AndyC Posted August 24, 2015 Share Posted August 24, 2015 Hi all I'm building the Tamiya Sd.Kfz 7/1 with the Flakvierling 38 mount on the rear...the link arm from the gunsight to the gun-mount is a simple rod which enables the guns to 'work'. It calls for the ends to be flattened with a hot screwdriver blade - I can just see a disaster waiting to happen with this. Anyone have any recommended alternatives? Otherwise, I will have to have the guns at a fixed elevation and glue it in place TIA Link to comment Share on other sites More sharing options...
Peter Marshall Posted August 24, 2015 Share Posted August 24, 2015 Try gluing a small metal washer at the end ? then trim to fit ? 1 Link to comment Share on other sites More sharing options...
rayprit Posted August 24, 2015 Share Posted August 24, 2015 Practice on waste sprue first....................also check the size of the end on the screwdriver Link to comment Share on other sites More sharing options...
HL-10 Posted August 24, 2015 Share Posted August 24, 2015 Try gluing a small metal washer at the end ? then trim to fit ? When I built this kit I cut a piece of the sprue, the tab that has the part number on it, and glued it onto the end of the pin, then when dry I trimmed it down to be less obvious. Link to comment Share on other sites More sharing options...
AndyC Posted August 24, 2015 Author Share Posted August 24, 2015 Well done all...I will have a look through my spares and my boxes of odds and ends and see what I've got. Many thanks! Link to comment Share on other sites More sharing options...
Mike Posted August 24, 2015 Share Posted August 24, 2015 I would suggest it's easy enough to do over a flame from a lighter or stove, but speaking personally, I'd consider some Friul or similar metal links instead. A lot of work and expense, but I just like 'em Link to comment Share on other sites More sharing options...
andym Posted August 24, 2015 Share Posted August 24, 2015 (edited) Glue them in place. There really isn't any need for them to move unless you're going to play with them (or need them to fit in a specific box for transport). HTHAndy Edited August 24, 2015 by andym 1 Link to comment Share on other sites More sharing options...
bzn20 Posted August 24, 2015 Share Posted August 24, 2015 (edited) Play with? We wouldn't would we? Dagger,dagger! Edited August 24, 2015 by bzn20 Link to comment Share on other sites More sharing options...
Robin Posted August 24, 2015 Share Posted August 24, 2015 I use a small soldering iron, the heat is much easier to control. Robin. Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted August 24, 2015 Share Posted August 24, 2015 To save probs in the future I'd glue them buddy Link to comment Share on other sites More sharing options...
John_W Posted September 4, 2015 Share Posted September 4, 2015 I use a small panel pin/nail hammered in to a piece of dowel. Gives a more even finish and is easier to wield accurately than a screwdriver. Link to comment Share on other sites More sharing options...
Tail-Dragon Posted September 4, 2015 Share Posted September 4, 2015 I personally would make a small disc of sheet plastic, or a "salami" slice of sprue, drill a hole in the center the same size as the peg (you can use a fine drill bit, a jewellers screwdriver or the tip of a #11 x-acto blade) slide you washer into position , and use a tiny drop of liquid cement. You can sand to shape and paint when dry, and never worry about it coming apart. Using pointed tweezers to hold everything, I've made washers down to .005 " thick, with a center hole of .013 " (#80 drill) Have fun, Colin Link to comment Share on other sites More sharing options...
John Aero Posted September 4, 2015 Share Posted September 4, 2015 An old tip is to make a small paper washer, place this on the shaft and wet it with water. Used a small soldering iron or any of the above tips. When formed tear off the paper washer. John Link to comment Share on other sites More sharing options...
AndyC Posted September 4, 2015 Author Share Posted September 4, 2015 All brilliant suggestions guys. I've concluded that moving guns are an unnecessary (and breakable in the future) feature as I can't move, point and make realistic enough Flak 38 noises with one hand whilst holding an allied fighter-bomber with the other in simulation. They will be glued in place! Also in a further nod to realism, I have purchased a set of brass replacement barrels and flash suppressors - very superior to the kit. n ow i just need to finish the kit! Thanks all once again 1 Link to comment Share on other sites More sharing options...
