+++ FINISHED 06-09-2018! +++ Boulton Paul Defiant Mk I (Airfix 1/72 Dogfight Doubles)
Hi again,
The Eduard PE set for the Defiant comes with a fret full of exterior details (grids, wheel well and undercarriage detail and some other bits). Here it is, with some parts already off:
y4mHvpgEnPLbdprScWntu7ytO871MMBmjIHd2yR0
IMAG5615
The missing parts were grids for the radiators:
y4mchKsw0sX_5zCvIII3Xd9lQ-l5mjOskd8a9w-V
IMAG5602
y4m9diWjvcgSTKJVfZEBF6-uNhxcbbXpHCvB3Z5e
IMAG5603
These parts with grids go inside the radiator housing (plastic part C1). The radiator flap in plastic should be replaced by PE parts 50 and 43:
y4mWGX_w3BbDOj6cENWQiLxvMyoAKAX5dAZQJz6z
IMAG5604
First, I marked the cut lines with a nº 11 blade:
y4m7jYCfAwhtWavJudobn8LMac9WtG84Qboqsxby
IMAG5605
This area of the part was cut off with a mini-saw. The PE parts were also cut off the fret and bent to shape:
y4mOffme5424oGxnAOBf7Ze97wsZk2WNEWieymfd
IMAG5607
The parts of the inner mechanism of the gun turret were glued together and the corresponding PE detail for the gunner's seat was cut of the fret:
y4mUhKhrJVjRCpD9vYiXoeLSaTjnatGzGPMaNNbm
IMAG5645
Result:
y4mwNGdx95YDxVHXwjnVLhiL5RTGj_GuS-IuM-AI
IMGA5646
To be continued. Thanks for looking.
Jaime
Hi again,
A lot of the PE detail goes in the wheel wells, to improve their walls:
y4mSlFl2V5lDLLLFHELfI9RhjDKeoF5puPufPVrG
IMAG5617
It should be noted that the instructions show PE parts 44 and 45 wrongly positioned. These parts should be glued with their tapering following the tapering of the well walls, so the narrower end goes near the gear leg and the holes on the parts go near the area where the wheel gets stored:
Parts 54 and 55 are also shown upside down, as shown in this picture (look for the 4 screw heads on the bottom of the panel, just above the well door):
Here are the front panels already glued in place:
y4mZsxGvdQ0ArIWVWxByR2e6pW5wuGhiEPxMLWex
IMAG5618
The side panels:
y4mG0vfu8Eh91-Am1eDQpk37hcvwBWHDFgKgB1H-
IMAG5620
Here's the tool I used to bend the curved parts. These parts were first roughly bent to shape and then glued by sections in order to get the final shape:
y4mXRv1yr9GidBIvQcmFSnlVE1Sf9b3n2R4J2l13
IMAG5621
y4mp555Q13cvHWyROTH8CvnJcz1uqCl7c7kAT33j
IMAG5623
The straight panels were are glued in place:
y4muGAvciBNJIFQAfySG417xRvmg0ziPzHuB2_rY
IMAG5624
The mechanisms to be installed on these straight panels are made up of a PE part like this:
y4m9uWyYPtgWtGeBFHNF3oXKgRMGAroR0vOMTWf-
IMAG5625
This part was bent to shape in two steps, as shown in the following two pictures:
y4mc18-nyH2ItJ9-c-r6a6AzqWaxqHFuFooORB04
IMAG5626
y4mKyANzkH8ATCYmUFZYsxl9uuSixqkmIhnPopN8
IMAG5627
Finally, the parts were glued to the panels:
y4m9rbew4fEw8N2gG3N94TEWtx-LM4byKBGuHyue
IMAG5628
The work on the wells was concluded with the bits around the gear legs:
y4mHzVs7ol4kHSA9bDfEsfG6Pk0GYP6_V8KX4D26
IMAG5629
y4mi8y0rT46Iifx_QHbfN-oqmFl2khVDo_myyhtn
IMAG5630
The gear legs are not glued in place yet and still need to be cleaned from moulding marks and excess plastic from the sprue gates.
