shood23
revell 1/24 Ferrari 612 gt1 prototype
So i bought a revell ferrari 612 as part of a bulk buy a couple of months ago and honestly I only got it because of the other cars it came with so from then i was stuck for an idea of what to do with this car as i rate it as one of the ugliest ferraris ever made, so ther i am trawling the Web for an idea for an unrelated project and a 612 race car by some make i have never seen before popped up, the there was my solution to my problem and here is what i have done so far today (also please bear in mind I haven't done any modelling for about 3 weeks as we moved house so not every thing is set up as of yet)
The box of the world's ugliest car
The body with the rear bumper glued on
And here is where i have started with the mods
And also the bonnet is being changed from stock
Also just so i dont forget one of these has been purchased from autosportmodels
I am hoping for this to progess quite quickly but i suspect like some of my recent builds this will stall and i will move on to something else
Shaun
A quick shot at what i have managed in a very short time this morning
More to come later
Shaun
A bit more done for today and really there's not much left to do on the body side
I had to fill in the number plate area and the parking sensors
I also cut out a front brake cooling duct
The diffuser has been started but i will make it more complex i just needed a basic one to see how it looked
And the front splitter has been completed
The interior will be started tonight and i will look into makeing the diffuser more pretty
Shaun
A small update for today
The body has bee primed and painted
More to come later
Shaun
Thanks pizzwizz it's just a rattle can and I must say I was quite pleased with how well it went on as normally I get really bad results with cans
So on with the build
While the paint cures up i have pushed on with the interior
It looks rough at the moment but there is alot more to be added here
I cant for the life of me understand why revell thought it would be a good idea to make the 2 parts for the dash in 2 colours but as with the rest of the car o have modded it slightly by taking off the 2 furthest out air con outlets and the bit where the cd player is will have a race screen put over it
The door inners have been modified aswell, i took all the un needed bits off and filled the recess with putty so it will be a flat surface to work off of
Right now most of above is being primed so i have made a start to the engine and running gear so this should progress really quick now
Shaun
A bit more done over the last couple of days
The engine before the top bit goes on
Now its finished
The gear box
The rear wheel arch, the only reason i show this is because its been sprayed with zeros semi gloss black and i am very pleased with how it works and i will be using it again
I need to grind all the tread off the tyres so i can have slicks
And i have removed all the nasty chrome plating off most off the bits
Shaun
A little more done to this car
The interior is very black but once the shell is on no one will ever see it
So now for a small bit of bad news, the body was sprayed with tamiya red and after a few email i was assured that zeros clear would be fine over it so i went ahead a used my normal method with zeros paint and it ate the decals and the red paint so i needs to be stripped and redone but this time with only zeros paint
Shaun
Right so 5he body has been stripped and has now been painted with zeros paint though out just so there is no issues
Here's the body before the clear coat
Now I just need to clear it and it shouldn't be long before I can get this off my bench
Shaun
Shaun
Hi Shaun,
great work so far!In fact the "Scaglietti"'s a barge and even if I wouldn't call it the ugliest Ferrari ever made (it's getting close anyway!),I think that it's been a real commercial flop;it's rare to see a 12-cylinder Ferrari costing $220k when new turning into such a bargain....specimens in good nick would set you back £35k and ONLY BECAUSE now the Ferrari market's going up ,until a few months ago £28k would have brought home a very nice (condition-wise) 612!
Can't wait to see it finished!
Manu
