Caution Wake Turbulence Posted April 3, 2015 Share Posted April 3, 2015 Hello, another GB newbie here (and P-38 newbie). Planning to build my Eduard 1/48th 'Pacific Lightnings' kit for this GB: Eduard Pacific Lightnings 1/48 Limited Edition by Caution Wake Turbulence, on Flickr I've chosen to build it in the guise of Capt. Bob DeHaven's P-38L-5, part of the 7th FS, 49th FG based in Tacloban in October 1944. It looks like a nice kit, and it's positively packed with goodies (loads of resin, PE, mask etc). More pictures to follow. Cheers, Andrew 2 Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 3, 2015 Author Share Posted April 3, 2015 What's in the box: Colour Scheme by Caution Wake Turbulence, on Flickr Decal Sheet by Caution Wake Turbulence, on Flickr Sprue A by Caution Wake Turbulence, on Flickr Sprue B by Caution Wake Turbulence, on Flickr Sprues C by Caution Wake Turbulence, on Flickr Sprue D by Caution Wake Turbulence, on Flickr Sprue E by Caution Wake Turbulence, on Flickr Sprue F by Caution Wake Turbulence, on Flickr Sprue ? by Caution Wake Turbulence, on Flickr Sprue G by Caution Wake Turbulence, on Flickr Brassin Parts by Caution Wake Turbulence, on Flickr Brassin Parts by Caution Wake Turbulence, on Flickr Brassin Parts by Caution Wake Turbulence, on Flickr Brassin Wheels by Caution Wake Turbulence, on Flickr PE Fret Part 1 by Caution Wake Turbulence, on Flickr PE Fret Part 2 by Caution Wake Turbulence, on Flickr Plus a canopy mask and some rubber/vinyl tyres I didn't bother photographing. Plenty there to keep me busy. I read of some fit issues with the resin, but I've also read that Eduard tweaked it for this release...time will tell. Cheers, Andrew 3 Link to comment Share on other sites More sharing options...
colin Posted April 3, 2015 Share Posted April 3, 2015 Surely the resin fit can't be any worse than Aries Link to comment Share on other sites More sharing options...
trickyrich Posted April 3, 2015 Share Posted April 3, 2015 welcome aboard, and the first with an Eduard beasty as well, though I expect we will see quite a few of those! I would have used and Eduard model as a base for my build if they turned out an early version, but am very interested in seeing how these build up. Love the extra resin bit!! Nice scheme as well, good luck with the build. Link to comment Share on other sites More sharing options...
HOUSTON Posted April 4, 2015 Share Posted April 4, 2015 WELL I think you have a good one there ... looks great from here Good luck and looking forward to this .. 1 Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 4, 2015 Author Share Posted April 4, 2015 Thanks Rich, I'm looking forward to it! Andrew Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 6, 2015 Author Share Posted April 6, 2015 Hello Folks, I've made a start on the resin cockpit. Having cleaned up the major components, I wanted to check the fit with the plastic. So far the news is good: Untitled by Caution Wake Turbulence, on Flickr I have removed the coaming/glareshield from part D8, as per the instructions, and also thinned the sides and the upper lip to make room for the top of the panel: Untitled by Caution Wake Turbulence, on Flickr Otherwise, I haven't needed to make any adjustments to the plastic yet, however, the fit of the upper and lower fuselage and nose sections does seem a little vague. Cheers, Andrew 1 Link to comment Share on other sites More sharing options...
dazdot Posted April 6, 2015 Share Posted April 6, 2015 Yep Andrew I was thinking the same with mine. It seems an opportunity for a myriad of alignment problems if you get something wrong Link to comment Share on other sites More sharing options...
wellzy Posted April 8, 2015 Share Posted April 8, 2015 good luck Andrew ,always dry fit first Les Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 8, 2015 Author Share Posted April 8, 2015 Had an attack of AMS and ordered some more etch: http://www.eduard.com/store/Eduard/P-38J-upgrade-set-1-48.html I know it's for the J, but I'm hoping it should be mostly applicable to the L too...anyone know any different? Cheers, Andrew Link to comment Share on other sites More sharing options...
