Shar2 Posted July 18, 2015 Share Posted July 18, 2015 Russian Navy Battleship Tsesarevich 1904 Trumpeter 1:350 History Tsesarevich was a pre-dreadnought battleship of the Imperial Russian Navy, built in France at the end of the 19th century. The ship's design formed the basis of the Russian-built Borodino-class battleships. She was based at Port Arthur, Manchuria after entering service and fought in the Russo-Japanese War of 1904–05. Tsesarevich was the flagship of Admiral Wilgelm Vitgeft in the Battle of the Yellow Sea and was interned in Tsingtau after the battle. At the end of the Russo-Japanese war, the ship was transferred to the Baltic in early 1906 and helped to suppress the Sveaborg Rebellion later that year. Around 1906, her fighting top was removed and her superstructure was cut down. The 75 mm guns in the superstructure were apparently removed as well. Tsesarevich made regular winter cruises to the Mediterranean before World War I and aided survivors of the Messina earthquake in December 1908. In 1909–10 the ship's machinery was overhauled and her amidships casemated 75 mm guns were removed and plated over four years later. Tsesarevich was not very active during the early part of World War I and she reportedly received two 37 mm anti-aircraft guns during the war. Because of her inactivity her bored sailors joined the general mutiny of the Baltic Fleet in early 1917. She was renamed Grazhdanin on 13 April 1917 after the February Revolution. The ship took part in the Battle of Moon Sound in October 1917. During the climatic part of the battle, Grazhdanin engaged the German minesweepers on 17 October with little effect while Slava engaged the German dreadnoughts König and Kronprinz. The latter fired at Grazhdanin and hit her twice, killing one and wounding four crewmen, although neither hit caused significant damage. The German dreadnoughts outranged Grazhdanin and she was forced to retreat and abandon Moon Sound in the face of German pressure. By December the ship was in Kronstadt where she came under the control of the Bolsheviks and she was hulked there in May 1918. Grazhdanin was scrapped beginning in 1924, although she was not officially stricken from the Navy List until 21 November 1925 The ship was ordered as part of the "Programme for the Needs of the Far East", authorised by Tsar Nicholas II in 1898 to defend Russia's newly acquired ice-free port of Port Arthur in Manchuria. Russian shipyards were already at full capacity so the Naval Ministry decided to order ships from abroad. Specifications were issued on 14 June 1898 and a few days later the chief designer of the French shipyard Forges et Chantiers de la Méditerranée proposed a design based on that of the French battleship Jauréguiberry. The Naval Technical Committee approved the design with a few changes to which the French readily agreed. The General Admiral, Grand Duke Alexei Alexandrovich selected the French design over a competing proposal from the Baltic Works. A contract was signed on 20 July 1898 at a cost of 30.28 million francs (11.355 million rubles) for delivery in 42 months. Tsesarevich 's most obvious design feature was her tumblehome hull. This had several advantages because it allowed greater freeboard since the narrow upper decks reduced the structural weight of the vessel's hull, it increased the field of fire of guns mounted on the sides, and it reduced the ship's roll in heavy seas. Its great disadvantage was that it reduced buoyancy and stability which contributed to excessive heel during turns. During the Battle of the Yellow Sea in August 1904, Imperial Japanese Navy observers thought the Tsesarevich was going to capsize when she suddenly turned out of the battleline. Tsesarevich was 118.5 metres (388 ft 9 in) long overall, had a beam of 23.2 metres (76 ft 1 in) and a draught of 7.92 metres (26 ft 0 in). The ship displaced 13,105 tonnes (12,898 long tons). Her crew consisted of 28–29 officers and 750 enlisted men.The Model Having released the Tsesarevich in her 1917 guise last year, Trumpeter have now released a kit of her as she was when first completed. The kit comes a top opening box with a very nice artists impression of the ship, anchored at the head of the battle line. On opening, the modeller is confronted with the two hull halves, whose bow and stern sections are given extra foam protection, eight sprues of medium grey styrene, three sub-sprues, five sheets of etched brass, a length of brass chain and a small decal sheet. The sprues are clear of flash and other imperfections and there are fewer moulding pips than normally found on Trumpeters ship kits. The moulded on detail is very nicely done and it appears that the unusual tumblehome shape of the hull has been moulded with all the right curves, although as I don’t have any plans I can’t tell if it’s totally correct, but it certainly