Sign in to follow this
AndyC
1/72 Revell Tornado ECR - Tigermeet +++FINISHED+++
My entry for this worthy GB is one of Revell's little 1/72 multi-schemed Tornados - this one is the ECR Tigermeet 2011/12 version
Box shot
And the contents with a very nice looking decal set
Love these kits - I've already built 2 and have another 3 in the stash
I've had a major PC "outage" for the last 2 weeks and have not had any means of posting which has driven me mad! However here is a massive update of where I have been busy on this GB now that the sick computer has been mended!
Primed some of the parts before taking them off the sprues
Cockpit interior sprayed Medium Sea Grey and kit decals applied. Seat also in the process of painting
Cockpit almost ready and seats done
All buttoned up with the coamings in place and painted
The rear fuselage all dry-fitted together with the the nose structure
The wings are glued and are being readied for fitting inside the rear fuselage. The pylons will be CA'd in place at the end rather than glued within the wings. This will ease painting.
All glued together and clamped to dry
That great big fin glued and fixed and along with the nose structure...starting to look like a Tornado now!
The dangly things are worked on now...DT's and HARM missiles
Filler applied although to be fair the fit isn't that bad
All rubbed down and ready for a final check before the canopy is in place (this will be closed). The tailpanes will be fitted after painting...again for ease of decals and paint.
Canopy masked and glued with Gator glue
Into the booth for a prime with Vallejo Black Primer...wonderful stuff...next will be the u/c doors and legs and all the underwing stores
Apologies for the compressed build and thanks for looking. All comments welcomed!
A quick update as everything has been primed now.
The usual confusing Revell colour call-outs "30% this + 70% that"...fortunately there was a reference to FS36320...which is Dark Compass Grey so that was sprayed on using Xtracrylix
Took the masking off the canopy - looks OK.
Next job is to mask and paint the nose cone and then a thin sprayed line of white at the forward bottom of the fuselage edges. Mask off the wheel wells and paint them light grey.
A bit of masking to the drop tanks and then I can probably start decalling...there are 'undreds of 'em.
Ta for looking
Finally getting round toward decals...
The instructions call for some white sprayed at the bottom edges of the fuselage, so a small strip of Tamiya White was sprayed. The nose cone was also sprayed NATO Black
Started on the decals - lots and lots of them on that huge decal sheet. I did the 1/32 Tiger Tornado a few years ago for the last GB. It's best to find a datum decal in this case the decal immediately behind the cockpit. Get that set and everything flows from that...
Pretty much completed the main decals on one side - they are Cartograf and are very thin but strong. I've used some Micro Set on them and they've settled down nicely.
Will finish these during the week. I've got some painting to do on the D/T's and then once they are all done I can get the wheels on and should be finished fairly soon,barring disasters. All comments welcome.
A quick update...
This is taking a long time :frantic:
I can only do the decals in short bursts because I'm having problems pickking up the model to apply new ones without disturbing the ones already down, so I have to give the Micro Set time to work...Anyway, after4 days of decal sessions, she is finally looking something like the box lid!
Tricky areas are the IFR probe (and I should have learnt from previous builds to have left that off) and round the nose, where I've had to touch up some gaps. Also the fin will need some touch ups where the decals don't quite meet - Tamiya Black and Purple should do the trick there
Definitley my most colourful Tornado yet!
Yee-hah!
Sneaked in just before the witching hour. Thanks for the comments. I'll put the final pics on the Gallery and may also do a general RFI
