bootneck Posted March 21, 2015 Share Posted March 21, 2015 Heavy Transport Aircraft An-22 (late version) Eastern Express 1:144 The Antonov An-22 was a specialist heavy transport aircraft that was originally assigned to the Strategic Transport Command of the Russian Air Force during the Soviet era. The An-22, Nato code designation "Cock", was powered by four sets of turbo-prop engines and was classed as the most powerful propeller aircraft the world had ever seen. The nearest equivalent being the massive Tupolev Tu-95/142 Bear. The An-22 first appeared in the mid-1960's; it had a registered load capacity of 80 tonnes within its wide-bodied fuselage and was used to transport heavy loads or troops on operational duties. The aircraft was superceded in the late 1980's by the larger jet engined Antonov An-124. The An-22 continued to operate in the Soviet/Russian Air Force for a number of years, including troop lifts to conflict areas during the break up of the Soviet Union and also providing humanitarian aid around the world. The Kit On opening the box it is obvious that this is going to be a big model once assembled. The fuselage alone consists of at least 12 components and that is not including the tail assembly. The panel lines are finely recessed and look good, however care made need to be taken that these fine lines do not get filled with primer and top coat; especially if brush painting. There are 16 sprues containing the main units and 1 clear sprue holding the canopy and fuselage windows, plus a nose unit. One important element to note is that, although the instruction sheets show part numbers, no corresponding numbers are shown on any of the actual components and therefore strict adherence to the illustrated instructions will be essential. The next point which again needs to be noted is that there are no locator pins or tabs (male and female connection points) on any of these components. This means that alignment of parts, such as the left and right fuselage halves, needs to be achieved by lining up the corresponding panel lines which meet at these junction points. I have had a go at dry fitting some of these pieces and the exercise was very fiddly, mainly as the fuselage is a three-piece assembly (top left, top right and underside) and without location pins I found it difficult to keep things aligned. I would recommend lots of tape be kept handy in order to hold and align two pieces whilst lining up the third and then apply glue. The sprue connectors are nice and small thereby making it convenient for removing the component part with minimal residue to file down. There are however small amounts of flash on the parts, as can be seen on the rear of the fuselage assemblies above and below. As mentioned earlier, the fuselage assembly is made up from a considerable number of pieces; the lower part of the fuselage being a type of double-hull construction. This means that the main fuselage section, the piece with the three windows in the image above, needs to be glued to an inner part of the under-deck piece of the lower fuselage assembly, before the outer piece (the part in the lower left of the above image). I have dry fitted this area to demonstrate what is meant by this and posted the image below. This three-piece assembly could prove a challenge without the locator pin/tabs mentioned. The pieces appear to sit in place OK, once taped, but they may still be prone to movement so a final alignment check before glueing anything would definitely be recommended. This side view also shows how far in from the normal edge that the main fuselage has to be positioned, again without locator pins, before gluing into place. The rectangular piece which juts out from both sides of the fuselage, as seen above, comprises the main wheel bays component; as described in the section on sprue N further down in this review. The nose section of the fuselage, cockpit area and instrument panel parts are supplied on sprue C. I would think this area would need to be built and pre-painted internally before attachment to the rest of the fuselage. Once completed, this model is going to be quite long and may possibly be a tail-sitter. The instructions recommend weight to be added within the forward part of the nose section but does not elaborate on how much weight to use. This could be another area where a bit of time spent dry-fitting and testing with different weights may prove beneficial in the long run. Care may also need to be taken here, as too much weight could cause strain on the area around the front and main fuselage joints. Sprue D contains the lower fuselage assembly I described previously and where the main fuselage would be fitted to. The two long indentations, between the wheel bays, are the areas where the main fuselage would be glued to which is over 2cm (almost 1 inch) inside the outer edge of this piece. As such, this is a very unusual, but necessary, way of assembling a fuselage. The next three sprues; E, F and G, hold the wing and tailplane pieces. The top section of the upper part of the main wing has been produced in three parts; central, outer left and outer right sections. A nice little touch is the placement markings for the