looks the part. With the amount of etch contained in the kit it really can be made straight out of the box without the need of any additional aftermarket sets, although this probably won’t deter the aftermarket companies from releasing them. Before construction proper can begin, the modeller needs to open up quite a few holes, both on the hull sides and the main decks. These are clearly marked in the instructions and on the parts themselves where the holes have been flashed over. The build begins with the construction of several sub-assemblies. These include the six secondary turrets, each made up of the two barrels which are slid unglued onto the trunnion which in turn is glued to the trunnion pivots which are glued to the turret base. The turret itself is then slid over the barrels and glued to the base before being finished off with the addition of a PE rail on the turret roof. The two main turrets are constructed in a similar fashion, but without a roof rail. Next up are the eleven maxim machine guns, made from two styrene parts, (the gun and shield), along with the PE base folded to shape. The six single 75mm guns are all styrene, and consist of the barrel, shield, swivel mount and base, whilst the twelve 47mm cannon come as a single piece barrel/mount requiring only the shield to be fitted. The modeller then has to assemble four cable reels, each with PE stands, PE drum ends and styrene drum, along with six two piece deck mounted bitts. There are another twelve 75mm guns in casemates along the hull and these are glued to three internal bases per side and slid through their firing ports from the inside. With these fitted the hull halves are joined together with the rudder sandwiched between the halves, along with two sturdy bulkheads. The side mounts for the twin 6” secondary turrets are fitted, one per side, near the top of the hull sides. The quarterdeck and bilge keels are also glued into their respective positions. The main deck is the attached along with the quarterdeck/main deck bulkhead, followed by the upper side pieces and lower bridge wings. The large windlass, made up of eight styrene and four PE parts is assembled and positioned at the rear of the foredeck. From the bow, the foredeck is then fitted out with the jack staff, cleats, bitts, ventilators and the splinter shields for the port and starboard 6” turrets. Moving admidships there are three deckhouses fitted, the front one being the base of the bridge. Before attaching the next level of the bridge structure, six supports and the base of the foremast need to be glued into position. With these in place the bridge piece, which has been fitted with the armoured control tower to the underside, can be slid over the mast section and glued into position, followed by the two 6” turrets and two capstains. The bridge is slowly built up with the upper section of the tower, the bridge itself and a further deck with additional deckhouses and deck supports. Four of the 75mm guns are fitted two per side, just aft of the bridge. One deck up an there is a complicated bit of bending required to fit the railing, which you will need to be careful not to knock off as you fit the six 47mm guns, binnacle and rangefinder to the deck. Moving aft the fore-funnel is assembled from two halves and fitted with two PE blocks to the rear, a PE vertical ladder for each side, plus a PE funnel cap, the completed funnel is then fitted to its position just aft of the bridge structure along with a pair of PE inclined ladders. Meanwhile back to the foredeck, and the fitting of the four anchors, plus a pair of booms, one port and one starboard between each pair of anchors. The foretop is then assembled with the main styrene part being fitted with PE angled supports on the underside, whilst on the topside four 47mm guns are fitted, along with PE window frames fore and after and finished off with the roof. This assembly is then attached to the top of the lower foremast section. Between the funnels there are two boat cradle decks, each made up of both styrene and PE parts and glued into their respective positions, one aft of the fore-funnel and one foreward of the aft funnel. On the foretop roof there is a small gun station fitted out with three maxim machine guns with another section of foremast glued to the centre. Just aft of the rear funnel there is another winch unit, this one made up of seven parts. The front main 12” turret can now be fitted along with the two side mounted 6” turrets, whilst the foremast is fitted off with anotehr platform on which another section of mast is fitted along with a searchlight. The previously attached boat decks are fitted with PE cradles onto which the four large cutters are mounted, each cutter also having a two piece whale boat cradled on their thwarts. The aft boat deck is for the steam launches, with each of the four