Old foxtrot Posted October 4, 2015 Share Posted October 4, 2015 It's coming along nicely. I have the version without the bar armour, think I may have to grab one of these at telford. Great build so far, keep up the good work! 1 Link to comment Share on other sites More sharing options...
SeanM Posted October 8, 2015 Author Share Posted October 8, 2015 Thanks Foxtrot. Slow but steady progress on the main part 3 Link to comment Share on other sites More sharing options...
simmerit Posted October 9, 2015 Share Posted October 9, 2015 It's coming along nicely. I have the version without the bar armour, think I may have to grab one of these at telford. Great build so far, keep up the good work! LionRoar do an etch aftermarket bar armour kit for the basic Buffalo kit - the part number is LAS35019. Be warned, there is a lot of brass, but its excellent by the looks of it - I've got it in the stash and plan to get to it at some point.... http://www.ebay.co.uk/itm/LionRoar-LAS35019-1-35-BUFFALC-6-6-MPCV-Detailing-Set-/351276648866 Link to comment Share on other sites More sharing options...
SeanM Posted October 10, 2015 Author Share Posted October 10, 2015 Maybe a little over the top on the weathering? Wheel threads done. Now need to do the side-walls a good bit lighter Windows being fitted tonight. 2 Link to comment Share on other sites More sharing options...
SeanM Posted October 11, 2015 Author Share Posted October 11, 2015 Here's the sheet to tint the windows Maybe a little darker than it should be but without an airbrush probably the best option. It's 0.23mm thick which makes it rigid enough. Have tried gluing some to scrap windows using different glues which left it foggy or streaky. So will attempt to just place it behind the kit glass and hope the lip in the frame holds it in place. Using the kit glass as template cut and file the tinted plastic to shape There is not a lot of tolerance. Too small and it just falls through, too wide and it won't fit. Window on the left is clear, on the right is backed by the tint Fit of the kit glass is so tight no glue is required. Takes a bit of patience to get it to fit without bending if too tight or falling through if too loose that one window took me over 30 minutes and a few bits of wasted sheet 😓 2 Link to comment Share on other sites More sharing options...
SeanM Posted October 11, 2015 Author Share Posted October 11, 2015 I'm giving up on the tinted windows. Got 3 done with much frustration then doing the 4th the tinted plastic fell out of two if them. 😖 But using glue will fog them... So I'll leave the glass clear and tint them in a few years whenever I get an airbrush 😏 1 Link to comment Share on other sites More sharing options...
SeanM Posted October 16, 2015 Author Share Posted October 16, 2015 Bench time has been hard to find this week but in the little bit available weathered the rubber mud guards and wheels 3 Link to comment Share on other sites More sharing options...
SJLR_1 Posted October 17, 2015 Share Posted October 17, 2015 Looks Great! 3 Link to comment Share on other sites More sharing options...
nick32 Posted October 17, 2015 Share Posted October 17, 2015 Just found this build, read through it and you are doing a great job! This isn't a kit that's usually on my radar, but it looks great and i might have to have a go at building one at some point. Thanks for sharing, Nick 1 Link to comment Share on other sites More sharing options...
heloman1 Posted October 17, 2015 Share Posted October 17, 2015 looking good Sean, I do like these big truck people movers. Lots of interesting add on too. Colin 1 Link to comment Share on other sites More sharing options...
SeanM Posted October 17, 2015 Author Share Posted October 17, 2015 Thanks Gents, glad you're enjoying it. Wheels on and figure beside it just to give an idea of the size. A big brute. Time to start on the slat armour 2 Link to comment Share on other sites More sharing options...
smuts Posted October 18, 2015 Share Posted October 18, 2015 Looks very good, got the original release without the slat armour Andy Link to comment Share on other sites More sharing options...
SeanM Posted October 19, 2015 Author Share Posted October 19, 2015 Thanks Andy, they are a great kit. A bit fiddly in places, but nothing to be afraid of. A nice little note in the instructions. Don't know why they left it to the very last page 😀 3 spruces just for the slat. Lots of sprue fares to be cut and cleaned. Also very fragile. But it does look fantastic. Nice crisp moulding and no flash. Just need to take my time and avoid damaging it. The next steps could see me through to Christmas..... 1 Link to comment Share on other sites More sharing options...
SeanM Posted October 19, 2015 Author Share Posted October 19, 2015 First two joined Only about 24 more to go.... 1 Link to comment Share on other sites More sharing options...
snapper_city Posted October 19, 2015 Share Posted October 19, 2015 Looking good. 1 Link to comment Share on other sites More sharing options...
SeanM Posted October 21, 2015 Author Share Posted October 21, 2015 Thanks Snapper, I must admit I'm happy with out its coming along. Speed improves with practice... 2 Link to comment Share on other sites More sharing options...
SeanM Posted October 30, 2015 Author Share Posted October 30, 2015 There are two types of lights provided to go on the slat. One looks like more modern LED spot loghts but involves small bits of PE with complex folds. The other looks older but only has one puece of PE which doesn't need to be folded. I'm going for simple & easy! 2 Link to comment Share on other sites More sharing options...
SeanM Posted October 31, 2015 Author Share Posted October 31, 2015 And this is one side of the skat before the lights are attached. This took 3 evenings at the bench. No real issues just need to be very careful cutting the slat and fragile arms. 1 Link to comment Share on other sites More sharing options...
magman2 Posted October 31, 2015 Share Posted October 31, 2015 Nice work on the Slats, try the led light lens on the headlights of your Panda M-ATV. 1 Link to comment Share on other sites More sharing options...
Ian Shumsky Posted November 3, 2015 Share Posted November 3, 2015 Coming along nicely! 1 Link to comment Share on other sites More sharing options...
SeanM Posted November 14, 2015 Author Share Posted November 14, 2015 About time I got back at this: 1 Link to comment Share on other sites More sharing options...
SeanM Posted November 14, 2015 Author Share Posted November 14, 2015 A productive evening at the bench: Now I just need to get them painted. Prime with a rattle can and then brush paint over the next few evenings. 3 Link to comment Share on other sites More sharing options...
prowler0000 Posted November 15, 2015 Share Posted November 15, 2015 STILL impressed! Maybe done for Xmas? 1 Link to comment Share on other sites More sharing options...
SeanM Posted November 15, 2015 Author Share Posted November 15, 2015 I think so Prowler. It'll take about a week to paint the slat & lights, a few evenings to fit them and then its just add the aerials etc. If I can just stay focused.... 1 Link to comment Share on other sites More sharing options...
magman2 Posted November 15, 2015 Share Posted November 15, 2015 Sean, nice clean work on the slats. I am saving the photos for reference, on my future build. Keep up the Good Work. 1 Link to comment Share on other sites More sharing options...
