AjD Posted January 10, 2016 Author Share Posted January 10, 2016 Just stumbled across this photo of an EMI pod loaded in theatre. Hopefully I'll find time to work the flaps a bit more tonight as progress will probably slow a bit this week. Thanks for the interest everyone. 5 Link to comment Share on other sites More sharing options...
HOUSTON Posted January 10, 2016 Share Posted January 10, 2016 AjD. Having read through the entire thread/build to catch up, I find your work full of precision, and exacting detailing. Good work ..and quite EXEMPLARY workmanship too. Keep it coming. Link to comment Share on other sites More sharing options...
AjD Posted January 11, 2016 Author Share Posted January 11, 2016 HOUSTON, Thank you very much indeed for such a nice comment. I'll do my best but I think time will be lacking in the coming week Link to comment Share on other sites More sharing options...
AjD Posted January 11, 2016 Author Share Posted January 11, 2016 Would anyone happen to know where I can get hold of some thin etched metal sheets? They don't need to be huge, just need some with no PE detail - just the metal. In fact I'm after some really large sheets of plasticard too - much bigger than your standard A4/A3 - nearer A1+ sort of size. It's pretty specialist but would anyone know a supplier? Thanks all. Link to comment Share on other sites More sharing options...
crobinsonh Posted January 16, 2016 Share Posted January 16, 2016 Here you go potentially for brass. http://www.largescaleplanes.com/articles/article.php?aid=2263 1 Link to comment Share on other sites More sharing options...
perdu Posted January 16, 2016 Share Posted January 16, 2016 (edited) That is an excellent article thanks for it.It'll be an ideal intro to the dark arts of metal playI ought to get into there more often Edited January 16, 2016 by perdu 1 Link to comment Share on other sites More sharing options...
fsssh Posted January 16, 2016 Share Posted January 16, 2016 large sheets of plastic: http://stephen-webster.co.uk/products/hips/ call and ask for a cash sale, another company is amari 1 Link to comment Share on other sites More sharing options...
AjD Posted January 16, 2016 Author Share Posted January 16, 2016 crobinsonh and fsssh, That's two seriously useful posts - thank you so much. I've just started making moves to purchase said items so I'm very grateful for the pointers. Appreciate you taking the time. Andy Link to comment Share on other sites More sharing options...
crobinsonh Posted January 24, 2016 Share Posted January 24, 2016 Looking forward to your next update Link to comment Share on other sites More sharing options...
AjD Posted January 25, 2016 Author Share Posted January 25, 2016 I've just noticed the nudge mate! It's nice to know you're interested! I'm recovering from an op at the moment so have begun to dabble a bit in the time off today. Even modelling's harder when you're less mobile! Still, I'll try and post something a bit later as the flap housings are complete now and I've made a more major adjustment to these silly Airfix wing tips to accommodate the outboard flaps. Just trying to find the right seating position for the leading edge slats this morning and once a few cuts have been made closing the wing up in advance of re-scribing the lower surface. The first one's being held together by clamps at the moment. Anyway, enough waffle without pictures. Thanks for the interest and I'll try and post a little bit more soon. Andy 2 Link to comment Share on other sites More sharing options...
RMP2 Posted January 25, 2016 Share Posted January 25, 2016 Yea, come on, stop slacking! Link to comment Share on other sites More sharing options...
AjD Posted January 26, 2016 Author Share Posted January 26, 2016 OK, ok! So there have been quite a few times that I've not managed to get to the cutting mat in recent weeks but lots of little bits of progress when I could. I didn't want to post every 5 minutes as quite a lot of it has been detailed work that would have looked fairly uninteresting posted piecemeal. In fact, I can't guarantee you'll be any more interested now but hey ho...you pay your money, you take your choice! So the flaps had been attached to the runners last time I posted but the real ones clearly aren't just glued on; they have brackets at their inboard end which curve around the flap edge and contain a pin which runs along those channels. So the brackets were made (too long initially, then later trimmed) and holes drilled out for the pin, which was to be brass rod. One half of the bracket was glued to the rod and trimmed. Then a hole with similar diameter to the rod was drilled through the runner at the correct position. Once the assembly was inserted through the hole and attached, the other side was glued on and the rod again trimmed on that side, before excess material was cut away. Having repeated that several times (urgh!) that pretty much finished the flaps themselves off, with the actuators to be added later once final assembly is complete. 4 Link to comment Share on other sites More sharing options...
AjD Posted January 26, 2016 Author Share Posted January 26, 2016 (edited) Next came one of the bigger challenges of this build...working out what to do with these flippin' wing tips. As previously mentioned, Airfix cast the underside outer quarter of the wing as a single piece with the entire upper surface and give you the final three quarters of the lower surface to attach afterwards. Not the world's biggest drama if you're just throwing the kit together - however... In this case I'm installing the dropped flaps and had elected to build the housings in to which they retract to improve the realism. That's easy enough to do inboard but this wing tip design stops you getting in between those surfaces to fiddle around inside. The join occurs about one third of the way along the length of the outer flap. My first thought was that I could perhaps live with it but if I was to build the rails for the outer ones too they would stand well proud of the surface and look ridiculous. So here's the problem, as seen dry fitted... The difference between the gap I'd created and the solid portion of wing is pretty obvious isn't it? Add to that, by increasing the depth of the wing inboard (as it should be) I'm in a position where the taper from root to tip now looks weird because it's pulled down too early to meet the outboard section; creating a sort of kink in the underside. So no options - I decided on more drastic surgery at this point. My idea was to remove more material to allow me to build the outer flap housing as I would like to, then re-skin the outer wing to blend with the inner. I tested the theory with a piece of thin plasticard cut to a rough shape: It's laying on top of the kit tip wing there, meaning that it's higher than the inboard section but it satisfied me of the concept as all suddenly lined up from behind: What became clear though is that I would have to lift the inboard section by a fraction of a millimetre to achieve a good join, but the end result would, I felt, be a lot better. So the way forward was a bit clearer. I had built most of the internal structure for the inboard flaps by this point and you can see the little slots in to which the runners attached to the resin parts will slide. That allows me to keep them off the model until after painting. Andy Edited January 26, 2016 by AjD 4 Link to comment Share on other sites More sharing options...
