cathasatail Posted August 2, 2015 Share Posted August 2, 2015 Afternoon all, Sorry to trouble you with another quwey regarding the Blue Steel missile When viewing photographs of the Blue Steel missile being loaded onto the Vulcan and Victor, the upper tail surface appears to be missing from a few of those. So my questions are as follows: Was this fin removeable? When carried in the recessed bomb bay of the Vulcan and Victor, was the tail surface kept vertical and fitted into a recess or was it folded down? Thanks, Sam Link to comment Share on other sites More sharing options...
Selwyn Posted August 3, 2015 Share Posted August 3, 2015 Afternoon all, Sorry to trouble you with another quwey regarding the Blue Steel missile When viewing photographs of the Blue Steel missile being loaded onto the Vulcan and Victor, the upper tail surface appears to be missing from a few of those. So my questions are as follows: Was this fin removeable? When carried in the recessed bomb bay of the Vulcan and Victor, was the tail surface kept vertical and fitted into a recess or was it folded down? Thanks, Sam As far as I know the upper fin was fixed and the lower fin folded. I could only find one picture of a blue steel with the fin missing and that was with a Victor, Just speculating , but as there was not a lot of room under the Victor aircraft it may have been removed for loading on this aircraft. Selwyn 1 Link to comment Share on other sites More sharing options...
cathasatail Posted August 3, 2015 Author Share Posted August 3, 2015 Mmm, so I presume that would suggest that the upper fin through the recessed bomb bay doors and into the bomb bay itself? I have a copy of a diagram from the ground handling manual as to the various connections between the missile and the bomb bay (i can't reproduce it here due to crown copyright) but it does hint to a fin-shaped hole in the bomb bay with (perhaps) two panels on either side of this cut-out which could be pushed inwards to allow the upper fin to be fitted? (only speculating) Thanks, Sam Link to comment Share on other sites More sharing options...
cathasatail Posted August 3, 2015 Author Share Posted August 3, 2015 Picture 1: a diagram of how I guess the "doors/panel" might have functioned to allow the tail fin to have been fitted. Picture 2: an image of the actual panel. Sam Link to comment Share on other sites More sharing options...
Kwad Posted August 4, 2015 Share Posted August 4, 2015 The Haynes Vulcan manual has a 3d drawing of the blue steel Bombay door area, it shows a flap door area too. 1 Link to comment Share on other sites More sharing options...
upnorth Posted August 4, 2015 Share Posted August 4, 2015 This diagram shows Blue Steel placement in a Victor: net photo 1 Link to comment Share on other sites More sharing options...
cathasatail Posted August 4, 2015 Author Share Posted August 4, 2015 Ok, thanks guys Now to model it in 1:48th scale ^~^ Sam Link to comment Share on other sites More sharing options...
Kwad Posted August 4, 2015 Share Posted August 4, 2015 Good luck Sam , I'm looking at doing one in 1/144 for the GWH Vulcan kit, once I've got the bombay and 21 1000lb'ers cast up.(the masters are about done). Kev 1 Link to comment Share on other sites More sharing options...
cathasatail Posted August 4, 2015 Author Share Posted August 4, 2015 (edited) Ooohh, very nice May I also wish you the best of luck and enjoyment undertaking your project too. Sam Edited August 4, 2015 by cathasatail Link to comment Share on other sites More sharing options...
