Sign in to follow this
bootneck
NMF and White - which to apply first?
I have a build to do which has a mix of NMF and white finishes. Unfortunately there is no cheatline, to demark the separations between the white and NMF finishes, so thought I would ask in what order others do their painting.
Normally, I would use Tamiya's grey primer base for the whole model; however, the NMF will be in Alclad and using their black as a primer. I think the white would still have the grey primer but not certain on this.
My queries are:
- is there an order of priming and painting mixes of media? i.e. alclad primer and NMF first, then standard primer and white followed - or vice-versa?
- what is the best method for masking/demarking the NMF and white? I'm concerned about bleed/overrun of the two mediums
- is there a 'special' way to paint NMF and white mixed liveries on models?
I would be very grateful for any helpful advice on this; I've been building and painting models for over 50 years but NMF is a newbie for me.
Mike
This is a very timely question for me, Mike because I need to do a C-47 in a similar scheme and was wondering the best way to proceed!
(Sorry I haven't got the answer! :shrug: )
I would personally use white primer, Alclad my self but tamiya do white I believe, then apply the Alcald over the white. The only issue would be if you want to use the high shine paints, which need a gloss black under coat. In that case I'd go primer, gloss black then white then Alclad.
I'm going to do something similar on a P-51 that's high shine NMF and Olive drab so I hope that'll work!
