Carlosee1974 Posted July 25, 2015 Share Posted July 25, 2015 Hi, I've seen lots of amazing finished projects on here where the tiny gap and rivets are highlighted by dark paint? How do I do this? Link to comment Share on other sites More sharing options...
Fatboydim Posted July 25, 2015 Share Posted July 25, 2015 Hi Carlosee1974, this is how I do mine. I find it quick and easy. Gouache, tap water and kitchen roll. Mix the gouache with a little water and gently rub on. Let it dry for a few minutes. Wipe off with a clean piece of tissue. You might have to revisit any sections your not happy with. If you apply too much, just rub it off with a damp tissue. Hope this helps, Joe. Link to comment Share on other sites More sharing options...
Deanflyer Posted July 25, 2015 Share Posted July 25, 2015 Hello there... There's a section on Britmodeller called Tips and Tricks - if you look at that or do a search for washes, as they're called, you'll find all sorts of posts on this subject. Some of them lead you to useful links such as this one: https://www.youtube.com/results?search_query=using+washes+on+models&oq=using+washes+on+models&gs_l=youtube.3...466.13562.0.14365.22.22.0.0.0.0.352.3053.7j12j2j1.22.0...0.0...1ac.1.11.youtube.nTTFa-1WwsU Have a read, have a watch, have a go...and get ready for the influx of posts warning you not to overdo it! HTH, Dean 1 Link to comment Share on other sites More sharing options...
Fatboydim Posted July 25, 2015 Share Posted July 25, 2015 That's good advice by Dean. I should have said gouache can stain the paint. Gloss paint is less prone to staining. Always try it out first on a small section to make sure your happy with the result. Link to comment Share on other sites More sharing options...
