FINISHED The other Tim's 1/48 Hasegawa F4G Wild Weasel - Spangdahlem
Well - In keeping with my routine I will build a 1/48 model as well as the 1/72.
Without going 'Full Limey' with the Hase FG1, I decided to kill 2 birds with 1 stone and build the F4G from Spang as part of my childhood USAFE memories project.
Jury is out with regarding the finish....I was going for the Lizard/Euro 1 finish, but the other Tim is doing that (I also like 3 colour cam finishes and masking....)
So I may use the Xtracolor 48005 decals for the later grey model as I am not sure about the Hase decals?
Also think about some aftermarket HARM's or may just build OOB...choices choices!!
E5651C03-CDB4-4CBC-8F2E-DDBD9071E851_zps
b31d8ece618bcaeb458cffbd8ffa9ab0_zpsg36x
spang_boss_bird_by_f16crewchief-d30gej1_
Edited by Tim Moff
My vote is for the Euro-1 scheme. F-4s in Euro-1 just look so brutal.
In my experience Hasegawa decals of that vintage are a little thick but perfectly serviceable. The major issue from that time was that the white sections were always an odd cream colour. I don't think that will be an issue with a Euro-1 scheme. :)
Thanks - I had seen that sheet but all the links went to a defunct URL.
Will have to look at buying them - depending on the content/quantity maybe the other Tim could use them too!
That Xtradecal sheet is only for Hill grey, you can't do a Euro One bird from it?
I didn't know that when I did. Those decals were my first ever aftermarket purchase, and I just wanted Spang codes and a shark's mouth. Looking now, and the white shadowing is absent.
Edited by theplasticsurgeon
Very nice choice Tim.
I have very fond memories of seeing these at many air shows, both in the European One scheme and the grey. Of the two I definitely prefer the Euro One.
Will you be building her with the shark mouth? I do hope so!
Craig.
This decal sheet seems to have what you need.
http://www.fantasyprintshop.co.uk/Hunters-Gathers_A1K66Q.aspx?nh=121825
Edit: erm... except it's in 1/72... :wall:
Edited by Enzo Matrix
Well got my decals - real nice, also bagged the F16 Euro ones too.
As per requests, I will do a Shark mouth from Spang!
The Q is, in my ref pic, it has the underwing tanks, but the pic below suggests just underbelly tank and 1 x HARM on the Port, with ALQ131 rather than the ALQ119, AGM 78 Standard ARM and AGM 45 Shrike in the kit. Would the load on the pic make sense? May be some aftermarket then or a look in my Academy F15E and Hase F16 boxes!!
http://www.eduard.com/store/Eduard/Brassin/Aircraft/1-48/AGM-88-HARM-1-48.html
http://www.ebay.com/itm/Attack-Squadron-Models-1-48-U-S-AGM-88-HARM-MISSILE-/191279745794
39B710D6-F3DD-4027-8CD2-DE3E4D56A066_zps
It wasn't unusual to see Spang F-4Gs without wing tanks.
Spang used AN/ALQ-131s while George (WW) used AN/ALQ-184.
Jens
Cheers - just started Pit and some parts, looking forward to bluetac and 3 colour cam.
Enjoying new job, but don't get as much time off as before, Aunty keeps me busy abroad a bit too.
Edited by Tim Moff
So just got started with the tub, seats and pilots.
Managed some basic painting, bit of dry brushing, need to tidy up, add some colour and weather wash.
Still more to do yet, just an update.
Some work to do, need to cut of the nodules on the upper wings, be a razor saw job I spose.
Taken some advice from a previous builds regards attaching the nose and building up each fuselage side before joining.
http://www.scalespot.com/onthebench/f4g/f4g_build.htm
http://www.helmo.gr/index.php?option=com_deeppockets&task=catContShow&cat=22&id=1146&Itemid=35
Now I will pre shade, however may try to post shade as the colours are dark. The thread indicates that the paint was left to dry, then a slighty lightened version of the colour was sprayed onto the middle of some panels - is this the best way?
272FB68E-9B29-48C1-A47C-34CC54C44E1E_zps
1BECC9BE-1586-44B0-BCBD-2CFFED443C83_zps
A3DDF5BD-AD00-40E0-B7F4-4FF35435D19B_zps
68219AC0-CB27-4AE7-925E-68F093CA8786_zps
Bit more work done, mainly the Pit and getting the raised areas off the upper wing and other bits that need to come off the kit.
Bit sanding, hopefully not too much damage. Scribing not my best skill, tried a bit just to get lines back in!
The pit had a bit of a wash with floreys just to give it a used look:
25375959-77D2-4A34-9257-A530E56149AD_zps
D31228C9-0F8C-4B78-9E10-FAAB2D286FF6_zps
Upper wing work:
CB893777-E753-4864-90C9-34F4B7990C3F_zps
646C15AF-92B1-4D83-B0EC-7CE6E4372D8E_zps
Also completed a test fit of the fuselage pieces, fits like a dream! Just going to build up each side first to make any extra work easy, and also put the landing gear doors into the lower wing.
Nice kit!
Some more work done on the wings, undercarriage doors, and joined the fuselage. Also started on some stores...
1B994306-A2FB-4084-BDD8-A2D1CF01A1BA_zps
C2699628-B955-417B-BD8A-2F5642895889_zps
41060BE6-52AC-4368-A1A7-B9D482DED5B8_zps
51D1B187-2B83-4E4D-9054-C4035AC8DD94_zps
FEE742FC-1413-4CC0-888A-7AD9F58F6204_zps
0FE65272-024B-44F6-943A-0325A779DA61_zps
Have test fitted the wing assembly, bit of filling will be needed, on the wing join and also around the intakes....getting there!