I finished this phase of the build by carving away plastic from the wing edge were the step board recoiled:
y4m2MDEfO_JxvAuPqnNk44WpCICE0HCoRAqnV0yy
IMAG5631
The corresponding PE part will be painted on the fret and glued in place in the end.
Jaime
Hi again,
Continuing with the updates.
The transparent parts for the wing lights were bathed in Aqua Gloss, to improve brilliance and transparency and left to dry for a few days:
y4m_NzKordkIo5ubw_4lgVBFtoPA_bZOWxNHx6KJ
IMAG5601
Then, they were painted silver in the back and interior green on the sides:
y4mVVJUxwEESI6Me92FDDcjwKxT5Dhzgb0AzoaqZ
IMAG5639
This was done so to simulate the real thing that can be seen in this photo:
The transparent parts were glued in place. Fit is not too bad:
y4mi9n1E874kaZeXYJFN9kjlt_5Q2XzPYIJ8tNW4
IMAG5640
There are PE parts to install around the lights:
y4mhnWTgFT50-g5mUQT9qbxD_nbIZIBDAgNvj_aA
IMAG5643
These PE parts were bent to shape and glued in place:
y4mWie6q0lk0UROOzvE5LH-rNzsOby4eA6HExgAr
IMAG5644
Jaime
Hi again,
This post should bring the thread up to date.
The kit has no detail for the navigation lights on the tips of the wing. However, these are quite prominent features, as shown in the following picture:
The inside seems to be silver or aluminium clad and the lights are green on the starboard tip and red on the port tip.
To simulate these lights, I decided to use a technique I first used in my Bf 109 G10 build, a few years ago, which consists on using pieces of transparent sprue shaped appropriately.
First step, was cutting off the tips of the wings, along the navigation light panel lines. This was accomplished with a nº 11 blade:
y4mXuJkzYfN15GpB9MdbBCAmna_ye1E-UTAyltOv
IMAG5632
Next, pieces of sprue were roughly cut using a mini saw:
y4mP8NEFbrEZrbbi8SsggSzixhZNUrl9mWgsNsTI
IMAG5633
I happened to choose a thick piece of transparent sprue, so I carved away part of the transparent plastic with a nº 11 blade:
y4mv4oKl4V4WljPD1cehnx0LBvlepQWp_Buxz-ZY
IMAG5634
As shown in the following picture, the pieces were still a bit large compared to the plastic pieces that had been removed from the wing tips:
y4mb-D7BJ-ysxKUV1k2-U5KARUp_yEPf9AveQM5M
IMAG5635
So, I reduced them further, sawing them to about half the size using a mini saw. The resulting pieces had now an appropriate dimension to fit on the wing tips and still have enough material to be safely filed and sanded to shape. But before that, it was necessary to simulate the navigation lamps. For that, I drilled small holes on the mating surfaces using a 0.5mm drill:
y4me9vbljdgdy_GI50bm3OYLn9vjFEnHnycy0UEH
IMAG5636
These holes were filled in with transparent red and transparent green, using a nº 0 detail brush:
y4mBjNFWDfkoFJCyG4XI8f-f0vQaTocwOJ9C_YXf
IMAG5637
Next, the mating surfaces were painted silver and the parts were allowed to dry:
y4mFWDmkD6igoW4_cFhUDg5jqTGW9hDg12OYemmc
IMAG5638
I used slow CA to glue the parts in place:
y4mcBLbbQf6LEcNW0Z_A_htiV7R8gaHmSv-PBCT7
IMAG5641
y4mP_E9mAvzrR7PKVnL65Qk8NFfWVAmLmLC7xOzP
IMAG5642
The parts were, then, filed and sanded to shape using, first, a small straight metal file and, then, sanding sticks of increasingly finer grain. Work proceeded slowly and carefully to ensure the proper shape was achieved. The following pictures show the results:
y4mPBiThzqZYIPzQB1yeyTd-AlWQlPQRAZr4IIkr
IMAG5651
y4mDbWN2HNLtFkUDMW2NxWhY6KvIcozRdEq1_DZW
IMAG5652
y4mbiGqK2S9krl0WxLFtNbxbk9moGUqSKe0lYpnQ
IMAG5653
y4mFTws3O6nbwZdvJ163vgyrxD0L3EiFnvpGndJ3
IMAG5654
The parts still had to be polished to become transparent. For this I used a set of micromesh pads of increasingly finer grain, and finished with a polishing fluid. Here's the end result:
y4muE9mfYWFRbCrrYj1Lfb20EKddEpj8zdvaiw_F
IMAG5655
y4myyVd5UdsmuB4PnIzloaMH3MfheZaVH6YlnAjK
IMAG5656
The wing can now be glued to the fuselage and the seams and joins can be taken care of.
