Bordfunker
235 Squadron Blenheim IVF *** Complete ***
Time to get my modelling mojo back into gear for this group build, and having read Alfred Price's 'The Hardest Day' over and over again over the years I always loved the account of Coastal Command Blenheim's IVFs wading into Stukas after the latter's attack on Thorney Island.
Simple choice then, a 235 Sqaudron Blenheim, and with the Airfix kit fresh on the shelves it had to be this kit.
Obligatory pick of the box.
IMG_20150719_121702_edit_1437430417841.j
And now the contents....
IMG_20150719_121755_edit_1437430487052.j
Clear parts, decals and mandatory masking set.
IMG_20150719_121831_edit_1437430528839.j
I also picked up some background reading as I know nothing about Blenheims!
IMG_20150719_121933_edit_1437430552253.j
Second profile down from the top will do nicely for this build.
IMG_20150719_122000_edit_1437430688765.j
Now to sort out some codes and serials as I've got nothing in the spares box for this.
Karl
Edited by Bordfunker
I'm in I do like a nice Blenheim.
Nice one, I have a stalled 235 Sqn IVf build (ye olde kit). A bit of inspiration won't go amiss.
John.
Welcome along to this build!
Be warned I'm not the world's fastest builder!
I have made some progress on the cockpit and the wing spars and undercarriage bays.
Airfix have provided two very robust wing spars, which also form the front and rear walls of the undercarriage bays, with inserts for the internal structure.
All very nice apart from the two ejector pin marks in the roof of each bay. Nothing major, and probably not something that will ever be seen, but it bugged me, so both had a disc of styrene glued in and sanded smooth.
The cockpit also suffers from a few ejector pin marks which were treated in the same way but only the ones which would be visible once the rest of the pit was installed.
The pit itself is very nice straight of the box, so I'll just be adding seat belts, and the shot below shows the pilots seat and rear bulkhead.
I've also dipped all the clear parts in Future in preparation for masking up.
That'll do for tonight, thanks for watching.
Karl
Excellent Karl, like you I had been inspired by Dr. Alfred Price's book and the part following the Stuka's attack on Ford, Gosport and Thorney Island when they get caught by the various defending RAF aircraft is brilliantly written...
Well, in short, I'm hooked... :popcorn:
Stew
A very nice start, happy modelling with this one. The cockpit looks very nice out of the box
Thanks for the comments guys.
The Hardest Day has to be one of my favourite books.
A little more progress this evening, mainly cutting parts from the sprues and cleaning up.
I did manage to glue the IP structure in having fist filled the sink mark in the middle of it.
On the topic of sink marks, the flaps also suffers from them, but nothing that a little Mr Surfacer wouldn't fix.
I also got around to adding some scraps of PE to the pilots seat for harnesses, which I first annealed to make it more flexible.
The engines are little gems, however the carburetor trumpets could do with opening out with the tip of a craft knife.
The only items missing are ignition leads and the diagonal bracing strips. I might add the latter from fine wire, but I don't think I'll bother with the leads.
After taking the photos I realised how rough the tubing behind the seat looked, so while the Mr Surfacer was out it got a coat.
That will have to do for tonight, but making steady headway towards starting painting the interior.
Karl
Karl
Are you aware that the ignitions wires on a Mercury are not on the front of the engine? The wires come up form the rear of the engine and the spark plugs are on each side of the cylinder.
http://www.airpowerworld.info/aircraft-engine-manufacturers/bristol-mercury.htm
Chris
Chris, that I did not know, so one less thing to worry about.
Karl
Good choice of subject Karl.
Nice to see a Blenheim being entered into the build. Built the MK.1 last year so I'm looking forward to seeing how this one turns out.
Craig.
Having picked up the Osprey book I'm tempted to do a Mk1F at some point in an all black scheme Craig.
Not much in the way of pics to post tonight, but have made quite a bit of progress this afternoon.
I started out sanding the Mr Surfacer off the flaps.
Much better!
Next up was the exhaust collector rings on the engine cowlings. Airfix have based these on a Bolingbroke, just like the engine nacelles, however this is easier to fix.
The ring on the right is as supplied, the one on the left as modified, just a straight forward sanding job.
I spent the rest of the afternoon cutting parts off the sprues before putting a coat of NATO black over the interior and wheel bays as a primer.
