galgos Posted August 25, 2015 Author Share Posted August 25, 2015 Ha ha, no those stripes were just playing about with my airbrush Robert, trying to improve my control and skills! Max Link to comment Share on other sites More sharing options...
hrtpaul Posted August 25, 2015 Share Posted August 25, 2015 All looking great so far Max. I'll be using the 1/32 eyelets on my future 1/32 build and even then I can't see the bloody holes so I'd be stuffed using 1/48 ones. With the knitting in elastic, do you reckon it'd be thin enough for the rigging on a 1/72 kit? I have to use the invisible thread on VH-AMY as I've already started but I'm thinking of future builds. If I can get away from having to use a match to tighten the rigging I'd be happy. I like you thinking re warping the wings too. Awesome work mate Link to comment Share on other sites More sharing options...
AdrianMF Posted August 26, 2015 Share Posted August 26, 2015 FWIW, I use a paint stripper gun to heat my plastic for vacforming. It doesn't have a flame and gives out quite a bit of heat in an even fashion. Regards, Adrian Link to comment Share on other sites More sharing options...
galgos Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks Adrian, I did think that might be an option........but I haven't got one! Max Link to comment Share on other sites More sharing options...
galgos Posted August 28, 2015 Author Share Posted August 28, 2015 OK, wing warping successfully achieved, glad that's over! The lower Moth's wings look fairly good so I don't propose making any changes there: I've also added the bell-cranks for the ailerons, they need a little more work on them with a small file just to neaten them up a bit. I've added some pins on the rudders in order to secure them to the fin but leaving a bit of a gap where the hinges are: I'm working on the underside of the fuselage at the moment, trying to get the detail of panels, covers, aileron wires etc right. Max 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted August 28, 2015 Share Posted August 28, 2015 Nice subtle bending. Regards, Adrian Link to comment Share on other sites More sharing options...
hrtpaul Posted August 29, 2015 Share Posted August 29, 2015 Looks great young fella. Keep it up 😀 Link to comment Share on other sites More sharing options...
bigbadbadge Posted August 29, 2015 Share Posted August 29, 2015 Wow looking good Max, this will be a fantastic scene when complete. Keep up the good work.All the bestChris​ Link to comment Share on other sites More sharing options...
galgos Posted August 31, 2015 Author Share Posted August 31, 2015 It's been pretty quiet in Tiger Mothland over the weekend, so I thought I'd post just a shot or two of what I've been up to! I've started working on the underside of one of the Moths, from my photographs and memory I did a scale sketch of what's what: I completely sanded off the Revell moulding, no idea what it was supposed to represent, and started adding some of the features, initially the access panel under the forward cockpit position: and now cutting out the slot for the aileron control horn to project: More later! Max 1 Link to comment Share on other sites More sharing options...
galgos Posted August 31, 2015 Author Share Posted August 31, 2015 Progress on the empennages, rudders successfully fitted: 1 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted August 31, 2015 Share Posted August 31, 2015 Looking good Max Link to comment Share on other sites More sharing options...
bigbadbadge Posted August 31, 2015 Share Posted August 31, 2015 Hi Max, very nice, was wondering how I might do the fuselage below the cockpit, will watch and use as refernce if that's okay. Could I ask what you used as the guides on the horizontal tailplanes for the control cables please ? Keep up the good work All the bestChris​ Link to comment Share on other sites More sharing options...
galgos Posted August 31, 2015 Author Share Posted August 31, 2015 Thanks Mish and Chris, I'm really enjoying these two builds - all's gone well so far but there are sure to be problems ahead when I come to put the wings on! My enjoyment is helped by my new model room and set up - at last I have both space and good light! Chris, the guides are the little "twists" of wire from Bob's Buckles, so effectively part of a turnbuckle. They're easy enough to make, lots of instruction to be found online. Max Link to comment Share on other sites More sharing options...
hrtpaul Posted September 1, 2015 Share Posted September 1, 2015 (edited) I do like how you've got the gaps between the horizontal and the vertical stabs and also the rudder. I'll be shamelessly stealing those ideas for my build when I get to it :coolio: Oh and nice modelling room setup mate Edited September 1, 2015 by hrtpaul Link to comment Share on other sites More sharing options...
galgos Posted September 1, 2015 Author Share Posted September 1, 2015 That's not shamelessly stealing Paul, that's just modelling accurately to type! Max Link to comment Share on other sites More sharing options...
galgos Posted September 1, 2015 Author Share Posted September 1, 2015 A little more progress on the underside detailing using Evergreen strip: These arrived this morning, Meng nuts and bolts - just in time for some to be added to the plane, but don't tell anyone.......they're 1/35 scale not 1/32!! Max 2 Link to comment Share on other sites More sharing options...
bigbadbadge Posted September 1, 2015 Share Posted September 1, 2015 Hi Max Thanks for the Tip re the guides, I do have some for a WNW Snipe but I will make them as they are very easy to make anyway (I did this for the smallest gauges on the Instrument panels following the carpet monster getting hungry and eating my last PE ones. I do like the work you have done underneath, as Paul said, I too will be shamelessly stealing your ideas and using !!! I hope you don't mind. I like your work space, very light and very clean and tidy, wow. Gonna have to give mine a tidy!!! Keep up the good work All the best Chris Link to comment Share on other sites More sharing options...
galgos Posted September 1, 2015 Author Share Posted September 1, 2015 Chris, I'm more than happy to share any information, tips, techniques etc that I have gathered together....I hesitate to call it expertise cos it isn't, just trial and error and a happy coincidence that I've got such good access to 3 Tiger Moths. Max Link to comment Share on other sites More sharing options...
hrtpaul Posted September 1, 2015 Share Posted September 1, 2015 That's awesome work underneath Max. When I visit AMY next I must get some pics of the underside. I love the 1/35, I mean 1/32 nuts and bolts. What a cracker idea Link to comment Share on other sites More sharing options...
galgos Posted September 4, 2015 Author Share Posted September 4, 2015 Still WIP, but spot the difference! Max Link to comment Share on other sites More sharing options...
bigbadbadge Posted September 4, 2015 Share Posted September 4, 2015 Wow looking good Max , fantastic work All the bestChris​ Link to comment Share on other sites More sharing options...
hrtpaul Posted September 5, 2015 Share Posted September 5, 2015 That's sensational mate. I'm gonna have to do all that on my 1/32 build now thanks to you and my OCD LOL 1 Link to comment Share on other sites More sharing options...
galgos Posted September 5, 2015 Author Share Posted September 5, 2015 I'm gonna have to do all that on my 1/32 build now thanks to you and my OCD LOL I know how you feel........it's a real PITA at times isn't it? :) Max Link to comment Share on other sites More sharing options...
AdrianMF Posted September 7, 2015 Share Posted September 7, 2015 Nice undersides! I feel the sudden urge to glue all my Tiger Moths to a big base... Regards, Adrian 1 Link to comment Share on other sites More sharing options...
galgos Posted September 7, 2015 Author Share Posted September 7, 2015 OK, I've found what I hope is the solution to fixing rigging line to GasPatch turnbuckles....though it's rather fiddly! I slid a length (3mm) of 0.5mm brass tube over the "extended part" of the turnbuckle and secured it with a smear of CA. The brass tube needs a 0.3mm drill run through it first to de-burr it and the extended part of the turnbuckle needs a light file round it first. So the brass tube is acting as a sleeve. A dab of CA just pushed inside the sleeve is enough to hold the line when inserted: The 0.5mm micro-tubing cut to length is available from Bob's Buckles though I'm sure there are other sources. Max 1 Link to comment Share on other sites More sharing options...
