bar side
Building a HAS
Finished off some bits on the control panel & fitted some nose weight (couldn’t remember if it was needed, but it’s there anyway) so thought I might was well seal up the fuselage.  Considering it has been stuck together, pulled apart & then stuck  back together again it went together nicely.  As RMP said I got a pretty straight one.  Nose extension is on - much worse fit, but working on that.  Some filler around the body joins.  Intakes, wing, tail fins and canopy are loose fitted.  Testing the centre of gravity with the undercarriage and all seems good.
2TtvDzv9WWFcuKihyCEmsvTANQKbxUmuEfY-QjbR
going to have to check & measure everything, but I am sure that when the body & main wheels are all square & level the right wing tip is lower than the left.  Slightly warped wings?  Not sure, going to have to check it out
Quick view with the wings off.  You can just about see the cut out & redone spine vent
hqKWp3Oy87BKTX_b-OxZMSLWv6F8VKhYxb7FOLjy
