mosquito four blade props where they the same as the hornet ?
brewerjerry
Hi
Wondered if anyone knows if the four blade props used on some mossies was the same as the ones used on the hornet ?
cheers
jerry
David Collins will be your man, but I suspect not, as the Hornet had handed props as they rotated in opposite directions, while the Mosquito's didn't AFAIK.
Hi
yeah true, but i was wondering if the correct handed props for the mossie was the same
I should have been clearer in my question :)
i think the complete prop assy dia was 12'6" but not sure what the hornet was.
likewise if the spinner was the same on both.
cheers
jerry
  • 3 months later...
Hi David,
Many thanks, no probs with the delay, you must have lots to do
I couldnt find anything myself, as my little research stuff i have on the hornet, doesnt give prop dia, or type info
cheers
jerry
The spinners are different. The mosquito 4 blade spinners appear shorter, with a larger diameter than the hornets.
My references show the hornet had a 12ft diameter prop, that they describe as the DH standard. Does this shorter prop work for you? The blade section and profile look the same between the two types.
Hi
Many thanks for the info
cheers
jerry
