nimrod54 12,519 Posted June 6, 2015 Share Posted June 6, 2015 On this my second set of builds for the GB, I plan to use the Revell 1/144th kit for examples from Luftwaffe, Italian Airforce and RSAF. As the kits are basically the same I intend to include them as a single topic. If the mods would like me to split the builds then please let me know. The Luftwaffe example is an ECR in the 2011 Tiger Scheme and will be made out of the box For the Italian IDS - ECR I am going to use this kit and for the RSAF IDS I am using a GR1 kit. For the Italian and RSAF aircraft I am going to use decals from the excellent MARK1 book 5 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 6, 2015 Share Posted June 6, 2015 Will be watching John, keen to see what's up your sleeve. 1 Link to post Share on other sites
AnonymousDFB1 2,743 Posted June 6, 2015 Share Posted June 6, 2015 Mmmm nice selection 1 Link to post Share on other sites
Fifer54 1,036 Posted June 9, 2015 Share Posted June 9, 2015 Excellent selection! Those MarkOne decals are great! They improved my collection of teeny Tonkas amazingly! Good luck with the Saudi kite, that camo is very subtle. I had to abandon mine, whatever I did it looked like a toy (where the others I did, didn't) . . . 1 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 9, 2015 Share Posted June 9, 2015 Do you decals for all the Tonkas in the book John or only some? Link to post Share on other sites
nimrod54 12,519 Posted June 9, 2015 Author Share Posted June 9, 2015 Do you decals for all the Tonkas in the book John or only some? There a 12 aircraft covered in the book 4 RAF, 3 Luftwaffe + 1 Marineflieger, 3 Italian Air Force and 1 RSAF. The national markings and relevant squadron markings are included, there is also a limited amount of warning markings. It also includes 4 views and photographs of the aircraft that are covered as well as some general walkround shots. There is an interesting 50th anniversary scheme that was carried by a Luftwaffe IDS of the Defence Material Test and Evaluation Unit which I wouldn't mind having a go at sometime in the future. I've included a link Tornado IDS DMTEU I probably won't use them all so if there is a set on the remainder of the sheet that you might be interested in let me know and I can let you have it. 1 Link to post Share on other sites
hovis 207 Posted June 10, 2015 Share Posted June 10, 2015 Looks good to me! 1 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 10, 2015 Share Posted June 10, 2015 It was the Orange badger that caught my eye too John. I shall have to find one of those books. Quite fancy an airforce of Tonkas. 1 Link to post Share on other sites
nimrod54 12,519 Posted June 10, 2015 Author Share Posted June 10, 2015 It was the Orange badger that caught my eye too John. I shall have to find one of those books. Quite fancy an airforce of Tonkas. Listen bud, your quite welcome to that scheme if you would like it. There are more than enough options on that sheet to satisfy the kits that I have and I have the Xtradecal sheet to go at as well. 1 Link to post Share on other sites
nimrod54 12,519 Posted June 13, 2015 Author Share Posted June 13, 2015 Not too much progress on these other than having got the rear fuselage sections together, I hope to get them moving along soon. 4 Link to post Share on other sites
AnonymousDFB1 2,743 Posted June 13, 2015 Share Posted June 13, 2015 Specialising in Tail sections John? 1 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 13, 2015 Share Posted June 13, 2015 You probably know this already, but the Revell instructions say fit the intakes after joining front & rear fuse's together. After trying this I would suggest & be doing on my next one is fit the intakes to the forward fuse then join to the rear. Allot less fiddly!!! Link to post Share on other sites
nimrod54 12,519 Posted June 14, 2015 Author Share Posted June 14, 2015 Thanks for the reminder, like you I found out the hard way that it was easier to fit the intakes to the nose assembly before joining the front and rear sections together. 1 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 14, 2015 Share Posted June 14, 2015 Fun wasn't it!? 1 Link to post Share on other sites
nimrod54 12,519 Posted June 24, 2015 Author Share Posted June 24, 2015 Just a mini progress update. The Saudi IDS has had the cockpit tub and instrument panels painted, I have to paint and detail the seats, add the decals and then I can button the fuselage halves up and join the front and rear sections. The ECR's have had the gun ports filled the Luftwaffe version having been sanded to shape, the Italian aircraft has yet to be sanded. The tubs and seats for these two also have to be painted. I am trying to keep the construction of these at a similar stage as much as I can up to the main painting and decalling stage. Photo's of the work carried out to fill the gun ports on the ECR nose sections follow. First job was to carefully remove the barrel. Then plug the the port with a small piece of plastic rod. Followed by some careful sanding to shape taking care not to remove the tiny AOA probe located just above this area. 5 Link to post Share on other sites
Hockeyboy76 8,865 Posted June 24, 2015 Share Posted June 24, 2015 That's some quality 1/144 work there John. 1 Link to post Share on other sites
nimrod54 12,519 Posted July 3, 2015 Author Share Posted July 3, 2015 A little bit of work done to these too. The Saudi IDS fuselage has been buttoned up and I am now adding a little detail to the instrument panels of the other two to try and break up what would be a flat looking area. Cockpit of Saudi version Extra detail added to the IP's for the other two aircraft. Alongside the F.3 3 Link to post Share on other sites
charlie_c67 1,090 Posted July 8, 2015 Share Posted July 8, 2015 I definetly picked the wrong scale to do the f3 in! 1 Link to post Share on other sites
nimrod54 12,519 Posted July 16, 2015 Author Share Posted July 16, 2015 Got the fuselages of the other two aircraft together, it's amazing how quick things go together when you have done it three times maybe there is something in Enzo's multi-build technique. Once I've built another three I should have the assembly off pat. I had a bit of an issue closing the nose halves of the second kit after I had put too much Liquid Gravity in so there will be a bit more seam clean up to do on that model. A bit of paint touch up to the cockpits and then I can close them up. 4 Link to post Share on other sites
mirageiv 3,845 Posted July 16, 2015 Share Posted July 16, 2015 Looking good! The Dragon? F3 looks a heck of a lot like the Hasegawa 1/72 kit, even has the fin tip! 1 Link to post Share on other sites
Sir T 93 Posted July 16, 2015 Share Posted July 16, 2015 Great work! 1 Link to post Share on other sites
nimrod54 12,519 Posted July 28, 2015 Author Share Posted July 28, 2015 Looking good! The Dragon? F3 looks a heck of a lot like the Hasegawa 1/72 kit, even has the fin tip! The Dragon F.3 is quite nice little kit although the panel and rivet detail is a bit heavy for this scale. I had to do a bit of work on the leading edge of the fin tip because it looked to square. Great work! Thanks Sir T. I've made a start on adding the Secondary Heat Exchanger intakes to these. This detail on the Saudi IDS has been finished whilst that on the two ECR's have been roughed out and need further refinement. 1 Link to post Share on other sites
nimrod54 12,519 Posted August 6, 2015 Author Share Posted August 6, 2015 Not a lot of progress to report, just a little more detail work to the underside of the ECR's. I have added the FLIR pod, which is absent in the kit, by using some square section stock cut and sanded to shape on both the Luftwaffe and Italian versions. Luftwaffe ECR Italian ECR Whilst looking through some stuff earlier today I came across these, so I will be adding one of these to the Saudi IDS. 2 Link to post Share on other sites
Hockeyboy76 8,865 Posted August 7, 2015 Share Posted August 7, 2015 Nice work John. 1 Link to post Share on other sites
