Black Knight Posted June 6, 2015 Share Posted June 6, 2015 Itsmee again. I'm thinking of getting a set of Montex masks for a 1/24 aeroplane. Have any of you used Montex masks, especially for national markings and codes? Any words of wisdom to impart or share? tia Fred Link to comment Share on other sites More sharing options...
Procopius Posted June 6, 2015 Share Posted June 6, 2015 I've used their cockpit masks on several (AZ P-40E, 2 x Special Hobby P-40L) kits, but wasn't blown away. I suspect they'd be better on flatter surfaces. Link to comment Share on other sites More sharing options...
Stew Dapple Posted June 6, 2015 Share Posted June 6, 2015 James is currently using some for the markings on his French Spitfire You might want to follow it and see what he thinks of them; I don't have any personal experience of them so I am doing the same Cheers, Stew Link to comment Share on other sites More sharing options...
Black Knight Posted June 6, 2015 Author Share Posted June 6, 2015 Ta Stew, will do. Link to comment Share on other sites More sharing options...
Skids Posted June 6, 2015 Share Posted June 6, 2015 I used them recently on my P-40 and I Had no problems. Easy to use and I liked the end result. 1 Link to comment Share on other sites More sharing options...
tank152 Posted June 6, 2015 Share Posted June 6, 2015 Yes I've used them on my ZM Ta-152 I've a WIP thread if you want to take a look at the results. They can be tricky to position due to the tackiness, the best way I've found to get round this is to wet them before applying them, you can then slide them around to position them better. Once in position dab them with some kitchen paper to dry them off and then you're ready to go. When spraying use mist coats to build up the colour slowly, you don't want wet coats or you will flood the masks. One of the biggest problems with Montex masks is that unlike Mal's Miracle Masks you don't get any information in how to use/apply them. If you decide to invest in some I'd be more than happy to scan his instructions and e-mail them to you so that you have some idea. Once you have used them you won't want to go back to using decals. Tim. 1 Link to comment Share on other sites More sharing options...
Black Knight Posted June 6, 2015 Author Share Posted June 6, 2015 Thanks for the input chaps Link to comment Share on other sites More sharing options...
ancient mariner Posted June 6, 2015 Share Posted June 6, 2015 I use them and like them. No tips or tricks to impart sorry. Link to comment Share on other sites More sharing options...
kwaterous Posted June 13, 2015 Share Posted June 13, 2015 I've got a set for the big revell Beaufighter. Canopy one don't seem to be super flexible, but they do fit quite well. I assume the ones for the rest of the plane will behave similarly. Nice thing about Montex is that the give you inside and outside canopy masks. K Link to comment Share on other sites More sharing options...
Black Knight Posted June 13, 2015 Author Share Posted June 13, 2015 I use them and like them. No tips or tricks to impart sorry. That in itself is a valid tip; it suggests they are straight forward and simple to use I've got a set for the big revell Beaufighter. Canopy one don't seem to be super flexible, but they do fit quite well. I assume the ones for the rest of the plane will behave similarly. Nice thing about Montex is that the give you inside and outside canopy masks. K I see they do both inside and out for the canopies. Very thorough of them I think. Link to comment Share on other sites More sharing options...
06/24 Posted June 13, 2015 Share Posted June 13, 2015 I used them on a spitfire and was very disappointed, the problems could of course be down to the numpty using them, but they weren't my happiest experience. I doubt I'll use them again where an alternative exists. Link to comment Share on other sites More sharing options...
