Building a HAS
Bit more done.  The wings are attached, and the exhaust nozzles have had some paint & a test fit
clUc2a3xZVxDL0FlmOwsz_g7pS1uq5lanyQ3sKfN
The nose has had a sand down & coat of primer.  I was a bit worried by the 2 part nose & having a visible joint.  Think it will be ok though
MMGIpUcqSghqk_aaWKvxc63Fdt5E053eBk29P3ke
I didn’t like the 2 part piece between the front & back tubs so I put a piece of plasticard across it   On to checking the wing & body joints next
All the main parts are on.  No work on the wheels yet or tanks, gun, missiles & pylons, but the main body looks good to go.  First coat is more to find spots to fix than any colour reason.  So may go car dark grey primer
DNEo7Kbw-6IPIpEGIS71RUx7hCsEUNao4bDCIyvf
So decided the wing brace was needed.  My last two uk Phantoms had them on so I thought this one should join in.  I just made up a paper template and stuck it on, painted then started underside pre shading
NuVsMM5yiPSoItquIhoTzBKFfJNpfW6vOFOJngvv
The top got the various colours on it too
6lyMfJyUoX2up5J3D4SLo-Bv5Luqkp8Ilf2EkTCS
Then Tamiya LAG over the underside.  The shading does show - honest!
1PzwGmFxh0BZ6E2rYPV3AhXNc_EXgrMKDPFEEbFS
Then preshade on the top
o8Sodasb2K3uTh-Al0_OTa4NDTmn1I-hY91iGog8
And grey over it.  The nose is actually darker, and the tail got some blue.  It is French blue and I think it’s a bit light.  Sure it should be nearer to navy blue.  But since I don’t have any darker blue at the moment.  it is a start
PLK8H1Qt_xCHLi-EdiM1VIlYDoyXl-n3LBN7Ki0Y
Tail is done too
So quick shot in daylight to see the colour.  It should be insignia blue but it looks nearer to low viz insignia!  Need to get some proper blue paint
o9xxY5pTf7_9ZENRpWtV_CtLOVeYW_pTfPKldmls
And the wheels are glued on
BrQJMMno1LifVyTHoFF4-qedWICwofUSgiGknHAh
And even got the wheel well doors on.  The canopy has its black inside done.  Got to paint the outside frame.  Need to build a periscope for the centre section too
6fxf5MaWm5rsMpJLR7ojWjf_xNImi68WGftue5Tj
I don’t have a Phantom problem, honest!
XIwPhCAWx15EoxixbNZR-BQ6NJb7WDAeTiG5blZ7
Mind you that’s just the RAF ones, there is an F-4D and an RF-4C upstairs!
Got a plan for the FGR2 identity.  Going 19 Sqn and looking for good reference photos found this
XT902 photographed here at Wattisham from the ABPic website.  I was all set to build the periscope and add a spinal antenna but no, not seen on this one.
Just about finished & ready for decals
WLoBT8liR6LcDfzFR0pwuNw-DBSPGtF1zlovWsy7
And started the decals.  Not done the serial number yet ( going to be XT902) but she has her 19 Sqn tail
KleRrHaJSHr8ChYurIqDGZkjtX-E98wcNVZRsLwT
you can just see the slightly darker main wing tops in this pic - not noticeable in all lights.  More decalling and a few bits before I call her done but coming along
And she has her identity
S3mU8jROenFsPhX4JRHvuERi7vzgZccx4Kxz_lzw
And coming along now.  Got to d3cide if I go for a full set of stencils, even though most can’t be seen in the reference photos
BjN0c0neswlclCZK9baQcdt7cqZaZ36XlVp4ZPDQ
Thinking about the remaining bits to do.  Still no belts on the seats, so need to sort them.  Started painting the wing tanks and Aim 9 rails.  Was thinking of leaving these empty but fitting two dummy/ballast sky flashes.  Borrowed some FOD covers from a US F-4 so fit is poor - need to make some new ones.  And my previous Phantom ladders are a bit past it, so a new paint of ladders are needed.  Posed with the ill fitting FODs and the stand alone ladder ( this one is still ok)
S02teuV4rhoG2iY93Tp8046aW9zGFJD1y08COGTF
Went for the classic air shows of the late 80s line up using my recent builds
xAQS0rR4Bo2DNYe78uZA3xQDBmQRHI8xCVuGS4oi
And then today started on the new FOD covers.  Porgressing nicely.  Just made from cereal box cardboard and waste telephone wire
jmwdtTmDfyG-_chE96ivBVMORL8ewJbe15hsvPi0
Then an I went and knocked off one half of the tail.  Always thought the whole thing on a tiny pin was asking for trouble
BA0p551Avsqc21fwP8Sh2CBBi8L9OxGGORbAd3iY
Going to have to look at putting a rod right through & find a good way to fix on the stabilisers and get the angle right
All done while I was shaping up some tape to form a nose strap
7F_0YBVUEUUEF_vLsE8yPQ288xQe4f2ZR-gN00tq
Not sure if it is too thick.  Might just need some colour on it to make it look better.
