wellzy Posted July 9, 2015 Share Posted July 9, 2015 Hi all well l hope to be building a Assembly Ship B24 ,cant say witch one when the decals get here !! The Kit More to follow ....Les 4 Link to comment Share on other sites More sharing options...
Dermo245 Posted July 9, 2015 Share Posted July 9, 2015 Nice......can't have a B-24 GB without an assembly ship or two! Dermot Link to comment Share on other sites More sharing options...
Arniec Posted July 10, 2015 Share Posted July 10, 2015 That is a great looking kit. And a assembly ship as well. Very interesting. I will watch this one. Cheers, Link to comment Share on other sites More sharing options...
wellzy Posted July 16, 2015 Author Share Posted July 16, 2015 ok we now have the Decals My build will be Lemon Drod 44th BG My Reference Cheer`s Les 1 Link to comment Share on other sites More sharing options...
wellzy Posted July 16, 2015 Author Share Posted July 16, 2015 Here is the start of my build , and i thought 1/72nd would be easy 3 Link to comment Share on other sites More sharing options...
Arniec Posted July 16, 2015 Share Posted July 16, 2015 Nice start Les. I will be wathing this. Cheers, 1 Link to comment Share on other sites More sharing options...
wellzy Posted July 22, 2015 Author Share Posted July 22, 2015 (edited) Getting some of the sub assemble work done !! Cheer`s Les Edited July 22, 2015 by wellzy 2 Link to comment Share on other sites More sharing options...
Planebuilder62 Posted July 22, 2015 Share Posted July 22, 2015 Well done so far. I recommend you build the nose the same way as Nils. I didn't, followed the instructions. .........., and had to take it off 3times. Regards Toby 1 Link to comment Share on other sites More sharing options...
wellzy Posted July 22, 2015 Author Share Posted July 22, 2015 Well done so far. I recommend you build the nose the same way as Nils. I didn't, followed the instructions. .........., and had to take it off 3times. Regards Toby Thanks for the heads up Toby Les Link to comment Share on other sites More sharing options...
wellzy Posted August 1, 2015 Author Share Posted August 1, 2015 Got a bit more of the inside done . Cheer`s all 1 Link to comment Share on other sites More sharing options...
Arniec Posted August 1, 2015 Share Posted August 1, 2015 That is looking great Les. Keep the updates comming. Cheers, 1 Link to comment Share on other sites More sharing options...
wellzy Posted August 2, 2015 Author Share Posted August 2, 2015 Hi Guy`s has any one had trouble getting the nose together on this kit? or it me ,took a hour to get the cockpit floor to fit Cheer`s Les 2 Link to comment Share on other sites More sharing options...
wellzy Posted August 7, 2015 Author Share Posted August 7, 2015 A bit more work done Cheer`s Les 4 Link to comment Share on other sites More sharing options...
tonyot Posted August 7, 2015 Share Posted August 7, 2015 Coming along nicely Les, The upper section of the nose looks like a poor fit,.....maybe the mating parts could do with a bit of sanding to make the fit better? Looking forward to seeing the colourful finish going on, Cheers Tony 1 Link to comment Share on other sites More sharing options...
wellzy Posted August 7, 2015 Author Share Posted August 7, 2015 Coming along nicely Les, The upper section of the nose looks like a poor fit,.....maybe the mating parts could do with a bit of sanding to make the fit better? Looking forward to seeing the colourful finish going on, Cheers Tony Thanks Tony l can see what you mean with the price tag on this kit lm not impressed, Academy is just as good as a finished build Les Link to comment Share on other sites More sharing options...
Wolwe82 Posted August 8, 2015 Share Posted August 8, 2015 Good job so far Les. One thing - i m realy sorry i did not noticed it earlier (only now when i did read about the bad nose fit..) - the problem might be in the instructions, when you are completing the cockpit and the first wall in there - in the instructions it is drawed exactly how you did it. But the first wall should be pushed on the floor, like 5mm more towards the cockpit - then the "floor" continues through the front pit wall and makes the table there. It is totaly Hasegawa´s fault and their wrong instructions, i m sorry i was not here earlier to tell you .. But it seems you managed to get the nose together quite good anyway 1 Link to comment Share on other sites More sharing options...
Learstang Posted August 8, 2015 Share Posted August 8, 2015 Very nice! I'm not normally a huge fan of the Liberator, other than Coastal Command ships, but I do love the assembly ships. I've always fancied doing the polka dot one, but I think this is an even better scheme. It should look fantastic when finished! Regards, Jason 1 Link to comment Share on other sites More sharing options...
wellzy Posted August 16, 2015 Author Share Posted August 16, 2015 Starting with the wings now , and got some resin engine`s Test fit with the new resin engine Cheer`s Les 4 Link to comment Share on other sites More sharing options...
Arniec Posted August 19, 2015 Share Posted August 19, 2015 Those resin engines are a real treat to the model. Specialy when they are in a very seable spot. Cheers, Link to comment Share on other sites More sharing options...
wellzy Posted August 19, 2015 Author Share Posted August 19, 2015 Dry fit for wings and tail ,after the fun l had with the nose these`s went in a treat ,well something had to go right !! Cheer`s Les 3 Link to comment Share on other sites More sharing options...
philp Posted September 16, 2015 Share Posted September 16, 2015 I am a big fan of the assembly ships and will eventually do at least one myself. At the US Nats in Seattle back in 1992 (I think) the program included a good story on Lemon Drop and decals in 72nd and 48th scale. Think I still have them if you are interested. Link to comment Share on other sites More sharing options...
wellzy Posted September 26, 2015 Author Share Posted September 26, 2015 Ready foe paint , masking the nose was a nightmare !!! Cheer`s Les 3 Link to comment Share on other sites More sharing options...
Arniec Posted September 27, 2015 Share Posted September 27, 2015 Nice. Can't wait to see it painted. Cheers, 1 Link to comment Share on other sites More sharing options...
tonyot Posted October 2, 2015 Share Posted October 2, 2015 Me too,.....I`m really looking forward to seeing this one painted up too, Cheers Tony Link to comment Share on other sites More sharing options...
