MartG
Nuclear Booster Rocket
Those of a certain age may remember the 'Project Sword' range of toys from the 1960s, which were loosely associated with Gerry Anderson. I had the one pictured below, which was based on a design from NASA's Ames Research Centre.
The NASA version is mentioned here ( scroll down to near the bottom of the page ) http://www.projectrho.com/public_html/rocket/realdesigns.php and was also the subject of this Ed Valigursky illustration in Arthur C Clarke's book 'Man and Space'
Anyway, I have now started on a kit to resurrect the design - though at around 57cm long I think it will be larger than the original.
While waiting for various sizes of plastic tube to be delivered, I made a start with the re-entry glider, which is a very simple delta-winged design.
11140008_768690923238703_363148366630944
Moulds now taken from the above parts, and test shot curing. More later :)
Edited by MartG
First set of glider parts from the moulds
11050659_952946628090762_205900748910451
Assembled, and a test fitting of the docking collar which will mount to the nose of the main rocket
11188167_952949271423831_426756489356330
Glider now painted and decals applied
1981747_770556533052142_7877324941331670
Three more parts fresh from the moulds - reactor cooling fin section, drop-tank body and end cap
11163241_770556539718808_429877833506529
Mould for core body section currently curing. Just need to make the conical front & rear transitions and the engine now :)
First fuel tank assembled - just another eleven to cast and glue together....
11204977_954015654650526_569876937403527
Fun while sanding some of the parts - sorry, couldn't resist, especially after seeing Blue Origin's new rocket.....
More new resin bits fresh from the mould - core fuselage section, aft transition section, rocket engine, nose transition section/
10982600_770950583012737_554584812051978
I've made the centre section of the rocket modular to a) keep the size ( and cost ) of the mould down, and b ) it gives the option of building a short version with only one ring of tanks or a longer version with three or more rings of tanks :)
Edited by MartG
How cool is that?
Lotsa resin bits - not bad considering I only started making a sketch of the design last Saturday night !
Edited by MartG
Started painting - not sure whether to go with the toy's grey/blue scheme or something more realistic
