Hello all,
This is my rendering of Spitfire Mk XIV of the 91 Sq, RAF, West Malling (codes DL-F, NH698), flown by Flight Officer Kenneth Roy Collier of the RAAF, as it was on D-Day, 6 June 1944, and the following days.
Collier became famous when, on 23 June 1944, tipped a V1 flying bomb with the tip of his Spit's wing, making the bomb lose directional control and crash on the ground, without hitting its target. This technique was then adopted by other pilots chasing flying bombs.
On 5 December 1944, Collier was shot down and killed in a dogfight with FW190s and Bf 109s over Germany. He rests in the Rheinburg Commonwealth War Cemetery, in Nordrhein-Westfal, Germany. This is a small homage to a brave young man.
This model was built OOB, with the exception of the seat belts (made out of Tamiya tape and aluminium wire) and the bar on the cockpit access door (made out of stretched sprue). I also rescibed some panel lines missing on the aft of the lower wing part. The D-Day stripes were painted. The WIP thread is here.
Here are the final photos.
General views:
y4mxLcBmBkGM7qWxhRiC1QSe3ENIbu-XrUguCCvL
y4mxA0yz4r7pLTOP0nrk5Q5ms1v_YgFHqUyQ6rX8
y4mUbMzRJIYlqSyLxeMQ2I_f90vFWgMyO35JQEk1
y4mdz7qBaoOP1gufHpQxegCDqiejQ_yvnNWeyOrX
y4mM-W4Msuh0eGSkdXc_UauQ2htT0HYM_7C-d6pM
y4mDgdQ2WDnPiXtsoym-SqdNkG60szNzjnt9EZJ5
y4mfBq3cUmQoPHxxvVma1WvxTS8hb8Tig75dAMRN
y4mN_FcDUjd2u3dCMWrwmqW-ShkXCocwB-6-kVfN
y4mh7ARy4iv63QUGzGCZW7TaAHbo1n7tdzkV0-Mf
Detail views:
Port wing's upper surface:
y4mBd85DWuaHrKbWV0_Vy3BpIzGXlitIRYzOyxg7
Starboard wing's upper surface:
y4mxoVwj0MPmavVbFGvHy4KRsc8wS0dPZL2ZX9Bn
Starboard wing's under surface:
y4mvHa8-GYGmyWw7Xn-LLt5631zGsAyJf4bzbIUl
Port wing's under surface:
y4mFvZFRJvPQNL0ypWXe-U-a5HWDqqi-MXuUGVlR
Belly and wheel wells:
y4m3_SPhiLZu2FBTijFoAZDw3m7u1gkdsj6E33AJ
Landing gear:
y4mWJ8X_Z5ASRvDMjpxJrzpy8lVr5hduAzk54nXJ
Cockpit:
y4mtKIUI5jOUp4KHTb_G2Ej-0DpKMGz_uFSSiSnX
y4m052xLoRN7MAxrnblvkPAlliWlG8vZXjvXmeJq
y4miDEaeazDFHfJ3iVsgjfCh62qw44z1j74hk7U_
I hope you liked it. All comments are most welcome.
Thanks for looking.
Jaime
  • Like 26
Thoroughly enjoyed your WIP for this and it's resulted in a beautiful Spitfire! Well done. :thumbsup:
Knight_Flyer, PlaStix, thanks for your appreciation :)
I followed the WiP and the end result looks fantastic.
I've heard the Academy MkXIV described as a Spitfire that's been at the doughnuts... but stripes certainly have a slimming effect.
Superb Spit, especially considering it is 1/72. Great back story too.
Wonderful finish and I enjoyed the wip as well, a great looking Spitfire,
Sean
Thank you all for your kind words and interest :)
Thanks for the nice words, Dave
Rob, batcode, thanks for your appreciation, it means a lot
Thanks for the kind words, Val
Great looking Spitfire , although some of the detail could do with reworking
The seat harness is way way over scale and the cockpit hatch looks like a house brick .
Correcting these would make a lot of difference to the finished model , everything else looks spot on :goodjob:
This is how I like modelling,good research and a "snapshot in time"historical finish with a great tribute to a
very brave young pilot.
Excellent stuff.
That Academy Spit sure has got a big oversize nose though,as has been said,it's the Spit kit
that's been at the doughnuts..............
Such a shame because it's a nicely moulded well thought out kit.
Edited by Miggers
Keith, Miggers, Greg, thanks a lot for your appreciation and kind words.
Thanks for pointing out those improvement areas.
I agree that the harness is too big. At the time I only had some rather thick aluminium wire. In the meantime, I managed to find some thin electrical copper wire, which looks better at this scale (You can see an example in my recently finished Bf 109 here). I may try to replace the harness in the Spit later, but now I'm a bit busy with the Phantom GB. :frantic:
Regarding the hatch, I'm afraid it is OOB and if its out of scale, so are the cockpit walls and canopy frames, which are as thick as the hatch... I will leave it as it is but will keep a note on this for future Spitfire builds
Excellent stuff.
Thanks Miggers, I always try to research my models as much as possible and am very interested on the human factor behind the machine and the historical context.
Regarding the nose of the Spit, this is Mk XIV, which used a super-charged Griffon engine, instead of the Merlin engine used in most previous Marks (the first Griffon-engined Spit was the Mk XII, and this was not super-charged). The new engine needed a 3-foot longer nose, with bulges over the exhausts to accommodate the engine's cylinder blocks. The Mk XIV also needed a five-bladed propeller and a bigger tail fin and rudder to enhance directional stability, due to the increased engine power. Maybe this is why some people refer to this as a "Spit on doughnuts"?
I used this diagram as a reference during the build, as well as pictures that can be found on the net. The only correction I made was scribing some missing panel lines aft of the lower wing part, but it is possible that there are some other inaccuracies.
Jaime
Edited by jrlx
Jaime
The XII had the single stage Griffon(Mk.VI sometimes referred to as the "short"Griffon).
The XIV/XVII/XIX all used the 60 series two stage two speed supercharged Griffon,hence the longer nose.
The Academy kit is referred to as a Spit on doughnuts because from the aft frame of the cockpit(the seat frame)
everything is way too wide for a Spitfire.
The radiators should also be perpendicular to the wing and not the ground.
Every Spit/Seafire should be the same dimension from Frame 5(the firewall)back to the rudder post.
Lord knows where Academy got their info from(that diagram you've linked to looks favorite,the rear fuselage top line
should be virtually straight).
Get your hands on an Airfix Spit XIX in 1/72nd,you'll see what we mean...............
Edited by Miggers
Miggers, thanks for the clarification and information in your post. I thought the complaints about the kit were due to nose inaccuracies but I now see what you mean.
Jaime
Jaime
You're very welcome Jaime.
Anytime you want to know about Spitfire/Seafire kits or the real thing,just shout up,there's quite a few of
us on here that are quite passionate about R.J's most wonderful aeroplane.