dazdot Posted April 9, 2015 Share Posted April 9, 2015 The academy kit is a j or l as I have the j tooling visually thete is little to distinguish them. Fill your boots 1 Link to comment Share on other sites More sharing options...
trickyrich Posted April 9, 2015 Share Posted April 9, 2015 I don't know why but the cockpit area on Eduard models always seems to cause issues of some sort especially with the resin bits or PE instrument panels. Is the plastic in this kit new Eduard mouldings or someone else's? Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 9, 2015 Author Share Posted April 9, 2015 The plastic is Academy. I know Chris Jephcott ended up using the Aires 'pit for his Lightnings over Europe build, but this tweaked version of the Eduard 'pit does seem better so far. Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 10, 2015 Author Share Posted April 10, 2015 The extra etch arrived yesterday and I've made a start on fitting some of it to the main gear bays. This is a combination of the kit etch and the upgrade set: Untitled by Caution Wake Turbulence, on Flickr There are still some more bits to add (door retraction mechanisms etc), but it's already added a lot of detail. Cheers, Andrew 1 Link to comment Share on other sites More sharing options...
trickyrich Posted April 10, 2015 Share Posted April 10, 2015 wow that will look nice when it's painted, definitely worthy it! Link to comment Share on other sites More sharing options...
snapper_city Posted April 10, 2015 Share Posted April 10, 2015 Looking good Andrew. I have test fitted my resin cockpit tub tonight and can see no issues. Those u/c bays look the business. Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 11, 2015 Author Share Posted April 11, 2015 Thanks! I've been struggling a little with the pipes that are supposed to go in the bays - the plastic parts really don't seem to fit very well, so I thought about using some brass rod bent into a perhaps slightly more prototypical shape: P1000212 by Caution Wake Turbulence, on Flickr This is just my first go - I think it still needs a little tweaking. Andrew 1 Link to comment Share on other sites More sharing options...
wellzy Posted April 12, 2015 Share Posted April 12, 2015 Looking good Les Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 12, 2015 Author Share Posted April 12, 2015 Made a little more progress on the cockpit. First, some primer on the main components: P1000214 by Caution Wake Turbulence, on Flickr and second, assembly of the PE seat belts: P1000213 by Caution Wake Turbulence, on Flickr My first attempt at wrangling PE belts and I'm quite happy so far. Going to try and get some paint on the cockpit parts later. Cheers, Andrew Link to comment Share on other sites More sharing options...
trickyrich Posted April 12, 2015 Share Posted April 12, 2015 the detail in the resin cockpit is very crisp, it should look very nice when finished, the seat belts look great. Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 12, 2015 Author Share Posted April 12, 2015 Yup, don't know how much of the detail will survive my attempts at painting though... Link to comment Share on other sites More sharing options...
snapper_city Posted April 12, 2015 Share Posted April 12, 2015 It's looking crisp. I was hoping to primer mine this weekend but Iv been too ill. Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 12, 2015 Author Share Posted April 12, 2015 Hope you feel better soon, Mark. 1 Link to comment Share on other sites More sharing options...
Caution Wake Turbulence Posted April 23, 2015 Author Share Posted April 23, 2015 Hello, been a bit quiet on this build lately, not been near my workbench for a while for various reasons, but I do have some paint on parts of the cockpit and I've been tinkering a little tonight and cleaning up the resin wheels. I'm hoping for a more fulsome update soon. In the meantime does anyone have any tips on cockpit weathering - I'm a bit of a novice in this area! Thanks, Andrew Link to comment Share on other sites More sharing options...
snapper_city Posted April 24, 2015 Share Posted April 24, 2015 I too have been struggling for time. Just been too busy. Check out Bera Karoly's Facebook photos. He has some excellent tutorials. https://m.facebook.com/bera.karoly?v=photos 1 Link to comment Share on other sites More sharing options...
