Looks good, I like where you're going with the wave, how will you attach it? Superglue?
Interesting. I am going to place my Universal Carrier in a diorama where it is charging through a muddy puddle, and I want to recreate big splashes so I'm following this topic with interest.
I will use Woodland Scenics Realistic Water for the puddles themselves (expensive stuff, but very realistic) but I am thinking about using polythene or similar for the sheet-like splashes, and something else for the airborne droplets, maybe glue.
The more options you try, the less I will have to try! :thumbsup:
Badder.
Edited by Badder
Thanks for the comments guys
phildagreek it is an adhesive ! ;-)
Badder
This stuff is ideal for sheet material / water. I spread it thinly on cling film wrapped around a flat surface. This gives it a wrinkled finish cos the film rucks up.
If you want it flat I would suggest spreading it on glass, curved over a tube etc
Give it 24 hours to dry and you can get some thin strings
As you can see in the following photo it can be mixed with acrylic to colour. The stuff is not crystal clear more tinted dirty water
You can get it quite thin 0.2mm
Hope this helps
Kev
Spent some time this afternoon sorting bits & pieces....... including rope work .
I've seen several pics with the tow rope fixed with a shackle to the bow reinforcing plate, so.................
Thought you might like to see how I make shackles (Good for you Tanky guys :winkgrin: )
Start by annealing your brass rod so it can easily be bent to shape
I clamp it in a vice so I can cut the two legs too the length I want
Cut two small tubes by rolling knife on tube. Note clean the end square before cutting then you know the drill bit will slide in one end easily.
These are held in position on the drill bit against the ' U '. Apply solder, in this case solder paint. Apply heat
You should be left with this. By leaving the bit in whilst soldering you know the tubes are in a straight line and your closing rod will slide in easily.
You can of course replace the rod with a bolt and with a suitable tap you can make a working shackle.
I hold the shackle with the drill bit whilst filing back the tube to the right size
The finished result
When the rain stops I'll flatten the end to complete the pin
I hope this is of some use to you out there and I'm not teaching you to suck eggs
As always thanks for stopping by
Kev
Edited by longshanks
Now that looks very neat and thanks for the tip will have to get me some of that solder paint and give it a try :book:
Beefy
'Wow', the man is at it again.
Thanks for sharing Kev mate.
foxy :coolio:
Julian, feel free to place an order matey
Just need the sizes required
Would it be for your up and coming Panzer?
Kev
Kev
Hadn't even considered the possibilities there Kev. Really great craftsmanship, who knows, might even see you with your own after market parts e-mail store.
Big compliments mate :goodjob::yahoo::thumbsup::yahoo::thumbsup::yahoo:
