FINISHED The other Tim's 1/48 Hasegawa F4G Wild Weasel - Spangdahlem
Got the wings on after a bit of fettleing at the front end, a few gaps to fill:
44834622-F6CB-4EE1-BE50-506A6BB40ACA_zps
A1983A50-8B4A-4A5C-B6D0-25CD942C928D_zps
2B6B8996-095E-4FBB-B781-A088933FF7FA_zps
2CB98B7A-2123-482C-A007-0562302F290B_zps
E3ECA72A-6D25-4BE6-99D6-E5DF67F25B44_zps
Working on a Lakenheath F100D for my USAFE/Childhood project concurrently!
56ABF720-A52F-47A1-AAF3-3269C37ED367_zps
Some filling done with some model putty.usual suspects, wing join, intakes etc - the power of the cocktail stick!
Having issues with my putty, drying up in its tube.....any advice as to which is the best putty to buy next - advice appreciated!
Hopefully sand the excess with micromesh and crack on with the build....getting there!
36E5B1EB-FC12-4333-BAC2-C85BD37BF2ED_zps
59F5BA8C-CF81-4AFE-8BE8-6C2BB52F10D3_zps
3EE10776-37F3-424E-B01E-A287112FFA72_zps
4C30D924-8EFB-4EA4-9336-D51E03B93EAF_zps
I can recommend Milliput Superfine White. It's a two part epoxy putty. It takes about half an hour to set, maximum strength is reached overnight. It can be shaped with a wet blade when it is setting or cleaned up with a wet cotton bud (good for cleaning up tricky seams like fuselage to wing). It feathers very nicely so no problems blending the putty across a particular area. It's not harder than the plastic. Like all putties, best to give it a coat of primer before base coat.
I haven't done it myself as yet, but I've read that if you want to rescribe a puttied area, it's best to coat the relevant area with CA first. The putty is slightly porous so the CA fills the gaps and hardens up the material for scribing.
I still rate Squadron Green Putty as my weapon of choice, but it does dry up in the tube. Having some good results with Perfect Plastic Putty, but I'm finding it's no good as a gap/step filler as it dries a bit chalky and seems to flake off from larger gaps. Being water soluble, it's absolutely superb for filling small cracks and surface scratches, as well as smoothing off finer gaps in the joins between fuselage and canopies, blade antennae and other added parts.
For larger steps and bigger gaps I've often used Mr. White Putty from GSI/Creos - it goes on a bit gooey and stringy, but dries quickly and doesn't shrink. It sands very smooth once dry and is perfect for the kind of overlaps and steps that older kits seem to produce along the longer seams.
My favourite putty for finishing remains Tamiya Basic Putty, which is perfect for filling sink holes and surface defects. It is also for me the best all-round putty for filling joins between wings and fuselage and so on. It will dissolve in Mr Color Thinners and can be smoothed off without sanding if you use a cotton bud dipped in Mr Color Thinner wiped along the puttied join.
Thanks guys, Cyano, CA...lol...lots to take in!
Do you have any specific brand names glue wise as I am not sure whats what!
I have been using perfect plastic putty, just dries up inside, but as Brokenedge says, easy to use. Going to try the Squadron Green Putty as well.
Your help is appreciated, I can buy the odd item as and when and build up a choice.
Have sanded the filled areas now, ready to crack on with the build!
  • 3 weeks later...
Managed to finish off the main build (less a few Antennas etc, canopy been futured and drying.
I will mask it and attach to the airframe next. After a quick spray of black around the framework I will prime with good old Halfords grey primer.
My Mr Color paint and thinner has arrived, I am going to try to post shade using JimmyDels F4 D Mig Killers technique (never gonna reach that standard!!) ...
My Q is - can I put the laquer based paint over Halfords grey plastic primer? Says the following : The Halfords Plastic Primer Spray Grey provides a strong base coat, helping to reduce runs and distortions in your top coat and providing a smoother finish. The advanced acrylic based formulation of Halfords colour match spray paint is compatible with virtually all types of automotive paint finishes including cellulose.
http://www.halfords.com/motoring-travel/cleaning-body-repair/car-spray-paints/halfords-plastic-primer-grey-spray-300ml
Any advice appreciated!!
8CF5DC7E-E923-41AD-AC60-E033FF546856_zps
E29E1A82-14CB-4096-AAFF-D72364944C4D_zps
08CA225A-CD13-4DBB-9C62-9E3C61CCF7EC_zps
Primed the exhausts, weapons, tanks etc using white primer from Halfords (ran out of grey!!)
F7BAA90D-DF4D-4351-907E-9EA328EE830F_zps
7D792051-806F-4EF7-93BF-7D968CBF7869_zps
Just need to order my HARM missiles!
Progress at least!
Managed to get the canopy masked, on, quickly paint black for the inner frame effect and then primed.
The Mask kit I used seemed to have a few 'short' areas which I added masking too.
F42D89D0-7432-4AF4-B8FC-6A61D5229805_zps
1DBC5512-D9C7-4B8F-8376-EC99D87EE7E8_zps
then added the black to the nose area with the last of my Humbrol rattle can used for Black Mike:
128F7591-E43A-47D5-BD7A-DDC7DCFBD70B_zps
2469F352-58E1-41D8-A46D-3DAB13082BB6_zps
Also the last of my Tamiya silver rattle can for the rear area:
90B4F507-37FA-4C86-B3A8-6CFD12D4E7E6_zps
Need to work on the other metals on the rear end, mask up ready for the Euro 1 cam.
Hmmm...with time getting on I may have to mask up the rear end and try to get the cam on over the weekend when I have more time...then go back to the exhaust area as time is getting short with a week in Moscow and family hols coming up....I think Mr Color is fast drying?
Pre- shaded with the Mr Color paint, utilising my new Iwata HP-C+ for the first time - the idea was to use the advice given by Jimmydel, in a slightly different manner - preshade the darker areas, colour on, lighten a bit and shoot some middle panel parts and then blend with main colour.
Drys so fast!
Light Green FS34102
F8F8A0F1-B53D-4776-968C-79E00DE5AB70_zps
EF0F9B8D-BEAD-4126-9557-C3BE099A38BD_zps
2FB165DE-4955-4AF4-A91A-DDE51CFAE78A_zps
2850AD21-1863-4479-BC21-0F6A1811E4F0_zps
Masked up for the next green FS34079
40D80138-35B6-47CB-A200-1CB49A07C19A_zps
22B8A449-866C-474D-931A-65F964EAE108_zps
98F1C796-CD9F-40B6-B79B-3459B1C9F859_zps
32F9F264-4123-488F-9F9E-EACF914CDD3D_zps
22A38358-D319-4C81-8CA2-B501183F5AEF_zps
ED1E9F00-6E59-419E-BBFD-81745E572258_zps
I love masking - me!!
CE2553F0-2736-4755-B25E-517D89F04EC1_zps
C670FA22-2528-446A-BDAD-BEE165F3BA5D_zps
F5F9A8B5-7A36-4BF1-B06A-B220FA643EB4_zps
Next then the Grey - hopefully the big reveal tomorrow - then on with the rest of the metals, lights etc before some Humbrol clear - will test on the tanks first!!
A lot of good work has gone on with this one Tim, well done.
Quick question, have you painted the jet blast panels yet? If not and I don't know if this will come too late, but I usually paint mine with Humbrol Metalcote Gunmetal No 27004 and then when dry give a good rub. This usually brings up the panels with that oily film look that the panels have.
Thanks Jabba - I know lots about assault rifles and parachutes - my plane parts are not so good! Are you talking about the metal areas to the rear of the exhausts, below the tail?
I have sprayed silver, masked that area in prep for the lower part - I take this is where you mean? I then masked that to get the cam on.
I will try your idea - do you thin it and spray or paint on? Think it says steel below silver on the instructions but will try the gunmetal- thanks!
16D9E7AE-50CA-413B-AF9B-5E956824AF6E_zps
Edited by Tim Moff
Couldn't wait any longer - all dried....think its ok? The clear will tone down the contrast hopefully!
D2246813-6779-4FEC-B822-20D5ABE20B20_zps
3B1C62AC-3631-4E0B-9231-2BA8C85FD70C_zps
C7A7D4D0-8EBF-43F5-82DF-672168F0DC98_zps
B1EC5F5D-B986-42D5-9EAD-202CFC5F8507_zps
0D5681F0-38AC-4F96-AD84-8816732C1836_zps
A0479533-6E92-47A2-8D09-F4F2711E5DA4_zps
b31d8ece618bcaeb458cffbd8ffa9ab0_zpsg36x
Need to do any touch ups, lights, Ae's, exhausts etc tomorrow before Humbrol clear - Decals during the week hopefully!
The best thing the G Modeal Wild Weasel F4's didn't use too many stencils!! :winkgrin::thumbsup:
Edited by Tim Moff
Tim the area where I am talking, is where the instructions say H18. I paint in on straight from the tin, let it dry add another coat let that dry and then buff away with a duster or softish cloth. A strange thing in the instructions where it says to paint H8 (as you have marked sliver) this really should be a more steel type colour. When I worked on Phantoms at RAF St Athan we used to make these panels from titanium, and could be a pain to drill for the screw attachment holes. Hope this is of some help.
That is very good work on the paint scheme, very realistic.
Great help thanks - will grab a pot and brush on!
Now do you Klear/clear over the metal parts when you do the rest of the model prior to decals?
Also with regards the Matt varnish - same Q - varnish metal work or mask and leave?
Thanks for the complement.
I do not Klear over the Gunmetal part, but do over the steel. When it comes to varnishing I do the same, as in nothing over the gunmetal (it should have a slight sheen to it as these panels get a little oily) and matt varnish over the steel.