AjD Posted January 26, 2016 Author Share Posted January 26, 2016 So, first job was to open up the area I wanted to work in more than I had done previously. Then insert thin strips of Evergreen which were sanded down towards the tip, checking that not only did they form the back wall of the bay but remained in contact with the lower wing surface along their length as it tapers towards the tip. The next shim inserted here was the little one pointing forwards. Clearly that wasn't going to be visible but it had three important purposes: 1) to force the wing out a little earlier along the surface between the leading and trailing edge, thus better mimicking the slight curvature of the underside. 2) to increase the surface area on to which the lower surface is glued. 3) to ensure that when the kit part is blended with the new plasticard tip that there is no sag in the kit part when pressure was applied during sanding. I also wanted it to have support when scribing begins. The solid tip wouldn't budge but without support that kit part would be capable of sinking slightly, possibly causing a crack and certainly causing the scriber to snag, possibly ruining the panel line. Anyway, next step was to throw in some detail. Some of this was sanded down a bit as it's not this prominent in reality. A dose of primer so it's in there for when I spray this area later in the build and then I opened up the gaps from which the actuator rods will protrude later in the build. Important to do this before sticking the wing together as these gaps don't go all the way through - existing underneath only. Then I stuck the wing together and prepared the new tip skin. That was intentionally made too big as I would cut it to size when attached. I used liquid poly to glue this area down to achieve a good chemical bond but left it a long time before doing the sanding as that effectively melts the plastic together so you can end up with one hell of a mess if you go too soon. Lots of work required to blend this as best I could. And the primer then revealed the end result. I'm quite happy. One more wing to go for the other jet and then on to scribing...oh joy... Andy 6 Link to comment Share on other sites More sharing options...
Julien Posted January 26, 2016 Share Posted January 26, 2016 So next was the start of the scratch building for the port cannon bay. Andy While I have uploaded all my Jag pics to the walkaround section for anyone to use, attributing the photos would be appreciated; either to myself, or The BM Walkaround section. Julien Link to comment Share on other sites More sharing options...
AjD Posted January 26, 2016 Author Share Posted January 26, 2016 Sorry Julien. An oversight on my part. Link to comment Share on other sites More sharing options...
AjD Posted January 26, 2016 Author Share Posted January 26, 2016 Photo removed. Link to comment Share on other sites More sharing options...
RMP2 Posted January 26, 2016 Share Posted January 26, 2016 I think Im just going to glue the wing things onto the middle bit for mine. Nice going. Unfortunately I think I need one of those rescribing tools too. Yuck. 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted January 26, 2016 Share Posted January 26, 2016 Now that is what you call an update! Stunning work that I will surely copy when I finally build the Airfix Jaguar. 1 Link to comment Share on other sites More sharing options...
Phone Phixer Posted January 27, 2016 Share Posted January 27, 2016 My gast is well and truly flabbered at the work you're putting into this build. Truly incredible. 1 Link to comment Share on other sites More sharing options...
Julien Posted January 27, 2016 Share Posted January 27, 2016 Photo removed.No need to remove it, the photos are up for use, just an attribute to the site is ok. Link to comment Share on other sites More sharing options...
AjD Posted January 27, 2016 Author Share Posted January 27, 2016 Now that is what you call an update! Stunning work that I will surely copy when I finally build the Airfix Jaguar. My gast is well and truly flabbered at the work you're putting into this build. Truly incredible. Thanks guys. I'm a bit nervous about the painting stage having not picked up the airbrush in 3 years but plenty to do before then and it keeps me out of trouble. Had a little test fit yesterday. There's going to be a fair amount of fettling to get all this to line up. Resting the Paragon nose on there too makes it look more like a Jaguar... 5 Link to comment Share on other sites More sharing options...
RMP2 Posted January 27, 2016 Share Posted January 27, 2016 Very nice work again. Looks like the fuselage and wings are a reasonable fit too, restoring my faith a little in the Airfix Jag after the fun with mine. Link to comment Share on other sites More sharing options...
Tiger331 Posted January 27, 2016 Share Posted January 27, 2016 REAL modelling at its very best………outstanding attention to detail and truly admirable work on a pretty reasonable but certainly not state-of-the-art donor kit. I fully support the argument that aftermarket parts have their place in the hobby but there is still plenty of room for those that prefer homegrown improvements and this build article is a true testament to that. Link to comment Share on other sites More sharing options...
AjD Posted January 27, 2016 Author Share Posted January 27, 2016 Thanks Mark. Once again, far too kind. There will be quite a few after market parts to come but at the moment I'm enjoying some of the old school. Of course you know me...I may never finish this Link to comment Share on other sites More sharing options...
