the yellow parts in one time - just not now, I need to distract from this a bit
I might just as well decide to overlap the kit decals to the waves ...
Next post shows some work I did on the canopy
Ciao
Edited by giemme
Canopy: I wanted to add some "structure", also to be able to properly fit in place the armored back plate, so I copied the canopy profiles with Tamiya tape and used them to cut some appropriate bits from the usual beer can:
Glued in place with tiny CA drops. I also added a small ring made out of copper wire, as an attaching point for the holding rope/cable that connects the opening canopy to the fixed one:
Canopy and back plate received a coat of Tamiya German Grey - masking the canopy wasn't that easy, as the framing is molded on the inner side :chair::fight:
Comments welcome, as ever
Ciao
Oh well Giemme, the trials and tribulations of masking and making ones own masks.....
It is something we try and master, some of us successfully , some of not ( I include me in the latter statement )
At the end of it, we see our mistakes and scream bad language but also learn too.
After all that, she is coming along nicely, the canopy work looked fun.
:goodjob::goodjob::goodjob:
Simon.
Hopefully so ... :banghead: But even with all this trouble, I still prefer a "not so good" (read: bad) masking rather than the look of some declas - and I know for a fact that Academy's own decals are awful to deal with.
Thanks for commenting and for your support! :thumbsup:
Ciao
Hi Giemme
Looking good, shame about the black lining smudging and the paint under run on the masks, but you seem to have recovered well with the touching up. When I built my He-162 the numbers on the sides were painted using masks. I was going to paint the black outline using a slightly larger mask, but decided it was going to be too much trouble so didn't bother and just left them without the outline!
The mottling looks really effective too. Thanks for including a description of how you did it.
Looking forward to seeing it finished.
Al
Well despite the....er........problems it looks like good progress to me. I don't know how you have the patience to make the masks and do the spraying but (usually) they will look so much better than decals....and, once you've done the touching up and weathering, I'm sure they will be far better too.
Keep calm and carry on.
Kind regards,
Stix
Hi Giemme
Cheers Al, thanks! :thumbsup: The black outline is pretty evident on the real AC (see post #236 in this thread), so I couldn't just leave that off ... :shrug: Trouble now is that it takes longer to fix it, and I should have done it in a different way from the beginning
Thanks Stix! Masking is all about patience; even with this ugly result, to my eyes it looks better than an average decal - and since the kit's one are far below average, definitely better! I will fix the whole thing anyway, no way I'm going on with how it is now :hobbyhorse::fight:
Ciao
