alex 1,190 Posted June 6, 2015 Share Posted June 6, 2015 Good afternoon, I started my project, I will build a nr. 2 squadron Tornado. Decals are from Model Alliance, along with some PE-parts from Eduard, which are intended for hasegawas ADV-Tornado. I'll use whatever fits and looks good. And I also have two pavla bangseats. Alex 5 Link to post Share on other sites
Hockeyboy76 8,895 Posted June 6, 2015 Share Posted June 6, 2015 Good choice. Anything looks cool in a camo wrap. Link to post Share on other sites
AnonymousDFB1 2,743 Posted June 7, 2015 Share Posted June 7, 2015 Nice one Alex Link to post Share on other sites
Tim Moff 4,107 Posted June 7, 2015 Share Posted June 7, 2015 (edited) Check the scheme in the group thread - I was looking at doing this too, it appears the mode alliance l graphic of Port Camo has the colours incorrect, should be switched....gazumped again! Make have to go for the saint! Good luck. Edited June 7, 2015 by Tim Moff Link to post Share on other sites
alex 1,190 Posted June 11, 2015 Author Share Posted June 11, 2015 I often start with the ordnance (just a strange habit). It will carry four 1000lb training bombs, along with small tanks, two sidewinder and the usual sky shadow/boz. I have noticed that the training bombs have one groove less than the live ones (guess because of the missing detonator?), so this had to be filled and sanded. The Boz has been opened at the read end. It will get the interiour later on. Cockpit parts have been airbrushed with humbrol medium sea grey. I cut away the pedals, as they will be replaced with PE parts. And that's how the cockpit looked this morning. Floor was a mixture of leaf green and black (revell acrylics, paintbrushed). Instruments are painted with revell acrylics, mostly black and some yellow. I am a bit proud of the pilots warning lights: first I did a wash with highly diluted red oil colour (to fill the recessed lights), then a drybrush with grey, and in the end a washing with brown/black oil to bring out all the details. For me, it works better than trying to paint all the details. No resin, no decals. Some details like the cables or displays are still missing. Resin seats will be from pavla. @Tim: thanks for the tip, I'm following closely! Alex 5 Link to post Share on other sites
Hockeyboy76 8,895 Posted June 11, 2015 Share Posted June 11, 2015 Looking good. Link to post Share on other sites
Jabba 4,686 Posted June 11, 2015 Share Posted June 11, 2015 Very nice indeed. One thing though don't forget to paint the TV screens on the Navs panel either side of the circular screen. Link to post Share on other sites
alex 1,190 Posted June 13, 2015 Author Share Posted June 13, 2015 Rear cockpit parts finished... completition starts. Please note the etched pedals - you won't see them anymore after the cockpit is finished... Nose gear leg shortened a bit... And the main gear bay. Just added a few things, boxes and cables. Alex 3 Link to post Share on other sites
AnonymousDFB1 2,743 Posted June 13, 2015 Share Posted June 13, 2015 Looking good Alex Link to post Share on other sites
Tim Moff 4,107 Posted June 14, 2015 Share Posted June 14, 2015 looking cool! Link to post Share on other sites
alex 1,190 Posted June 20, 2015 Author Share Posted June 20, 2015 (edited) That's how the main gear bays look like after some painting The APU exhaust was a little bit too deep into the fuselage, so I needed to rebuild the area with sheet. I also extended it a bit on the inside. The holes of the middle fuselage pylon have been filled. I use some stretched sprue for that. I also opened the oil coolers. fuel coolers. The nose gear bay is attached to the cockpit tub and is ready to be glued into the front fuselage section. Thanks for watching! Alex Edited June 20, 2015 by alex 4 Link to post Share on other sites
AnonymousDFB1 2,743 Posted June 20, 2015 Share Posted June 20, 2015 Nice work Alex, you're going for it aren't you? Looking good. Link to post Share on other sites
Tim Moff 4,107 Posted June 24, 2015 Share Posted June 24, 2015 Great stuff - not sure if I have the skills for the APU and fuel coolers! Link to post Share on other sites
Alan P 6,667 Posted June 24, 2015 Share Posted June 24, 2015 Fast work alex! Looks good so far. Link to post Share on other sites
Tim Moff 4,107 Posted June 25, 2015 Share Posted June 25, 2015 lol - I can now see how that pilot bulkhead and WSO boxes are meant to go...mine is slightly different, instructions not too clear...too late now all sealed, will be in flight so not too worried...know next time!! Link to post Share on other sites
Lex77 1,724 Posted June 25, 2015 Share Posted June 25, 2015 Looking very good Alex. You are doing some things in 1/72 scale which I don't do in 1/48 scale! Link to post Share on other sites
alex 1,190 Posted June 29, 2015 Author Share Posted June 29, 2015 The nav lights have been painted chrome silver inside, and glued to the wings: After sanding, it looks rather smooth. The seats from Revell, and Pavla. Revell's not bad, but Pavla is still better... And Pavla after a few colours. (WIP) Intake has been airbrushed with MSG. Fuselage intake is painted with some white. AAR-Probe looks nice, but positionning is a bit tricky, as the locating holes are not very precise. You need checking some photos to get the correct position (and few rubberbands, to hold it firm until the glue has cured. Alex 2 Link to post Share on other sites
alex 1,190 Posted July 3, 2015 Author Share Posted July 3, 2015 just a small update... the front fuselage is attached to the main part. Dry fitting was excellent, but I still had to use some filler. And the first coloured parts. Bombs are Revell light blue and sea green, aquas. Panel lines will get some black washing at a later stage. Alex 3 Link to post Share on other sites
Jabba 4,686 Posted July 3, 2015 Share Posted July 3, 2015 Coming together nicely. I really like the ejection seats, much better than the kit ones. Link to post Share on other sites
Cookenbacher 11,267 Posted July 4, 2015 Share Posted July 4, 2015 Wow, that's some top work Alex. Link to post Share on other sites
alex 1,190 Posted July 14, 2015 Author Share Posted July 14, 2015 Seats are glued into place with CA. They are too tall, so that the canopy wouldn't close anymore, so you have to sand 2-3mm at the bottom. The lens of the HUD has been made with transparent sprue. Milled to the right diameter, polished on top, and painted with gloss black. A shame you won't see it once finished. The HUD itself is from the kit. Alex 4 Link to post Share on other sites
Cookenbacher 11,267 Posted July 15, 2015 Share Posted July 15, 2015 Wow! The HUD frame looks amazing. Link to post Share on other sites
Hockeyboy76 8,895 Posted July 15, 2015 Share Posted July 15, 2015 Wow, this is some quality work dude. Link to post Share on other sites
alex 1,190 Posted August 4, 2015 Author Share Posted August 4, 2015 OMG, time flies... Today, I managed to mask the cockpit, intakes and the small pod underneath the fuselage (Laser?). Main wheel doors are glued in place with PVA, so I can avoid a lot of masking. Tomorrow the black parts like radome and preshading, then white, then grey. (and some metal parts for the exhaust) Alex 4 Link to post Share on other sites
alex 1,190 Posted August 8, 2015 Author Share Posted August 8, 2015 DSG (Tamiya Acrylics) have been applied after the preshading. As usual, the preshading has almost vanished. Next step: masking the grey parts, and then the white colour. Alex 1 Link to post Share on other sites