I'll post some more pics tomorrow.
Karl
As per my last post, some pics of the parts with a coat of NATO black.
Each fuselage half comes in two sections, the rear component which is common to both the Mk1 and MkIVF. The idea that you build front and back separately and then bring the two together after the wings have been fitted. I didn't fancy that idea, so joined front and rear sections to form one complete fuselage half at the very start of the build.
The wings got a coat of NATO black, along with the pit assembly and the engines.
As you can see I added the diagonal braces to the main engine stays. These were made from sections of wire taken from multistrand model railway wire, rolled straight and then super glued in.
This morning I managed to get a coat of interior green onto the pit, wheel bays and flaps.
I then applied a thin, random coat of IJA Grey/green to the centre of panels and in a downward direction to the pit etc.
It looks a bit stark now, but by the time it is glossed and washed it will look fine.
Next up is detail painting of the interior, after which it will be time for a gloss coat and wash.
Karl
Good start Karl.
And a good idea with the fuselage halves, I followed the kit instructions on my Mk.1 and it does not work well. I will do the same as you on my next one, whenever that might be!
Craig.
Nice progress Karl, this kit does look nice.
Nice to see a Blenhiem in the GB, great bit of progress,
Sean
Thanks for the encouragement guys.
No pics tonight but there has been some progress.
I managed to close up the wings last night and put some Mr Surfacer on the seams this evening, so not exciting but progress none the less.
Detail painting of the interior is almost complete, despite my best efforts to daub paint in the wrong place!
I'll post some pics tomorrow night.
Karl
Thats good progress and a very nice paint job ! Well done so far.
Excellent progress Karl.
How easy is this? Is it just a case of lining up the sections on a flat surface and gluing? I'm wondering how good the alignment is.
Enjoying watching this build, keep up the good work!
John.
Looking good Karl watch the fit between the wing centre section and the fuselage. If youre not careful you end up with a step
Dazdot, I've dry fitted the fuselage to the wings and the fit is pretty much spot on. That's probably just dumb luck on my part though!
John, it's fairly easy to line the front and rear sections of the fuselage up, however the join area is quite small so everything needs to be allowed to set up before you try moving it.
I've finished up the detail painting of the interior, and applied a coat of Humbrol clear in preparation for the application of the IP decal and a wash.
Karl
Time for some pics of progress to date.
First up the wings....
Not very exciting, but progress all the same!
Having spent some time looking at pics of various Blenheims, it is clear the solid molded wing tip lights aren't going to cut it. (See what I did there? Suit yourselves!) So I've cut out the molded lights ahead of replacing them with some clear sprue.
Here's the port side of the fuselage painted up, and with the IP decal applied, not that you can see it from this angle.
This just needs an oil wash and a coat of matt varnish, and the fuselage can be closed up, along with the pilot's seat and rear bulkhead.
I'm quite pleased with how the belts came out, not quite Eduard, but they'll do under a closed canopy.
Now what about the other side of the fuselage I hear you ask? Yes well. You now how I said the joint between the front and rear sections was delicate? Well I went and proved it!
It's a nice clean break so no big issue to fix.
I've got a week off next week so should make some good progress.
Karl
Currently waiting for the final gloss coat on the interior to dry before I apply an oil wash so decided to tackle some of the other parts of the build.
First up were the wing navigation lights, having carved out the solid representations earlier in the week.
Being Airfix plastic it is very easy to carve, and was the work of a few minutes. Next up were the lenses themselves, fashioned from clear sprue from the kit, roughly sanded to shape and painted with a coat of Tamiya Cockpit Green.
These were then glued in with thick CA, I won't call it super as it isn't, a 'super' glue would stick to the part first not me!
As you can see I still need to sort out the landing light.
Sticking with the glazing theme I gave the edges of all the clear canopy components a coat of Tamiya Cockpit Green, just so that when they are joined you can't see the join through the glazing.
Having done that it was time to turn my attention to the engine cowlings.
Now I must admit I found these quite fiddly with minimal jointing area, but then that's probably because I've built them free standing without an engine the middle for support.
Focus has been on neatening the seams, but also hollowing out the exhausts as they look dreadful molded solid. The end result is this....
Much better to my eyes at least.
That'll have to do for today as off to see the Mission Impossible movie this evening.
Karl
Nice progress, Karl.
