++++FINISHED++++ The other Tims - Italeri 1/48 Tornado IDS - GR1, Op Granby, ZD851/AJ - Tabuk Tornado Detachment, Saudi Arabia 1991
Will be looking at my normal 1/48 build too (may be on the drag with my F4G to finish and the 1/72 Tonka, plus a couple of cheeky work deployments to fit in around a family holiday!)
Have not built any Gulf aircraft, so nows the time.
Am thinking of ZD790 or ZD851 as I have the decals.
I could place ALARM missiles onto AJ as I have an Airfix 1/48 F3 that has them in the stash!
Some great Gulf War Pics here
http://www.britmodeller.com/forums/index.php?/topic/45266-gulf-war-tornados-reference-piccys/
09B15720-8740-43C5-BADB-21719E1CB970_zps
B48F492D-533E-4F9A-B55C-4A4444248ABD_zps
Sprues have now been washed - will source 2 pilots gor my normal in flight finish (maybe from the Airfix GR4 in the stash!)
Edited by Tim Moff
  • 1 month later...
Now that the Revell 1/72 is awaiting Mr Color DG paint and my F4G from the phantom STGB is now finished here I have kicked off this build.
On first glance the kit and build look quite simple - yes there are some inaccuracies (anyone who has followed any of my WIP's knows that I ain't too bothered as long as it looks like the subject!) and some parts are simplified (engines cans area, Swing Wing sleeves, weapins could be better etc).
However, having just looked at dry fitting etc, the fit seems to be a right pig - some more in the pics further down!
Well, I will get on with it, Desert Pink can and will cover up no doubt a multitude of sins!!
To start, I decided to get all the major components of the sprue, fettle/sand where needed, dry fit and glue. As I said the kit is quite simple build wise I spose.
I stole 2 x large tanks from the Airfix F3/EF3 kit I have, as well as 2 trusty aircrew. I will also be nabbing the 2 x ALARM missiles later (when I can find the instructions!!) as well.
Once everything was ready, I primed with my trusty Halfords grey and set aside to dry.
Before my hols I will try to get the pit started and the aircrew looking ready for action.
B7DFBEAA-2580-4422-87E9-F375FF5B8F15_zps
This kit was defo not designed to be built airborne, some of the airbreak gaps and gear door gaps are crazy!!
9259F4DA-1A29-4244-8DFE-E2797F2F8D70_zps
94814ECB-BC19-46AD-A9FD-0FD6FE050F5A_zps
8764412A-116E-4A5C-AB05-6AA06DA73FBD_zps
361824D0-7A8F-439B-9425-70B764E52A34_zps
apologies for the focus of my IPhone - but you get the gist!!
Some references found on the net:
http://www.globalaviationresource.com/reports/2011/gulfwar20th2/images/13.jpg
Tornado%20GR1%20ZD851%20AP%20Amanda%20Ja
I will paint the tanks desert pink as well, was looking to paint them as per the F3, but the references show otherwise.
Looks like a horror fit wise. As for the fuel tanks, I am not sure when the would have been painted pink but I am sure that they would have been grey when first given to the GR Sqns. I will have a more detailed look later, but I have just found a picture of an Alarm toting GR1 (dose not say which one) with the Pink paint coming away from the nose area exposing the grey underneath. Also have you had a look at dstorm. eu, as this site has a wealth of photos of Gulf aircraft.
Thanks Jabba.
Yes the pics of AJ above indicate they were desert paint covered at least towards the end of Granby, which the decals represent.
Have seen lots with grey tanks from the trg phase before the conflict started.
Will try to weather the ARTF pink as all the airframes looked very worn at Endex.
Will do my best with the build, then paint over/weather any 'issues'!!!
Managed to get some pit-painting started last night, will dry brush and add some colour too....then finish the crew off:
6A1F6A9A-4BD4-4B88-9BB5-3DB6766F5EE5_zps
Need to paint up the seats - not great but will try to colour as per the MB MK10A, pilots will be in em anyways...
9A1FEEFA-9269-4E26-961C-2279F80F6BC9_zps
just need to finish off the pilots before I see what 'surgery' they will need to fit in!
C2730752-8557-4EA5-B371-6C6F3D22CA0D_zps
F25EF65A-D252-4DE8-A5D7-E056FDDDB7C2_zps
Handy page for GR1 cockpit references etc:
http://www.jetartaviation.co.uk/2014/02/tonka-norfolk-land-shark-the-mighty-fin/nggallery/page/1
I do have pictures in one of my Tornado books that does show one of the Alarm aircraft with one grey and one pink tank fitted. Will let you know which one (book) when I get home tonight.
Squeezed some more time in today, detail painting the pit etc initially.
