Dear Fellow Modellers,
I've started this model back in November 2014 and I'm nearly finishing it. However, since it is still a WIP, I thought I could post the main building steps here.
The kit is the Revell Bf 109 G10 in 1/72. This is the box and contents - just two gray sprues, one clear sprue and decals for two aircraft. 37 parts in total:
y4mOPZo3ROL_pJN6JdAEWQZufujSWxHJClnQMYCk
IMAG1105
My main objective when I bought this kit was to try to properly paint a mottled camouflage. As you'll see later on, I tried a few other techniques, namely some scratch buiiding, in order to correct some lack of detail / errors.
I chose the option of the IV. Gruppe/JG 27, early 1945, Berlin aircraft, with yellow underside wing tips. I didn't find any information on the individual aircraft portrayed by Revell, but found several sources about Bf 109 G10 aircraft (109 lair, barracuda decals Part I and Part II), which I used to correct the painting instructions and other details.
I was also inspired by the excellent build of this kit made by Rato Marczak, though for a different individual aircraft.
This virtual view of a Bf 109 G10 cockpit was also useful.
My first step was to cut out the main parts (fuselage, wings, cockpit components) and make a dry-fit test, to check potential fit and seam problems:
y4mmRJW-loJ2b0G3a_q7qdvawWimYz71pg1mAJxE
IMAG1109
There was nothing specially problematic.
Next I cut out the canopy, gave it a bath of Alclad Aqua Gloss, which I found to be a superb product to bring out the transparency of clear parts, and let it dry overnight:
y4mBzKyhm1f5T4gP6m3nH2cOtpfuT5TOFJxJSn99
IMAG1222
When dry, I masked it with Tamiya masking tape. Here are a few steps of the masking process:
y4m0ksoLt3ttXc-ujhnL3VwJ98D_NA8XIuFo5OcD
IMAG1223
y4mhKjKzRsPD768MT8Xfot4Rb9bdbguS1KGdNTAE
IMAG1224
y4mhQHvsOU7GdS2H7boGFBUUaoTdMD9yLoP6veTo
IMAG1225
Then, I proceeded to the cockpit. Luftwaffe aircraft of this period had their cockpits painted RLM 66 Schwarzgrau (Black Gray).
The instrument panel was given some color according to pictures of the real thing. The backs of the dials were painted black and the rims of some of them were dry-brushed with yellow and red. A dry-brush with silver was applied to provide a worn off look. A flat coat of varnish (Micro Flat) was then applied and, in the end, the dials were covered with a drop of Alclad Aqua Gloss, applied with a toothpick, to simulate the dials' glass covers:
y4mrVx8_nmkOTEBwHVBjJ4UU_r3mFm3uFCKN_ora
IMAG1290
The cockpit base, seat and control column were also painted RLM 66, dry brushed with silver, and washed with a Vallejo brown acrylic wash. Finish is Micro Flat.
y4mdcLkyk6BeDoEYCjFe6XS5JdAZsad2Q6c9z5ZA
IMAG1292
The cockpit sides were subjected to the same treatment:
y4mlhQrcSuRSSCJrSJCWWgxz-QQhowgrRvZ-W8oq
IMAG1293
y4moplKV1z1mLq-ilVQowlSQ5C10AjoJVpildbeS
IMAG1294
At this point in the build I intended to display the aircraft with a closed canopy, so I considered the existing cockpit detail to be good enough.
Here is the cockpit base, seat and instrument panel already glued together:
y4mPc54dZgYuYSe3RdP7TY0mzsRQRrjUV42QAw6R
IMAG1419
y4m_G_rO_YNUonwfWWxkDOrtVVRa8EZMeDI66kk4
IMAG1421
And now glued to the fuselage:
y4mrlSDlg6W62TnmCJsbW1Shq1jWwOdcbQvrl7jS
IMAG1425
y4mqBm44QHMF4JhXCOIu4EmbBCI9j8wbvklHUhyS
IMAG1426
y4mIUnVY_ZCVSbkq1vtCuh4ILx_FKefwcPgGmYca
IMAG1427
Well, I guess this is enough for the first post of this WIP.
Hope you found it interesting. Thanks for looking.
Jaime
This is very nice. I've built three of these G10 and I remember the propeller had too small a diameter.
