1/48 - Yakovlev Yak-9DD/TD & Yak-9D by Modelsvit - released - new Foxbot Decals
Homebee
Homebee - would you please correct the topic name. Now it's:
Yakovlev Yak-9DD & Yak-9A & D by Modelsvit - Yak-9DD released - Yak-9D & Yak-9A release in 2020 - Yak-7 resin conversion set by Vector
There have never been anything like the Yak-9A. Thus it should read:
Yakovlev Yak-9DD & Yak-7A & Yak-9D by Modelsvit - Yak-9DD released - Yak-9D & Yak-7A release in 2020 - Yak-7 resin conversion set by Vector
Michael
Edited by KRK4m
a misprint
There have never been anything like the Yak-9A. Thus ist should read:
Michael
Yeah, I had the same thought - there was never a Yak-9A, the initial version was simply designated Yak-9 (no suffix), right?
John
John
Yes, John. When talking about the Yaks you're always right :)
The Yak-7DI (thus -7B with metal wing spars, larger fuel tanks and one MG less) when put into series production has been renamed simply the Yak-9.
Michael
On 02/10/2019 at 17:13, John Thompson said:
Looks great! Maybe with Modelsvit making such a commitment to the Yak-9 series in 1/48, someone will pick up on doing the same in 1/72. The recent attention to the Yak-1b in one-seventytooth (excellent kits from Brengun and Arma) is encouraging!
John
To see new-mould 1/72nd scale kits of the Yak-9D, Yak-9DD, and the Yak-9T would be brilliant!
Regards,
Jason
02e43b440b9b44d3cab254ae1ba587be.jpg 02e43b440b9b44d3cab254ae1ba587be.jpg 02e43b440b9b44d3cab254ae1ba587be.jpg
Source: https://www.facebook.com/groups/greenmats/permalink/3024505224275666/
Quote
Hello Friends,
Maybe someone of you know that in the end of 1944, a small amount of Yak-9D (Early vers.) were converted into 2-seat night interceptors with more powerful armament and radio locator. So, we have decided to recreate this unfamiliar modification under designation Yak-9SD in 1/48 scale.
Greetings!!
91707291-2620452608223774-20678189668011
91185533-2620452704890431-54213164907815 91216359-2620452574890444-88074395097602
91234738-2620452674890434-36974071045381 92018367-2620452594890442-20358906523691
V.P.
  • Haha 4
  • 1 month later...
Yak-9D sprues
Source: https://www.facebook.com/modelsvit/posts/2666066990329002
Quote
Hello fellows!
We are continuing our work on WWII Yak's family in 1/48 scale.
Below you can find first test shots of the new Yak-9D, being fully 3D designed!
In few months we expect to be ready with the other sprues, decals and photo-etch sheet.
99127664-2666066486995719-10287444308923
98460892-2666066736995694-88522424611084
100093728-2666066500329051-2491392365269
100514838-2666066560329045-3784702203160
100374160-2666066476995720-3580690801333
99138933-2666066640329037-45840299251445
V.P.
  • Like 9
3 hours ago, Graham Boak said:
What's a TD?  A long range T?  Or just not-quite-as-inventive as the SD?
From Red Stars 5 reference the Yak-9T - "from the 11th batch (Feb 1944) onwards all machines were built with four tanks holding a total of 480 litres. When the 37-mm Nudel'man/Sooranov cannon was installed, the model was designated Yak-9TD".
  • Thanks 2
15 minutes ago, Mike Esposito said:
Which variant to get? Hmmmm. 37mm for AtA work seems wrong....probably the D. 😁
You don't have to use it for A2A work you know, you can use it for what it was designed for - ground pounding ;)
I just hope they give us more Yak-9 versions, I would love to see a recce Yak-9R.
It appears that it's Modelsvit - "В коробке Як-9ДД от фирмы Modelsvit" = "In the box Yak-9DD from the company Modelsvit", according to Google Translate:
https://leib-company.ru/voennye-samolety/19168-zebrano-48001-istrebitel-yak-9dd-i-toplivozapravsshik-bz-38-1-48.html
John
John
Thanks. I shouldn't have been so lazy and just Googled the product number! Chrome translates that page automatically, not that "Modelsvit" needs translating ;)
6 hours ago, Graham Boak said:
Yes, the 37mm was designed for Air to air, and very popular as a "sniper".  The P-39 was also designed and built with a 37mm, part of the reason the Russians liked it.
I thought the T stands for Tahnkovyy, which I believe translates to tank-busting? I don't speak Russian so I'm only going from what I've read, but I do realise it was used against aircraft.
The Lagg-3 also used a 37mm cannon, the Sh-37 which they used against bombers.
Probably a case where it was designed for one thing (anti-tank warfare) but used where the opportunity arose against aircraft. There was also the Yak-9K with its massive 45 mm cannon, again designed as a tank destroyer. Either weapon would have had such a recoil force as to make it difficult to aim for sustained fire against anything more maneuverable than a tank or a bomber, and even then it was seemingly intended that one round would do the job.
John
John
Yes the NS-45 was a beast, though a bit too much for the Yak-9 structure. The Yak-9K ended up being used mainly for ground attack because of the lack of German bombers being used by that time in the war.