That's all for now. Thanks for looking.
Jaime
Nice work Jaime :)
That PE certainly adds some finer detail and those scratched nav lights look 'the business'. Good job!
9 hours ago, CedB said:
Nice work Jaime :)
7 hours ago, stevehnz said:
Stunning work on display here Jaime. I've just had a catch up & much enjoyed it. Your wee curved mini saw intrigues me, whose is that? I can see a need developing there. :)
Steve.
Ced, Steve,
Thank you very much for your interest and kind words :)
The micro saw comes in a set of PE saws by RB productions:
http://www.radubstore.com/index.php?main_page=product_info&cPath=77_112&products_id=358
They're really good. I bought them on a recommendation by Ced :)
Jaime
Some really nice detail Jaime. You've put a lot of work into your Defiant.
Thanks a lot, Joe! Your kind words are always very much welcome :)
Jaime
Hi again,
I don't think I'll finish this build in time for this GB but I've been progressing and here's an update.
I finally glued the wing and fuselage together. The aircraft was left for a few days while the glue cured:
y4mcUGKU2R3UGgiwgnHbHCEKKe_2kpWPmKEfnDrG
IMAG5666
y4mZgdXhoYhcRCD8nDhEH9I7GS1l0yqqV1BayDoT
IMAG5667
In  the meantime, I did some work on the main undercarriage legs, as there were some PE parts to add. The PE parts are nº 55 and 61 in the fret. A bit on the left leg has already been cut off for installation of PE part nº 61:
y4mZbToMKL2yTOxIfnQBibs6J7NZ3K1gAWrBO4Yq
IMAG5663
PE parts nº 61 glued in place:
y4mDMOoZryyIhxd16YsEEEy59lmMnAe5h32CCNO1
IMAG5664
The legs ready. The break line will be installed in the end:
y4mv62mgAU7ARfASzWWqnqEGOIPHrNT8YUZXcLLC
IMAG5665
A few days later, the clamps were removed and here was the model:
y4mn-RFy3_2TJRgbVtS7HKBaEuQ21kgRMscnOzLZ
IMAG5668
y4mXzrmrJT1MapCh0HgEuu9LviyPk-xQqYlN4Pci
IMAG5669
There were some joins and gaps requiring attention.
The wing root on the port wing was a bit recessed from the fuselage:
y4m9Y24fo6FcRuf5V3Jiwd3W2k-Mc_q7F9U4BvcK
IMAG5670
The root of the starboard wing was better:
y4mE1wR8cGjVAd28ARbVNUz1_nwFqTiqKzi8R9uX
IMAG5671
There were some considerable gaps on the front of the wing-to-fuselage join:
y4mmYgHEbIpcw-yBflWOj9-2SOSA2qzRc0peVovs
IMAG5672
y4mBvHuD9x8-7oUESQeGVWDyE4GVtvozvbIVmlvf
IMAG5673
The back of the wing-to-fuselage join also needs some work:
y4mnUF89Rpjc1Dx9gNI8Jtp8EDGINGt4Scivfilf
IMAG5674
Before starting to work on these joins, I glued the rudder in place:
y4moe1Y0OyHBZsbBibvnJxKhm1-Rxb_VPea5k23t
IMAG5675
and the horizontal stabilisers:
y4mfcuelEwI0OQOcztEAkuCBEB4rA7Uqx5rtVk4I
IMAG5676
The alignment of tail fin and horizontal stabilisers is perfect out of the box:
y4mQCnwEtbf_DLQaDSpOkhqmHcmVFTN3vyw0Mviw
IMAG5677
Here's a top view of the model as it was at this point in time:
y4m_cuxQ17HW1S2jG8cS3DIGI1WZI00MA8nnqskL
IMAG5679
Jaime
I just tried the wing to fuselage fit on my Hurricane today and it looks about the same as your Defiant. I tried a bit of sanding but it didn't help much. Looks like I'll be using some more Mr. Surfacer 1000, unless you have a different, better plan.