Patrick
Patrick, Thanks for your post. I'm afraid I'm too nearly finished to replace the propeler with an AM substitute...
If you can find an old Heller kit...
Patrick
Patrick
Funnilly I did one when I was a kid. I believe it was an E-3 or E-4, but I lost track of it long ago.
I was speaking about this one, which should be available for less than a resin propeller.
Patrick,
Thanks for the tip. I'm afraid my local hobby shop has neither the resin propeller nor the heller kit in stock. They would have to be ordered from the sellers and that would take at least 3 weeks. As I'm just finishing the model and have already applied the spiral decal to the propeller cone (I'd have to source a new decal sheet or try to mask the resin cone and paint it), this is not an option right now. :weep:
However, I'll take note of your tips for a future build. Curiously, the resin propeller with cone, from Quickboost, would cost about 4 € and the kit at least 12 €.
By the way, the Heller kit has a great box art! Is the kit any good? Or is there a better 109 K?
Thanks again
Jaime
The Heller kit is rather nice if a little dated now, with raised panel lines. The best late-war Bf109Gs and Ks come from Fine Molds. However, don't buy the Heller K for the prop, for although it is the right size it goes round the wrong way. Quickboost do a replacement prop which will do for either kit.
As I recall the Revell G-10 also has the undercarriage legs a little too far out, but I suspect that's too late now.
Graham,
Thanks for the advice. I'm afraid it is too late now for additional modifications in the model. Anyway, my initial objective was to built it OOB and try my first mottled camouflage. In the way I ended up making a few error corrections but just those that where more glaring.
I'll make a few additional posts to show them.
Thanks again.
Jaime
This is the second WIP post on the Bf 109 G10 by Revell.
I did a few corrections to the more glaring errors, though this was not my main objective for the build.
I decided to follow Rato Marczak's technique for building more realistic navigation lights.
I cut two roundels of clear sprue and etched the wing tips on the navigation lights' positions:
y4mxBBH-u0YMryErmKou138SP0gc70rJ_9n0EAJi
IMAG1438
y4mEGinX9ahHqUMXl8gGUD9H3jOD9gcaSn2NMQsf
IMAG1439
The roundels where drilled with a 0.3 mm mini-drill:
y4mOl8WQ_7oTTeolHV1B3QIT7yXfa1nPaDW1I6Qf
IMAG1441
then I filled the holes with transparent red and transparent blue paint:
y4mBalFLvx1dx49NWnGkrvA9pZS5imnPhsJPqzX0
IMAG1443
While I was dealing with the wings, I followed Rato's directions in order to make proper cartridge ejection holes. I started by drilling the positions of the holes:
y4mkygcBIcEsswMS821FYO8FvGSuI6lN7Mo654ja
IMAG1444
The holes were squared with a nº 11 x-acto blade:
y4meBj1H9wejYIlIQpeGtWTp7Uc09TCg0rGUQfJW
IMAG1445
Then, I cut small strips of Evergreen 0.5 mm thick plastic sheet in order to build the ejector walls:
y4mQZtIUVQlCYrVMyE-OwonibHN9if-ezpqLAPfk
IMAG1447
These where glued in place and the exterior facing sides were painted RLM 66 with a small paintbrush (just to make them dark). I also glued the painted clear roundels in the wing tips:
y4m81RHLmvYZ7-B0umEGKJqW3dgC706LOj8GB1yW
IMAG1451
The clear roundels were sanded to shape:
y4mQWO4Y3CJoOiDF-0G_F4vlmQF7qUFzMS6Hfdwr
IMAG1461
y4mbRqo-k4AMpdznbYpTgSerkEU5YAInGsG4vAYh
IMAG1462
Here's the end result:
y4mGzlHVXTW95PpJ-OrF3W8tjetIQkkPU30pg1Rs
IMAG1463
Before gluing the two fuselage halves together, I cut the front piece (where the propeller should fit) so that I could install the exhausts after the main painting:
y4mRvaltKGpMJQW7w2eTjfcTNcIhJJUHjM7MLM3x
IMAG1418
I also used putty to make some rivets disappear. In fact the kit has a quarter circle of rivets over the engine covers, which is not to be found in any picture or technical diagram of this aircraft:
y4mZBJ0HfSG9JmypB8rVZR-j14kKYXoTgS320vRs
IMAG1416
After gluing the fuselage halves together, I installed the air intake, which was previously drilled to make it more realistic (the original piece has no air admission hole...):
y4mPvOYVYpju3WCjqc6Ks12tfRoxqEZ4j9tiyFl0
IMAG1485
I also installed a piece of plastic, carved out from sprue, to represent the battery box, on the back of the cockpit:
y4m-8SBgFpwgDU8CbcBf_5D3Is1ghUzMc_Zo0Ijl
IMAG1511
I'll continue tomorrow. Thanks for looking.
