Sherman Mk.I with dozer, 4th NZ Arm.Brig in Italy - from Asuka ?
TomCZ
Hi there,
I am thinking of making Sherman Mk.I dozer using Resicast dozer and Bison decals.
Now I am just considering a donor - but since all my other Commonwealth Shermans should be from Asuka kits, can you please recommend, which kit or kits should be used from Asuka/tasca range ?
Thanks.
Would that be a M4A2 rather than a M4?
Regards
Phil
It could possibly be, but without seeing the style of transmission cover (or something else to compare between the two types?), I can't say for certain.
Interesting chart here does put it as a Sherman I:
http://www.172shermans.com/markings_New%20Zealand.htm
regards,
Jack
Edited by JackG
If the driver's and radio operators hoods are of the welded type as opposed to the cast type, that tells me is this is a tank built by Fischer Body. That in turn means it is most likely an M4A2 in that Fischer built mostly those variants. I'm looking at what appears to me as a sharp edge just above the add on plate in front of the driver's hood.
Just addding to the confusion here!
G
Well, getting complicated a bit :)
Do you know about better resolution pic ?
Or are there some pics of Commonwealth dozer with visible markings to make a correct camo on correct version ?