engines. Each engine location cut out on the wings is marked L1, R1, L2 etc., to denote the left and right engine pieces. The engines/cowlings are similarly marked to ensure the correct engine is mated to its corresponding location on the wing. We then have the vertical stabaliser/rudder pieces on spue H. Each piece is marked L or R and accordingly should be matched with its counterpart for glueing before to the tailplane elements from Sprue K below. The ramp section, which is situated under the rear fuselage and tail sections, is quite long and consists of three components. One of those, the main ramp, is also part of Spue K above. There are four sets of Sprue L, each consisting of a contra-rotating properller set, plus four of the 16 main wheels/tyres and two front wheels. The model has been designed so that the propellers can be assembled to be free-wheeling and, in order to allow for the contra-rotating element, there is a central plug on which both props plus four separation washers/cleats are to be assembled but not glued. A fifth washer/cleat is then glued onto the end of the plug thereby holding the propellers and cleats in free state. Sprue M has the engine cowling covers and, matching with the wing locators, are marked L1, R1, L2 etc. to ensure correct fitting to each other. The parts which make up the majority of Sprue N above make up the internal main wheel bays. When assembled, the unit has a square box shape and acts as a strengthener for attaching the main fuselage halves to. The final components sprue has all the remaining components for this build; consisting of seats, joysticks and various antennae and fuselage strakes etc. The clear sprue which came with this kit had some slight rubbing marks on the canopy surface. It should not be a problem though as the area concerned is a painted area. The marks are very light and should disappear with a bit of rubbing down, priming and painting. Instruction Sheets The two page instruction sheet is of the illustrative type, with no text as such for additional guidance. Due diligence really does need to be applied here, when identifying which item goes where; mainly because there are no corresponding numbers on the plastic parts themselves. With the exception of the engines and vertical stabaliser parts, that have L or R notations, you are left to make identify everything from these illustrations below. Although I stated that there are no numbers shown on the parts themselves, there is a visual breakdown of what those part numbers should be on the components sheet as shown below. The colour demarcations and marking sheet below should be very useful when painting up your completed model and applying the decals. I would take this sheet and get it enlarged to 1:144 scale so that I could get exact placement to match with the illustrations. DECALS The decal sheet is impressive. It contains over 100 items and the registration appears to be quite clear and crisp. I am, however, concerned that all the decals appear to be on one single backing sheet and will each need to be cut out separately before applying to the model. The kit area is so large though that cutting out each element should not be a major concern as there will be a good sized gap around each part. I particularly like the cockpit window frames which are in silver. This really will be a benefit, rather than having to mask and paint those tiny areas. The same applies for the leading edges of the propellers as there are 32 little silver strips that are applied, one for each propeller blade. Conclusion This is a very large kit with lots and lots of components and, even with the lack of locator pins/tabs; plus the unusual and complex method of assembling the fuselage; I found that when dry fitted the parts looked to fit nicely. The only area that appeared to need attention was some uneveness on the top fuselage join and therefore some filling may be needed in that area. The model is probably not for a beginner, and will probably need a little more effort and concentration to assemble, with regular referrals to the instruction sheet and any other reference aids but it should turn out to be a lovely looking model when finished. Review sample courtesy of 7 Link to comment Share on other sites More sharing options...
Mike Posted March 22, 2015 Share Posted March 22, 2015 Looks like a nice kit Mike - thanks for the review... makes me want one now Link to comment Share on other sites More sharing options...
Flankerman Posted March 22, 2015 Share Posted March 22, 2015 Nice review of what looks like a good kit I've built the beast in 1/72 scale - here. It includes a few reference photos if you need them - and note that I took the lazy option of using Halfords acrylic car sprays to paint it. Halfords White Plastic Primer makes a good base coat - followed by Halfords Appliance White for the top surfaces. Halfords Ford Polar Grey is a good match to the 'VVS rey' used on the real machines. Finally, their 'Aluminium' was used on the wing, tail and fin leading edges. You could always have a go at the sole camouflaged example - that would make a nice change..... Ken 1 Link to comment Share on other sites More sharing options...