Jaime
Hello again
This is the third post in the WIP.
When I test fitted the canopy found it was narrower than the fuselage:
y4mlF7_gHIfLS4aGqDlZiQbURiQq1IWRtvXM7eS2
IMAG1515
It also didn't fit properly in the front, due to the gun sight piece:
y4mUn42tbvoTuZJLTIPjp69wEjPJOZ2ywKsnb7kN
IMAG1516
Due to this, I couldn't build the kit properly with the canopy closed and decided to build it with an open canopy. However, this implied I should cut the canopy piece.
To do this, I filled the inside of the piece with Blu-Tack I placed it on a Blu-Tak base, in order to minimise stress to the part while cutting. Then applied masking tape along the joint of the fixed and movable parts of the canopy, to serve as a guide for cutting:
y4mZcfDM4JF-Cg8jsqYJ16OuS15fhu84hrP-kuXA
IMAG1519
Using a brand new nº 11 x-acto blade, I scribed and slightly cut the piece along the joint:
y4mA0txhpVwEZ4if5eVAZZ_w5ouL3gHgz81udsbF
IMAG1520
Then I slowly progressed, cutting through the piece. This took me quite a while and a lot of patience, but in the end I managed to cut the piece without damage:
y4mLZMvDWA2KzUih82jQ0AYBOReoLovAA1d3ODB5
IMAG1521
Here is the end result:
y4mM9ZGl6H4ljmsZz8Dk6TPPwSMyunHP1dVZHf15
IMAG1522
The masking was then repaired and a new coat of interior colour was applied.
Since the canopy would be open, I decided to improve the armoured glass piece that existed behind the seat (fixed to the top of the moving part of the canopy).
The kit is rather poor regarding the representation of this part. This picture from early in the build shows that the armoured glass is represented by two pieces of slightly bent solid plastic, in each of the fuselage halves. Right at the beginning, even considering that I would build a closed canopy, I decided to improve this piece slightly, so I cut the two halves:
y4m3iugYIeyzEtuTEkxU4wdxIpti8FvwPco-gvZB
IMAG1136
cut off the inner area of the plastic pieces:
y4mXsZWLLYX7PiLQG_egBA-BW4iKzx06gHFnQ3Cg
IMAG1137
glued them together and applied a piece of acetate to simulate a better looking armoured glass:
y4mqvfxguZM4ZS8KahUXG9bFh4Pt36pX3p6qeIqJ
IMAG1139
Not really perfect but passable (hopefully...) under the closed canopy.
However, with an open canopy I decided to scratch build a proper looking piece. The following picture shows the real thing:
y4m7d0UeE_0jtsZsGDshaga-yiWyIQ821gCWbRuw
I used pieces of Evergreen 0.5 mm thick plastic sheet, cut to shape (here, side by side with my first attempt, already painted):
y4m7GKu0VrBHOAqcgxWLKs9FsATtgWdoO9PVxMuf
IMAG1486
Glued them together and here's the end result. Much better now, I guess:
y4m5a9M9XIBIphw_KOT7Q7KEAyvNJDmkA0Ep9B9y
IMAG1489
To finish with the improvements, I replaced the original gun sight (a solid piece of plastic) by a piece of acetate, previously bathed in Aqua Gloss to improve its transparency:
y4m9hJzOPa456Dg4Xr3GgIjxc8I7HvcI6-8YqSLJ
IMAG1543
Should be enough for a single post... :wacko:
Thanks for your patience.
Jaime
Hi, fourth post on work progress.
This one's about painting.