Chris
  • Sad 1
2 hours ago, CedB said:
Nice Jaime. Your work with tiny PE continues to impress :)
Thanks Ced! The PE fret also includes replacement wheel well doors!
Chris
Sorry to know about that, Chris. I used thick CA followed by Perfect Plastic Putty to fill in the gaps.
Jaime
Jaime
All I have right now is the Mr. Surfacer 1000. Hopefully soon, I'll get down to Edmonton and have time to peruse the hobbyshops to see what else is there for thin putty/filler.
Chris
Nice progress Jaime. The undercarriage looks very detailed.
Thanks Joe! Yes, the PE bits from the Eduard sets improve the detail of the model considerably.
Jaime
Hi again,
The gaps between wing and fuselage shown previously were first filled in with thick CA. Next, I filed and sanded the problematic joins,  including the wing roots. In the following case, I had to glue a bit of sprue to repair some damage I did to the wing leading edge while filing and sanding the wing root:
y4mmanmjJLKOYAtxqxHviAKkLjRGN3iOrdlMAnEe
IMAG5681
It was roughly shaped with a nº 11 blade and later finished with sanding sticks:
y4m1RCcqJrYDkzDJZbVIEiweJc20jqTwMfAIxp7B
IMAG5682
After a lot of filing and sanding, I filled in the remaining gaps and scraps with PPP:
y4miSbbRKQWsqA2L0CrUsq0extUSRGMXTs1xibut
IMAG5683
y4m4832QZrEyy-7QWR3Z-fNmNC4ZUkk5o_oM0Bn9
IMAG5684
y4m9Wl6FGv5u5mHvW2PxSI0ORHt_wNbrDz4n68Gl
IMAG5685
I allowed the filler to dry for a few days. Then, it was removed using an old paintbrush moistened in water. This avoided further sanding and damage to the plastic but I had to be careful to avoid completely removing the filler from the gaps and scraps.
Next, I rescribed the panel lines that were not aligned across the fuselage and wing halves. I'll show, as an example of the technique used, the rescribing of the front panel line around the nose of the plane.
The misaligned panel lines had been first filled in with PPP:
y4mtbC-u-8XrspN4N4wo8g1Vq9bA_TaYaK98ctNS
IMAG5686
Now I used Tamiya's 2 mm contour tape as a guide for rescribing:
y4mEPmopLFZf-LEWN1DwthJkHfFsxTwet7wry2Xk
IMAG5687
After rescribing and removing the tape, the edges of the new panel line are a bit rough:
y4mySTB_iobtqbf__Qd_eXr9xHiw_4rjuS92l8BK
IMAG5688
To smooth the edges and clean the line, I used a bit of Tamiya's Extra Thin glue, as suggested in a recent build by Giorgio ( @giemme )
y4m_eVH7Mm3zhDbIGE0DXfTv8eM5nd22t165cVeC
IMAG5689
In the end, this is how the model turned out:
y4mPE5A0p4XgF1VdWN-aFuX8LFA7wD3sIxSvym18
IMAG5691
y4mJIHIhKa5dytkXFfQkTsbYeYE-cibLpN3FT8H1
IMAG5692
Some details of the problematic joins and gaps after all this effort:
Port wing root
y4m4AIgOR0v7RC245OvFTMIEDcZOx_vx6NlJDLIU
IMAG5693
Starboard wing root:
y4mzS7hoePXWZVAWK9BQocYB6Xq94TLA5dftgbXo
IMAG5694
Front wing-to-fuselage join: starboard side:
y4msEUjmz_UMtYVoAYreV3GVXv2aONYu1YzOefen
IMAG5695
Front wing-to-fuselage join: port side:
y4mVp0zJkOuXYNOG0yKyfeNZ1Qo6wE7FIHZupFPn
IMAG5696
Back wing-to-fuselage join
y4mqkhZ_yAl-rynwjaqwKOuXRvbOp8mWnx7XgfgP
IMAG5697
Leading edges of wing around the fuselage. The vertical panel lines and the curve shaped panel lines on the wing roots were completely rescribed.