launches, two large and two smaller are each made up of the hull, deck, funnel, gun mount, gun, searchlight, ventilators and propeller, with the smaller ones also having a rear mounted maxim and a torpedo. With the boats fitted the rear funnel can be assembled, this consists of two funnel halves, PE vertical ladders, PE blocks, PE funnel cap and a PE derrick complete with hook. The completed funnel is then glued into position. At the centre of the foreward boat deck there is a searchlight tower made from a PE tower structure, PE railings, PE ladder and styrene searchlight. The aft superstructure supports are attached, along with the aft pair of 6” turrets, the aft mounted main 12” turret along with two decklights, inclined ladders, aft mounted anchor, spare anchor just aft of the rear boat deck, a pair of derricks each side, the boat booms, bitts, cleats and ensign staff. The after superstructure deck is fitted with a deckhouse and angled supports glued to the underside, before being fitted onto the previously attached supports between the two aft 6” turrets. The four piece steam launch derrick is assembled and fitted to the rear of the aft superstructure deck along with another deckhouse and further deck supports, onto which another deck is fitted. This upper deck is fitted with six 47mm guns and another complex railing which will require careful bending to shape. Both the foremast and mainmast are finished off with the addition of the mast tops and various length yards and platforms along with each having a pair of searchlights fitted. The foreward boat deck is then fitted with a pair of large davits complete with PE downfalls, whilst the two convoluted, (to cope with the weird tumblehome shape of the hull), PE accommodation ladders are assembled and glued one per side aft of the steam launch deck. Another pair of whale boats are attached to the derricks previously fitted to the ships sides. To finish the kit of it’s only a matter of fitting the two propeller shafts, propellers and assembling the stand supplied, complete with a nice plaque with the ships name on.Decals The small decal sheet contains two sizes of ships crest, the Russian and Ensign, in both flat and wavey form. For what it is, it is very nicely printed, although the blue cross on the wavey ensign appears to be quite a bit out of register. Conclusion I just love the look of these ships in which you can clearly see the French influences. They look so wrong that they’re right, if you know what I mean. This is a very interesting kit and will make a nice, different addition to any maritime collection. Without any plans I cannot say definitively how accurate it is, but it looks pretty good when compared with the published photographs, although the kit seems to be a little undergunned in the tertiary department as the details show that she actually was armed with a few more 47mm and additional 37mm cannon. Otherwise it is a very nice kit and can recommend it quite highly.Review sample courtesy ofUK Distributors for 5 Link to comment Share on other sites More sharing options...
Antoine Posted July 19, 2015 Share Posted July 19, 2015 Thanks Dave. I like the hull shape of those old battleships. Build in France? From which class? Link to comment Share on other sites More sharing options...
Shar2 Posted July 19, 2015 Author Share Posted July 19, 2015 You might want to read the history a bit more carefully Antoine. Link to comment Share on other sites More sharing options...
Ravens Posted July 19, 2015 Share Posted July 19, 2015 I've had my eye on this release for a while and it looks to be a worthy purchase. As mentioned in the review the etching that comes with it is quite extensive - I wonder what more an after-market set could add? Ross. Link to comment Share on other sites More sharing options...
Antoine Posted July 20, 2015 Share Posted July 20, 2015 You might want to read the history a bit more carefully Antoine. I might.... Link to comment Share on other sites More sharing options...
prowler0000 Posted July 20, 2015 Share Posted July 20, 2015 Nice review, Dave! I have the 1917 release, & wondered how different this & the 1st release were. Do you have both available to you for a quick comparison to see the changes (if any) Trumpeter made?? Link to comment Share on other sites More sharing options...
Shar2 Posted July 20, 2015 Author Share Posted July 20, 2015 I haven't got the 1917 to hand, but I might be able to sort something out over the weekend. 1 Link to comment Share on other sites More sharing options...
prowler0000 Posted July 20, 2015 Share Posted July 20, 2015 I haven't got the 1917 to hand, but I might be able to sort something out over the weekend. Thanks Dave! Usually i compare the instructions on HobbySearch, but the 1904 release has no instruction scans.... Link to comment Share on other sites More sharing options...