All the small parts were cut off the sprues, cleaned from flash and moulding marks and glue to the tips of toothpicks, for better handling and painting. I use just a small drop of super-glue on the toothpick's tip and press it against a locator pin or an area of the part that won't be visible after assembly. Here they are before priming:
y4m4WDiEl9sLpvs1iMKfDSrKOClUXtEOmYjBS627
IMAG1430
After priming (and painting some of them), the result was this:
y4mE3VukxgDmLH14j0kybftfrVUY8BunPkYTp8R7
IMAG1587
then I primed the aircraft with Tamiya XF-19 Sky Gray and pre-shaded the panel lines with flat black. Here's the top side:
y4mtz0oR5k8SdLU_E2YoILJSkknv5aBct6dJ8FM_
IMAG1567
Here's the underside. Since the underside wing tips will be painted yellow, I primed these with flat white and masked them with tape, before priming the rest of the aircraft:
y4mflGGb_MZcr0IMn1Wjt_ZEVgSKfShUcqhA1e79
IMAG1569
After priming, I applied Mig's chipping fluid in areas that should show worned out paint and then applied silver over those areas. Next I painted the underside and fuselage sides with RLM 76 Lichtblau (light blue) and let it dry.
This is an aircraft with a mottled upper camouflage, in the transition from the upper colours to the underside colour. The upper colours are RLM 81 Braunviolett (violet brown) and RLM 82 Lichtgrün (Light Green). The mottling is done with RLM82.
I started by delimiting the upper and underside colours with blu-tack. The upper colours should be slightly blurred on the edges, so the airbrush should be used perpendicular to the blu-tack. Note the upper colour delimitations marked on the wings with pencil:
y4m7xBXre4wtAGJm_f_ZE2S4Dt0mziEyl6ftz77l
IMAG1616
y4mql2FWQwI08GHJuzLgpZnGD2K4IEUQP8pgYdA6
IMAG1617
The lighter colour (RLM 82) was applied free hand within the pencil delimitations. I did some post-shading with lightened RLM 82 (with a drop of flat white):
y4mH0_RUnegJaBi-JBkHv79p1hB8lwXuKWKN7EYb
IMAG1619
Next I used blu-tack to delimit the areas to be painted with the darker colour (RLM 81) and protected the already painted areas with a combination of masking tape and kitchen cling film:
y4mxhlc902v-jrpLLL9IMzh8GjMzOuc2Yrx227Lt
IMAG1625
I try to avoid using masking tape directly over painted areas in order not to damage or peel off the paint.
After painting the darker colour and removing all the protections, this was the result:
y4mGRjxllb1Kwayp3HLOXEhREANFVhJ05evZN_jS
IMAG1637
y4mFJSXfXJCh0Kcllc2JrBBiijqzjbH_w4JUTY7c
IMAG1638
y4mVlrcAF21OlQ36ZqxgDFGo9LCDL6xwHtnc19Sh
IMAG1639
A detail of the soft transition from the upper to the lower colours:
y4m4B_WE7XPxnYDBDIuYjMIriwiqK4We-cWni9Wv
IMAG1640
The next phase was painting the mottling. For this I diluted the paint in an approx. 75% thinner / 25% paint ratio, reduced the pressure to 10 psi and closed the airbrush paint volume as much as possible, in order to have as much control as possible over the paint application. Fortunately, Gunze paints are excellent and very rarely clog, even under these settings, which permits a good control of the mottle painting. The mottling was painted free hand, loosely following the kit's painting instructions.
Here is the result:
y4mUeYaIAG1bgb_o-7jywzblBwVjPnwVwLsGWyz-y4m0jzVJV8lD3BUccYZsf-JNHgsBMVERC3Ah1zMd
IMAG1646 / IMAG1647
A more detailed view:
y4m1jaVo5r-hajoZs_RIQMKecre2l3uPhqk8yxthy4mv5nX0vPAWXB0-XnZQmncV0J3VqUhu4YVwq1tR
IMAG1648 / IMAG1649
y4mLGupGksTrmsiaXj4u0vfHUYFCd2zFlQRLR27iy4mIVGb_rHNQQEu3MkK_v6nbKiNIx8TSv9iffXBn
IMAG1650 / IMAG1651
I must admit I was rather pleased with the results, as this was my first mottling attempt.
