occa Posted August 28, 2015 Share Posted August 28, 2015 Here's B/W that shows parts of the codes: http://www.iwm.org.uk/collections/item/object/205212167 Low contrast hints to TSS indeed Edit: Tho the demarcation line hints to that this is a different AC Or were the colour photos retouched to remove the codes? Link to comment Share on other sites More sharing options...
JasonC Posted August 28, 2015 Share Posted August 28, 2015 (edited) Here's B/W that shows parts of the codes: http://www.iwm.org.uk/collections/item/object/205212167 Low contrast hints to TSS indeed At the risk of being Captain Obvious, that looks like a different aircraft. Unless it's had a full camouflage repaint with different demarcations (i.e. 'A' vs 'B' patterns). J. Edited August 28, 2015 by JasonC 1 Link to comment Share on other sites More sharing options...
occa Posted August 28, 2015 Share Posted August 28, 2015 At the risk of being Captain Obvious, that looks like a different aircraft. Unless it's had a full camouflage repaint with different demarcations (i.e. 'A' vs 'B' patterns). J. Your right, there is also the pennannt below the windshield missing, sorry, I jumped the gun. I had already edited my post before you replied ... Link to comment Share on other sites More sharing options...
cngaero Posted August 28, 2015 Share Posted August 28, 2015 (edited) Here's B/W that shows parts of the codes: Here's B/W that shows parts of the codes: http://www.iwm.org.uk/collections/item/object/205212167 Low contrast hints to TSS indeed Edit: Tho the demarcation line hints to that this is a different AC Or were the colour photos reouched to remove the codes? Low contrast hints to TSS indeed Edit: Tho the demarcation line hints to that this is a different AC Or were the colour photos reouched to remove the codes? Sorry I dropped the laptop before I finished. I think that this is a different aircraft. The B&W image seems to wear a different canouflage pattern carries a Wing Commanders rank pennant, whereas the coIour image carries the pennant of an Air Vice Marshal. I hope this helps. Edited August 28, 2015 by cngaero Link to comment Share on other sites More sharing options...
brewerjerry Posted August 28, 2015 Share Posted August 28, 2015 (edited) Here's B/W that shows parts of the codes: http://www.iwm.org.uk/collections/item/object/205212167 Low contrast hints to TSS indeed Edit: Tho the demarcation line hints to that this is a different AC Or were the colour photos retouched to remove the codes? Hi Possibly the A/C of W/C John Marlow Thompson he was at Luqa / Hal Far, cheers jerry Edited August 28, 2015 by brewerjerry 1 Link to comment Share on other sites More sharing options...
stevehnz Posted August 28, 2015 Share Posted August 28, 2015 Which Makes it Spitfire Vc AR650. Steve. Link to comment Share on other sites More sharing options...
tonyot Posted August 29, 2015 Share Posted August 29, 2015 I did a model in this scheme and mentioned the aircraft used by Park here in this thread,..if it helps; http://www.britmodeller.com/forums/index.php?/topic/234981416-malta-spitfire-on-the-offensiveplus-a-few-others-more-added/?hl=%2Bmalta+%2Bspitfire The Spitfire was AR560, JMT- Personal aircraft of Wing Commander JM Thompson, OC Luqa Wing Here is the model that I built in my impression of the camouflage colours; Cheers Tony 3 Link to comment Share on other sites More sharing options...