Well after knocking off the rear horizontal last night, dug out some wire & started making a rod to go right through & fix both sides to it
xAiDAuPihvdkI-AKbNJBPaSaR2XwwaFfETgoP0vP
FOD covers are painted & fitted, along with the nose strap and rbf tags.  Front end is looking better
UGq_h3AGVeA29jLT69jymyJSiggk-f7LuEgL9h6O
And underneath the tanks and rails are painted & two balast Skyflashes are in place
YKu1xLCTgHsJTBcJYqIBqkU7tM8mxJS0MDpVy6HM
Still lots of stncils to do but quite happy with it now
The FGR2 isn’t really finished yet but a silly cheap kit I picked up a while back keeps getting my attention.  It’s just sitting there going ‘build me!’  It’s a Siat / MMB Flamingo trainer.  Very few parts, very little detail, doesn’t fit my usual build criteria but what the heck
-fxhqwDLRG4p5OgaJ2iRD7yxJsC5eQKZjvYeiK_h
if I build it as the Turkish version it could even go in to the trainer group build
So been progressing the little Flamingo build as part of the trainers GB, so thought I would put progress so far.  This one may be little but it has been putting up a fight!
8vGtb0e2UibyDvg5Fys_XSJwjCgDNr62uW1fpIOy
lots to finish off & tidy up but she is getting there
Got the Flamingo finished off today and got the HAS out too pose her.  They have HASes in Turkey, so why not?
_5CErg42o8rCu-h5wlEAgHaAvFQ5OaxOit2a7_5Q
Its been a fun little distraction of a kit that could well have ended up lost somewhere in the stash.
So what next? Three options spring to mind
dU0GwqyOZiad8WkHPyYtXBQtqUx7atURDChJhPO9
Yes, the ESCI Alphajet Kit I picked up couple of weeks back is tempting, but the F-16 to be built as a Bentwaters aggressor, the vacform TSR2 or more effort in to the scratch build F-27 are the front runners.  I fancy doing the F-16, then the TSR2.  With the F-27 ticking along in the background
was going to go with the white prototype.  I remember seeing it almost in bits at Duxford in the 70s.  my dad thinks he was breaking TSR2 parts when he did his national service.  have s and plan to open up the bomb bay & scratch build the inside a bit.  there is a ton of resin to copy from
Must get on with the Bentwaters F-16 soon.  It is sitting there looking at me.  Until then another Phantom arrived via eBay today.  So what could I add to the current F-4 list?  At the moment it stands at:
F-4J (UK)
2 x FGR2
F-4D
RF-4C
One that has evaded me so far is a late Euro 1 scheme USAF Phantom.  Ideally a Spangdahlem example.  And this AMT version popped up
PHuSIh6ePcUivAQcUT4Msw8HKrHmhpbktwnoVPnV
Never been keen on the grey scheme, and I think I have some extra decals around somewhere too
The last National Service man left in 1963 . TSR2 didn't fly until 1964 wasn't  scrapped until 1965 by the   Wilson Govt . He must have been on some other RAF kites. Not even sure any RAF guys were on them to scrap as they weren't in Service. A few ,can't remember were at Colley's Yard in Feltham,Middx . waiting for the breakers . We could see them from the road under tarps on wagons .
That’s interesting @bzn20 I’ll ask him for more details and see what he might have been up to.  I know he was based around Farnborough before being shipped out to Hong Kong with the engineers.
Was he Army  ? Aldershot is just a stones throw from F/bro
  • 3 weeks later...
Yes Engineers.
Just thought I hadn’t posted a link to the F-16 build that I mentioned