Hope this has been interesting.
Jaime
Having finished the camouflage, I still had to paint the yellow underside wingtips to finish the main painting.
I had applied white primer to these, to ensure a brighter yellow, and kept them masked while painting the rest of the aircraft.
Now, I removed the masking from the wingtips and masked the rest of the wings' undersides, using kitchen cling film and masking tape:
y4mstdwE5u1NAAytHN3L5rvfmmzojNrd7f9jC6Ks
IMAG1702
After painting the wingtips with RLM 04 - Gelb (yellow), this was the result:
y4mFzIulCPNJbIyxcsRlch0XhkzkaKiYTTMvs5uP
IMAG1714
I had also painted the propeller blades, backplate and spinner cone. For this I used as reference Barracuda Decals' profiles in their 1/32 Bf 109 G10 decal sheets. It seems that most of these aircraft had the propeller backplate painted 1/3 white, 2/3 RLM 70 - Schwarzgrün (Black Green), even when they had a spiral on the spinner cone. The propeller blades where also RLM 70 and the cone was black. So, I decided to use these colours. The following picture shows the propeller and cone already painted (on the left we can see the armoured glass holding structure that will be installed inside the moving part of the canopy, painted RLM 66):
y4mjt9msafQs-cT31e7yV4PFe5G5D5MmkJ13YBwe
IMAG1704
I had to scratch build the flaps' trim tabs. Although the kit instructions direct us to paint these, the flap ones are missing. I made them from 0.5 mm thick plastic sheet:
y4mraF9478z25D0eOZff9A44_9AevM0wXbhltj5v
IMAG1724
The trim tabs (wing flaps and elevators) were painted RLM 23 - Rot (Red):
y4mP3_0dqp0W76J3yHnIyxO1W8uXoAOyP01zq100
IMAG1725
To finish with, in preparation for decaling, I applied a good gloss varnish coat, using Microscale's Micro Gloss.
Hope you found this interesting.
Jaime
Some more progress on the Bf 109.
With the main painting behind me, I moved on to decaling. I used the kit decals. The swastikas came from an Xtradecal sheet.
My decaling method uses Micro Set and Micro Sol to ensure proper adhesion of decals to the surfaces. Here's the set-up, just before starting applying the decals:
y4mkivo1TFPxmxrHN0z0yFth8yDlkYqWcypxcQnp
IMAG1732
Though in total there were only approximately 30 decals, it took me two night sessions to apply them all.
The following pictures show the end results. These were taken before applying an additional coat of gloss varnish over the decals:
y4moNJ93_Gh0Mw8Rw_i7DBr0LGXP91v3apRGwATm
IMAG1747
y4myNnNyFoxpvir4XMC4C8sPccwDS5tn-IiEaOcT
IMAG1748
y4maLKh0unG6nrRvbynU_1VXXXY4VoA0gdEzkR1i
IMAG1749
y4m-oluUGeA6q04H9Zb-5dB2jPaYSsgT6BmTJG53
IMAG1750
The fuel tank also had some decals:
y4mlGqrJrGtvy2F-mIImnMZeHMGJ6MDDe7ggkkeH
IMAG1753
And the spinner spiral was a decal too:
y4mAwFZwxWuXZf48euerRutokcS1-QKknrkAvm06
IMAG1751
The decals were thin and reacted well to the setting solutions.
I did a couple of mistakes:
  • I applied the swastikas in the end. The kit decaling instructions do not envisage enough space for the swastikas, therefore these are slightly overlapping the Werk Nummer on the tail fin. The Werk Nummer decals should be applied after the swastikas and slightly shifted to the rudder.
  • The green tail band conformed beautifully to the fuselage but I wasn't careful enough and didn't make the visible end of the band to align with the underside longitudinal panel line.
That's it for now.
Thanks for looking
Jaime
Blimey that's a cracking build. Very good paint work there the colours look spot on to my poorly trained eye.
Brilliant
Rob
Bit late seeing this - sorry Jaime! A great build and some good tips here - thanks for sharing!
Rob, CedB, thanks for your kind words. They're really much appreciated.