B93F175F-03CA-4B4A-A28C-7213389A2A01_zps
The 2 aircrew suitably prepared - no doubt have typical RAF names like 'Ginger' and 'Sandy'... :bleh:
58C607F6-15F5-4CF1-82BC-7DDE22383364_zps
73BB2ED3-BC7E-4BBD-8835-32451A3E4FA6_zps
Instructions said to paint the panels black, on looking at the references they were the same grey, so I re painted and added a dash of colour here and there.
5AF0FD53-39BE-4A5E-8E8A-F00CE461A5BD_zps
34C39BFB-BCA6-4E02-8A1B-3AD2CE699FFF_zps
4F4E6789-4A1C-4177-8273-0EBA15D6F874_zps
E77E9C49-BB6B-4902-A8C2-7D92C8D6BB7C_zps
A bit of floreys to dirty up the pit (although I am sure that Messers Ginger and Sandy ensured the lineys kept the place suitably RAF clean!!
Got the front parts together, aligned ok:
AF09E0D0-86A0-46CB-8ADE-15B9B4409825_zps
3153F216-EDA5-4D3F-89D4-7523E86127DB_zps
737ADAB4-B331-42C4-9DFD-50AED65D3829_zps
A bit of filler and sanding to get rid of the obvious seams as best as possible.
0FDEE6BD-24B9-434D-A09B-359ECDFA2F53_zps
Talking of seams - it appears I was not put on this earth to do seams...I never seem (pardon the pun!) to erase them totally? I add some filler, coarse sand, light sand etc....not sure where I go wrong...anyways thought I would give the 'Big Jugs' a pop and the Boz/Skyshadow pods.
AED0ED80-60B8-447F-90A6-3FD34B99002C_zps
Painted up the engine exhaust areas, initial coat of a mix between Humbrol 27004 Gunmetal mixed with some Revel silver.
I then dry brushed on some Xtracolor exhaust, Xtracolor burnt Iron and some Hum 62 leather to add a tinge of brown/rust seen on Tonksas:
Just playing around really, came up with this:
7D0C7007-D89B-496A-96C4-947FC73B1484_zps
CC24B251-FEA7-4D2A-8913-0196448F27FD_zps
329FC4F8-4B6F-4B80-9586-20F81A1FEA2C_zps
from this!!
3CA22563-6092-4135-891F-9DEB8398397C_zps
Got the wings sorted:
20E7DB5C-028E-45EF-AF4B-583FC11C8B0B_zps
Also filled and sanded the horror gear doors and airbrake areas.
Any top tips for the swing wing area?
This kit has absolutely nothing but a gap!!
So any clever ideas, work arounds gladly accepted!
A productive session, starting to get along a bit now - bit of a break for my holibobs! :drink::frantic:
Edited by Tim Moff
I have had a look in my Tornado books and I am now a bit confused. Both of the pictures that I mention are in the Tornado Multi Role Combat Aircraft by Jon Lake and Mike Crutch. The aircraft shown on page 96 shows it with 2 fuel tanks one grey and the other pink. But the confusing part is that the Ser No that I can make out is ZA411, which although being painted pink and carrying 2 Alarms from my records did not go to the Gulf. The other picture on page 97 show an aircraft with 3 Alarms is fitted with 2 grey tanks. From what I can make out it is carrying the tail code of either AG or AC as the dirty on the tail and the angle of the aircraft in the photo does not make it that clear. If it is AC that would make it ZA739 which was a TIALD aircraft, whilst AG would be ZD893 again not an Alarm aircraft and it crashed on take off on 20 Jan 1991. So sorry to say although there are some pictures of what you are looking for (although not Amanda Jane), and not (from what I can make out) Alarm carrying aircraft so this may not help you at all.
Thanks - looking at ZA893 it is listed as an Alarm aircraft from the RAF records, but as you say crashed early before the first missions: http://www.raf.mod.uk/history/RAFbaseslistduringOperationGranby.cfm
The pics I see look as if AJ had 2 x pink/desert tanks....however I may take some artistic licence!!
Listed by location are the bases used by the Royal Air Force during Operation Granby and the aircraft at each location.
Saudi Arabia
Dhahran Royal Saudi Air Force Base
Lead Squadron
Aircraft Type
Tornado GR1 and GR1A
Tail Number/Name
ZA370/A (GR1A)
ZA371/C (GR1A)
ZA372/E (GR1A) "Sally T"
ZA373/H (GR1A)
ZA374/CN (GR1) "Miss Behavin'"
ZA376/- (GR1) "Mrs Miggins"
ZA397/O (GR1A)
ZA400/T (GR1A)
ZA403/CO (GR1)
ZA457/CE (GR1) "Bob"
ZA461/DK (GR1)
ZA490/GG (GR1) "Gigi"
ZD707/BK (GR1)
ZD715/DB (GR1) "Luscious Lizzie"
ZD719/AD (GR1) "Check Six"
ZD740/DA (GR1) "Dhahran Annie"
ZD745/BM (GR1) "Black Magic"
ZD792/CF (GR1) "Nursie"
ZD843/DH (GR1)
ZD847/CH (GR1) "Where Do You Want It?"
