Using decal setting solution to remove old decals?
cmatthewbacon
So, I've got Microsol and Microset, and some Daco setting solution. How do I go about removing old decals? Make a good puddle on top and leave it for a few hours? Or am I better off with sellotape? Any tips from anyone who's done it much appreciated!
Bestest,
M.
I've always just wet sanded them off using a fine sanding stick and plenty of water - but Im assuming you want to keep the surface finish beneath intact - so that may be a non-starter?
I've tried tape too - but find it frustratingly inconsistent
Jonners
Setting solution doesn't seem to have any effect on decals once they're set in my experience. I'd be looking to sand 'em back & repaint, although I might try some strong tape, but then you run the risk of ripping off the paint, especially if you use acrylic. :S
  • 1 month later...
In the past I have used a pin to score the surface of the decal and then applied softening solution. By breaking the skin of the decal the softener can penetrate and start lifting off the decal. Then slide a soft brush underneath and prize away...