Pin Posted March 22, 2015 Share Posted March 22, 2015 What could be done out of it (not mine): Full build log http://pas-decals.ru/forum/19-wip-work-in-progress/6149-an-22-antej-aeroflot-sssr 1 Link to comment Share on other sites More sharing options...
Pin Posted March 22, 2015 Share Posted March 22, 2015 Also be informed that the props as moulded are rotating in wrong direction. May be not an issue unless you are not an accuracy geek Link to comment Share on other sites More sharing options...
Flankerman Posted March 22, 2015 Share Posted March 22, 2015 I took this photo at Gostomel, Kiev - it nicely illustrates just how big the real thing is - note the guy by the nose leg...... Ken 3 Link to comment Share on other sites More sharing options...
Julien Posted March 22, 2015 Share Posted March 22, 2015 All of Ken's pics are available in the Walkaround he kindly sent into us. http://www.britmodeller.com/forums/index.php?/topic/234956667-antonov-an-22-antei-cock/ 1 Link to comment Share on other sites More sharing options...
bootneck Posted March 22, 2015 Author Share Posted March 22, 2015 Also be informed that the props as moulded are rotating in wrong direction. May be not an issue unless you are not an accuracy geek Thank you for that piece of information Pin, it is an important one. Mike Link to comment Share on other sites More sharing options...
Radleigh Posted March 22, 2015 Share Posted March 22, 2015 I need this kit. Looks great.. 1 Link to comment Share on other sites More sharing options...
Julien Posted March 22, 2015 Share Posted March 22, 2015 I want to do the camo one. Wonder how much paint they had to use on the real one? Link to comment Share on other sites More sharing options...
charlie_c67 Posted March 22, 2015 Share Posted March 22, 2015 Out of interest, what are the model dimensions of this beast? Link to comment Share on other sites More sharing options...
Mick4350 Posted March 23, 2015 Share Posted March 23, 2015 (edited) Out of interest, what are the model dimensions of this beast? Wingspan 211ft 4in, 447.3mm Length 189ft 7in, 401.3mm Height 41ft 1.5in, 87mm Edited March 23, 2015 by Mick4350 Link to comment Share on other sites More sharing options...
Viking Posted March 25, 2015 Share Posted March 25, 2015 That'll look great parked next to a Revell An-124 Ruslan. The completed one looks amazing. Link to comment Share on other sites More sharing options...
Flankerman Posted March 25, 2015 Share Posted March 25, 2015 That'll look great parked next to a Revell An-124 Ruslan I've done it in 1/72 scale (my Modelsvit An-124 and Amodel An-22 at SMW 2013) All I need now is the An-225 !! Ken 3 Link to comment Share on other sites More sharing options...
Radleigh Posted March 25, 2015 Share Posted March 25, 2015 Yes, they are big buggers.... dominating the Soviet SIG table and others around Untitled by Totallyrad.co.uk, on Flickr 2 Link to comment Share on other sites More sharing options...
Learstang Posted April 1, 2015 Share Posted April 1, 2015 Ye Gods that Ruslan is a monster! I have that 1/72nd scale Amodel An-22 (done quite a bit of work on it but nowhere near completion) and it is immense, but that An-124 is significantly bigger. I'm waiting for an An-225 Mriya also, in 1/72nd scale of course. Regards, Jason P.S. Ken, did you do those Brawneys (Brawnies?)? Link to comment Share on other sites More sharing options...
Flankerman Posted April 1, 2015 Share Posted April 1, 2015 P.S. Ken, did you do those Brawneys (Brawnies?)? Hi Jason, Yes they are mine - from the Amodel kits - plus the Anigrand resin Il-102 in front of them. Ken Link to comment Share on other sites More sharing options...