ZD895/BF (GR1)
Tabuk Royal Saudi Air Force Base
Lead Squadron
16 Squadron
(RAF Bruggen)
Aircraft Type
Tornado GR1
Tail Number/Name
ZA393/CQ (T) " Sir Galahad"
ZA406/DN (T)
ZA446/EF
ZA447/EA " MiG Eater"
ZA452/GK " Gulf Killer"
ZA460/FD " Fire Dancer"
ZA465/FK "Foxy Killer "
ZA467/FF *
ZA473/FM "Foxy Mama"
ZA492/FE
ZD719/AD (A) **
ZD739/AC (T) "Armoured Charmer"
ZD744/BD "Buddha"
ZD746/AB (A) "Alarm Belle"
ZD747/AL (A) "Anna Louise"
ZD748/AK (A) "Anola Kay"
ZD810/AA (A)
ZD844/DE (T) "Donna Ewin"
ZD845/AF (A) "Angel Face"
ZD848/BC
ZD850/CL (A) "Cherry Lips"
ZD851/AJ (A) "Amanda Jane"
ZD893/AG (A) ***
KEY:
T = TIALD CAPABLE
A = ALARM CAPABLE
* = Shot down on 22 January, 1991. Crew killed.
** = Later to Dhahran
*** = Abandoned near to base due to control restriction on 20 January, 1991. Crew ejected.
Looking at paint - HUM 250, Xtracolor X032 or Tamiya XF57 Buff - any comments/advice?
Tim whenever I paint a Gulf British aircraft (and I have done a few) I always use Hum 250 and add white to it to whatever I feel is right. I know that the colour is a little on the dark side straight from the tin, but adding the white gives it that faded look that the aircraft had after being under the sun for quite a while..
the 3 phase fuse has been completed!
Some filling and sanding to do, not long and construction will be completed.
Phase I + II
65050C45-437E-48C0-8B6E-C5E766375723_zps
973C502E-AFBA-47F0-A7C4-6FD953B8E65D_zps
AF4E1A3A-F2D1-4F97-B06D-14C89C55775B_zps
Phase III
5C476E29-E428-4923-AA01-19E890A80656_zps
50DD9EF2-D0FD-4566-B4B2-431FFFE0EDFE_zps
2D92E201-6344-4E94-9AC9-13C095D183DC_zps
Edited by Tim Moff
now I am getting there I am torn between Hum250, Xtracolor X32 and Tamiya XF57 for the RAF Desert Cam.
Any advice?
Was going to do 1 Big Jug tank grey as per F3 and the other will use a different paint to the main body as I understand it was a local purchase and hand painted on 'in-theatre'.
What colour were the F3's Big Jug tanks - were they MSG or Barley/Cam Grey then?
69F92BB2-D3FE-4B99-ADDA-980533E8D875_zps
Edited by Tim Moff
I agree with Hum 250, but do add a bit of white as the colour straight out of the tin replicates an aircraft that is fresh from the paint shop. As for the fuel tanks looking at the instructions for the Hasegawa F3 at the moment and they state Barley Grey, or whatever that is called now.
I have just had a look at the Aviation Workshop decal sheet for the "Tornado at War" and this states Camo Grey which I think is the same as Barley Grey.
Got the mighty fin on, had to a bit of filling and sanding in places, binned the idea of wing gloves, wings will be swept and I have bashed this kit into a reasonable shape enough!!
Dipped the canopy so need to mask it and get it on. Soon be time for priming!
6C562A10-3241-4110-B10C-2F3604B896B6_zps
9C1B09C0-563D-4C72-B374-D7990BE48D80_zps
Some work over the weekend.
Canopy masked and on with Chrystal Klear:
F9451AEB-169B-4562-9914-30B90ADB26C4_zps
Remembered to paint the frame black for 'inside' appearance!
06B12D95-FD1E-4830-8ED2-CF690E065314_zps
D1FDCB35-3019-474E-B8A9-6451852774FC_zps
Halfords White Primer on - thinking is that when I pre-shade there will be more contrast options for the Hum 250 (with a couple of drops of white) when it goes on - well other guys on this build have, so I will heed their advice!
90EBE8A8-1329-4DC2-8F3E-F94D874048B7_zps
7C551F5A-DECB-4A14-A6F6-CB16086400BE_zps
couple of seems/filler to tidy up then ready to pre-shade.