y4mLE8x0fg4bq3n7tSSRXpy1NjxxkGUNr_Knbxtv
IMAG5698
Jaime
3 hours ago, CedB said:
Nice filling Jaime, looking much smoother :)
Thanks, Ced! Filing and sanding joins and seams is always a very boring phase of the build but all work invested here results in a better looking model.
Jaime
Hi again,
As usual, this thread is again way behind the present state of the build and, of course, wasn't finished before the deadline of the RAF Anniversary GB. I'll try to bring it up to date in these and the following posts.
After taking care of all the seams and joins, I did some work on the remaining small parts.
The propeller parts were removed from the sprues:
y4mNOESutVTpoSRnNDSFu1SGRN3zUaDf_UZMhN39
IMAG5699
and glued together:
y4ms4UxkPe8zcu0tAHp-oQoYZnIPdbpTFxgWgPME
IMAG5700
The following parts are used in the interior of the gun turret:
y4mf62253hFgn4IW3flEnO26r_9tnL5wUIGFuW20
IMAG5701
The raised detail on part 9 had to be removed, Later, it will be replaced by a PE detailing bit:
y4me-dq5YUPTzikRRa2XeNDF0JJ28yYafXlO5q5i
IMAG5702
The guns were improved by drilling holes on the tips:
y4msDloRbGFRTWA1A89p5OCoB1OaEhnS7MnrTENG
IMAG5680
The same was done on the exhausts:
y4mXRbb2cGH5kh0bPM_dWySjcZoWPJVJ0GJB-Nd9
IMAG5703
Next, I had to add some detail to the port wing trailing edge, near the wing root, where the step board recoiled. The following picture shows a slight indentation on the edge:
K3zrRqUq.jpg?0801
This is the result after cutting some plastic:
y4mAxB4kvaqTLUG1r47KcBw8pXYmmnj5Trh2zdhn
IMAG5704
y4msTBzVdc8q-YldLXk3UZ6-Fzq0EIhLxbAyza1I
IMAG5705
Next, the instrument panel was glued in place (again, as it was knocked off in the previous handling phases), as well as the wind shield and fixed part of the canopy behind the cockpit.
y4m6nucgIXvmoNA56ei55zD6nHXft9iWS4QngNNN
IMAG5706
y4m-MLrKCTSY-f9bBhpab628H9h84Gb2pLch_2kF
IMAG5707
There were still a few PE bits to add before starting the main painting. First, two plates for the port wing (nº 40 and 41 in the picture):
y4mmf64st3VqSgO9thhSfq-NQfjf9wn2nupHzx9x
IMAG5708
Here they are, glued in place:
y4m-EqN4RnoqEgSYDL7VMyLfdOPxRg-wZzrrN2PK
IMAG5711
And also PE part 60:
y4mGY8WrRJHqP4RkuZWLdI8Pz8l6CqNDrc6gDmwX
IMAG5709
which goes on the leading edge of the starboard horizontal stabilizer:
y4mMPW1-25D3VLvCDeiExYLJwyjTZ7Tt2sgRqgEH
IMAG5710
I decided to paint the PE wheel well door parts still in the fret, to avoid any risk of accidental bending, but there were some small parts that could be glued before painting. One of those can be seen just below the PE doors, ready for gluing:
y4mEADwNFDuI1EK2m2oEHU2K6OsltmaKAocxCy2R
IMAG5714
These small parts were glued in the center of the inner faces of the wheel doors, as shown here:
y4m6EJ3xcvmfndeFJK0DBTuByj5UL-LV5DAoRdoY
IMAG5715
I still had some masking to do. I applied masking tape to the mating faces of the radiator and carburetor housings and the underside of the wing:
y4mt-fXDvWfxfyWull7a6XiZYQ58QAM79AiSG_7R
IMAG5712
y4msNhgx7C4TlhHhItSM2Vslw3WajFwkALv2gNhh
IMAG5713
Cockpit and turret openings were also masked:
y4mjFJg86tfpHto1dNLsugnBKpAxrXCSRPh7W2tG
IMAG5717
y4mt6RisK5fTSP_vtNJr2L9A2g3jFd1y8dly9q2P
IMAG5720
A last small detail that I added was a metal shaft on the port side of the fuselage, between the cockpit and turret, which can be seen in the following original picture and was used to help the gunner climb to the turret:
Boulton_Paul_Defiant_gun_turret_WWII_IWM
I did it with a piece of 0.5 mm evergreen rod, slightly filed on one of the tips:
y4mAw1kQfkw5SBP_TyN8PbWIJPUzSx-MX9YkpbeC
IMAG5719
Finally, all the small parts were readied for painting:
y4mz8Bd-78RkoPsntN8too_6lhwz8yREFydTNVIf
IMAG5718
Jaime
14 minutes ago, stevehnz said:
I can see a stunna in progress, nice work there Jaime. :)
Steve.
