Shar2 Posted May 26, 2015 Share Posted May 26, 2015 Focke Wulf 190 Wheels and Main Undercarriage 1:32 Brassin As good as the wheels and undercarriage are on the new Revell 1:32 Fw-190F8 the seams on the tyres will take some careful sanding to completely remove them and thus probably a lot of detail. These new wheels come in the standard blister pack with two layers of foam protecting them. On opening the quality of parts really stands out. The tyres, with very finely engraved treads, the mains with radial treads along with the tailwheel which whilst having no tread the hubs are beautifully moulded with a more natural look than the kit parts and come complete with the manufacturers name on the sidewalls. Clean up of the wheels should be quick and easy as the webs holding them to the moulding blocks are very thin. Any excess left after removal will only require a quick swipe of a sanding stick to tidy up. Also included in the set are the inner hubs, with nicely rendered brake details and attachment holes that match the kit axles. The outer hubs have a finesse and depth to them that would be impossible to do in injection moulding. The hubs are on quite large moulding blocks for their size, but since they are on the rear of each item it’s just a matter of razor sawing them off and flattening them with a sanding stick. To complete the set Eduard have included a sheet of masks to aid painting. Meanwhile, the second set of parts, in a similar blister pack, contains a pair of replacement resin undercarriage doors which have a much better scale thickness as well as extra detail, the thin webs holding them to the casting blocks shouldn’t cause too much of a problem to clean up. The best bits about this set are the superbly produced bronze undercarriage legs. The casting is superb and appears to include all the brackets and clamps seen on the real items. All that is need is the addition of some brake hoses to complete the look. It’s just a shame that they have to be painted as the look really good as is. ConclusionThe new Revell kit is a feast of detail in its own right, but the addition of these simple parts will not only aid the look of the undercarriage, without too much effort in cleaning any seams, but will also give increased strength to the undercarriage thus preventing them legs to spread and distort.Highly recommended Review sample courtesy of Link to comment Share on other sites More sharing options...
