Pin
Azur Farman (SNCAC) NC 223.3 - Finished
My second planned entry to this GB
Very good inbox review and analysis
http://www.internetmodeler.com/2005/august/first-looks/Azur-Farman.php
And yes - I'm planning to address all the issues mentioned in the article above
Meanwhile - does anybody have an idea where to obtain Air Magazine issues 21 and 22? I can obtain any other but these two - it seems like these particular issues are carefully kept in the vaults of Farman lovers.
Edited by Pin
Aah - French art-deco equivalent of a Handley Page Harrow, ugly yet strangely interesting.
Good luck with this Pin.
Welcome!
Nah - "Harrow" is a medium bomber whereas this monster is heavy - larger than Fortress or Lancaster
As large as that - impressive.
This will be interesting
Yes and one of the only 4 engine bombers at the start of WW2.
I might have the Mags will need to check as I have loads, forgot what I have 1/2 the time.
Hello
Here is my Farman 223.4 built some years ago and it is BiGGER than a Lancaster ! This one was the first bombing Berlin on June 6/7th 1940 night.
Patrick
Wow! This is gonna be good!
Ok - let's get started (or rather "get published")
I have found one thing that was not mentioned in Cybermodeller article - compare these two shots:
The turret should be further aft and the fuselage forms a distinctive edge with the wing upper surface that is flat in the kit
This requires some surgery
Kit tank reinforcement strips are sanded down and replaced with foil
Wings are attached, the opening for repositioned turret is made of plasticard
A strip of thin plastic is used to form an edge
That's how it is looking after the surgery. Note that upper fuselage edges are rounded aft of the wing as they were way too sharp
Very nice. Now you should discard the Karman at the trailing edge because there is not. Actually the deeper part of the wing is on the same level as the upper fuselage and the flaps moved close to the vertical part of the fuselage. :winkgrin:
Patrick
That's exceptional work! :thumbsup:
Trailing fairing is removed as suggested
I managed to glue wrong version of stabilizer. It did not fit ( hah! ) so I had to remove a lot of plastic that I need to restore in order to set the correct one
Primed and preshaded
A lot of struts. The instruction sheet does not specify correct detail numbers for them
First coat of underside colour
I attempted to apply freehand method of camouflage painting and very dissatisfied with the way it turned out. Will sand and repaint as usual - with masks
Remasked
Sprayed. Gray is waaay too lite. Azur instruction is obviously wrong here. Too late to repaint now
Lower tail struts - stock ones are too short, used Aeroclub profiles
Engine nacelles in place. Again - the instruction sheet does not specify correct part numbers
Airscrews and wheels
Washing. I used to use artistic oil plaints, this time I tried AK interactive washes. Little less hassle but no much difference.
Ropes
Standing on its own
Nearly there ...
Toucha Toucha Toucha Touch me - I wanna be dirty
Too much postshading - will soften it a bit
99% ready
Next to somewhat more known heavy bombers
As big as (bigger than?) a Lancaster? Good grief. Even without the roundels and tail stripes you'd just know it was French. Fab model.