The paints used are Gunze Mr Hobby Colour acrylics. They're really very good and have the right tones for aircraft camouflages of different countries (RAF WWII and modern, RLM, FS, Japan WWII). They spray marvellously (it is very difficult to make them clog the airbrush - the same can't be said of Tamiya or Vallejo...) and the finish is superb.
Jaime
Looking fantastic Jaime, I love the colours of these late Luftwaffe schemes, you're tempting me to get my Fujimi 1/48 G-10 off the shelf.
Again, thank you all for the kind words :blush:
Jaime
Some more work on the Bf 109.
With decals applied, I moved on to some chipping. I had applied Mig's chipping fluid over silver paint in areas that should have worn painting. This was done before painting with the camouflage colours (both upper and underside).
Now, using the point of an x-acto blade, followed by 1000 grit sand paper, I chipped away the painting on:
  • the wing roots (more on the port side than on the starboard side, since access to the cockipt was done on the port wing)
  • edges of engine cover panels and hinges
  • edges of cockpit and canopy
  • along the edges of control surfaces that were metallic
I didn't chip too much. On the one hand I didn't want to overdo the effect, on the other I read these aircraft didn't get much use due to lack of fuel (end of the war), so they shouldn't be too weathered.
The following pictures show the results.
Port wing root:
y4mxOcnY0TUuJZVQ84LpaqcbSVQT0B324Ozz4R12
IMAG1767
Starboard wing root:
y4mmIwXcfWRdoqwqeTSNY5bzsG0gjFL3lI4q2CZX
IMAG1769
Engine cover panels and hinges:
y4mdx5g3MDA2jDfzJw1j-1YtMEJ9St_V-Pxa_n53
IMAG1769
Control surfaces:
y4m0UIjnuTDeRKuzaTmjf8hH3pTR14fYobkVKDzF
IMAG1770
Next, I applied a new gloss cover, to protect the decals, prior to further weathering.
The following weathering step was applying a dark wash, in order to achieve a dirty / worn look and to accentuate the panel lines. For this I used Vallejo's acrylic "Oiled Earth" wash. The following picture shows the set-up, just before applying the wash with a flat brush:
y4md8ZJ4CXhgDVuFdqn6AJGedHNpjwnkr7FbvkpP
IMAG1782
I used a "sludge wash", where the paint is abundantly applied all over the aircraft, with strokes in the direction of the air flow. This process is not recommended for the faint of heart... :) A "pin wash", just along the panel lines, is a better option for those... :)
Here's the result, on the top surfaces:
y4m2AgR8vThPOA1DzaiXXgpCedanxjNUwSsxEzkP
IMAG1783
and on the under surfaces:
y4mK7fHtEqmL48a4MBDSKld-KrxWsbfWWjWP2HFc
IMAG1784
After 10 minutes drying time (please, don't let it dry much more than this, otherwise the wash will stick...), I removed the excess with damp Q-tips, always with strokes in the direction of the airflow.
The resulting upper surfaces:
y4mR-8f4lzU8_NVoNPdgp4hyTUcxfriPV37A3cOD
IMAG1785
and under surfaces:
y4mlpsFqMDlGW9Uhf8e6BhFruVKuJgnfV_N7a67O
IMAG1786
In detail:
y4m_ZAvFKR6j-DBUG2uVyP9YL2Jh_zn06fFOJjMx
IMAG1798
y4mgbqEt_ubK4JpZb93rDdbhimPVdUhEqljB0ZP0
IMAG1794
Hopefully, the model now looks a bit more realistic.
I applied the same procedure to the fuel tank.
Wash applied:
y4mvZa07H0iNltSvpw9lbeP1NkzO3CZJl7lgdBKP
IMAG1787
Excess removed:
y4mOOdBFGQR68y_o4ofmlGOiwD0Jf0Ql6a5DUXGh
IMAG1790
The small parts got the same treatment. Wash applied:
y4m3Xe3bsW7-9XDHxidTAHMhJZjb4_rS9myCEV9t
IMAG1788
Excess removed:
y4m2J8DlZQPGnT183ZxYISigVrBXt2G5oZldRzWn
IMAG1789
That's all for now. Almost catching up with the present state of the works.
Hope you liked it.
Jaime
Really good build Jaime, keep up the good work. Joe.
Joe, thanks a lot! Hopefully, I'll finish it over the weekend.
Jaime
