DB's 1/48 Senior Service Phantom -={FINISHED 9/7}=-
:bye: My entry is going to be the old P15 boxing of the 1/48 Hasegawa Phantom FG.1, and i shall try to build it straight out of the box.
Box art and sprues:
The 20+ years old decals' carrier film was a bit yellowed, but surprisingly only a few hours of danish sunlight seems to have cleared them,but the roundels will be replaced, as they are printed in the infamous ivory white :zombie: :
And on to the tires that i tried sand to get rid of the moulding seams and giving them a more flat finish:
^much improvement? :hmmm:
Hmmm...I better get some sleep now. :sleeping:
Edited by The dragonborn
update:
I tried to give the intakes an illusion of depth by fading in the black end wall.
And now it is starting to look like a phantom:
the seams around the intake and aft of the wing needed some filler.
:pilot:
Looks as though Hasegawa got the lower intake tunnel much smoother on the 1/48 version than their 1/72 version. Nonetheless, your image above will be useful inspiration when I come to addressing that area on my 1/72 kit.
Thats because I added some thin styrene sheet to cover the rough area=easy fix :winkgrin:
Here is the intakes with the wing fitted:
Stabs,nose and fin box fitted:
Thanks for the tip. Nice intakes!
And I started painting the bottom with vallejo white surface primer using the trusty hairy stick. :tomato:
:pilot:
Ah, the great battle between the brush painter and white paint has begun! I'll be watching for any hints cos I've not got the hang of it yet... :shrug:
Sean
  • 1 month later...
  • 3 weeks later...
:yahoo: I'm calling this one done:
After the decals was on I gave it an coat of vallejo satin varnish followed by a dark grey wash from the same make. This was the first time I tried a wash, and I thought looked awful after applying it, but as I began to rub off the excess a nicely weathered finish emerged.
I hope y'all enjoyed my build, I certainly did. :coolio:
Vry nice indeed. I like the scruffiness that you have done to the fuselage. We used to mark this area readily with our work shooes and an aircraft fresh out of paint got very messy quite quickly.