Thanks, Steve! I hope it lives up to the expectations!
Jaime
Hi again,
Continuing with updating this thread.
I was ready for starting the main painting phase. I took some decisions regarding colours and weathering which determined the primers to use.
First, the propeller has yellow blade tips, the rotor cone is mainly white with a black ring nearer to the fuselage and the blades are black. So, I decided to use Alclad's white primer as the first coat (as white for the cone and base primer for the yellow tips) and Alclad's black primer for the black areas. The black primer will be used for almost all other small parts and the model, in order to provide some form of pre-shading, so it spares me the need of using matte black paint for the propeller.
The only other exception will be the main gear leg parts and pitot tube. As I intend to use Alclad Chrome, which is a high-shine tone, for the "olios" and pitot tube, I'll have to use Alclad's gloss black primer instead of the regular Alclad black primer.
So, here's the propeller after application of white primer and yellow on the tips:
y4mtg4TDvvzw0wjfbLb9W96aPPcjE-YAUohYKMsA
IMAG5721
The cone and tips were masked:
y4mjMyksGzKv3CA-3aT90x6uoSVNGc7QWVtJTtvT
IMAG5723
The black primer was applied and the masking removed:
y4mawf59TxHRzoFzm37-rPpJHxje35mUUezpTGIg
IMAG5724
Before applying the black primer to almost everything, I applied gloss black primer to the gear leg parts and pitot tube:
y4m1vUnLl8K51fuLhVq0Og8-UWq3P6xLpT0WF9cI
IMAG5722
The regular black primer, as said before, was applied to the model:
y4mbacxCOYnLT6K57GDU0noK6FOoiuTp1XacQNWQ
IMAG5725
y4mEq74uykJOBEMEb5fmIfyIotIrtNkqMOOztu7K
IMAG5726
to the PE fret, on both sides:
y4m9Y0W5FETzvqpNYevZpXOhjD01pmGjYDktckg1
IMAG5727
y4mNpPEJtlVtS-8AYL9WBOm3KCVzOdtgncaxQx2O
IMAG5728
and to all other small parts. Here we can also see chrome already applied to the gear legs and pitot tube:
y4mrDwMC7dbB4pcKQK-4EmexxUBXgJkEMWkJu2Uh
IMAG5729
The following pictures show how the joins and seams turned out, as revealed by the black primer.
Port wing root:
y4mvZToSvOeSFAxMTMEySH2cRRHecgppy837Ui3n
IMAG5730
y4ml2Zn5eDYDyoClSRUab8d_ez5DkKveUgiwqQSY
IMAG5731
Front joins between fuselage and wing:
y4mAc7FIGPQ93HpXxXbzB_WOluf1i4MQtUNQ4Zbd
IMAG5732
y4mkKpmANY5QC0cU0UIT7ijoG6VLeB4NYoDbYM_X
IMAG5733
Back joins between fuselage and wing:
y4mdKumTAb-5Npzv5MEvu6PeL0nQRHLJucYExVf3
IMAG5735
It seems all the effort I put in taking care of the seams and joins and re-scribing misaligned panel lines paid off.
Jaime
