almac Posted August 3, 2016 Share Posted August 3, 2016 Evening everyone. A quick question regarding editing the title of my build thread. Basically I can't work out how to do it. Can anyone help? Link to comment Share on other sites More sharing options...
Arniec Posted August 3, 2016 Share Posted August 3, 2016 (edited) Evening everyone. A quick question regarding editing the title of my build thread. Basically I can't work out how to do it. Can anyone help?if you klick edit, than there is another button for full edit at the bottom. than you can also chamge your title. this is only possible on the starting tread.Cheers, Edited August 3, 2016 by Arniec Link to comment Share on other sites More sharing options...
almac Posted August 3, 2016 Share Posted August 3, 2016 Thanks Arnie, sorted. Cheers Allan Link to comment Share on other sites More sharing options...
Col. Posted August 6, 2016 Share Posted August 6, 2016 You boys are a bad influence. After lurking around here watching your progress and seeing a photo of captured 190Ds in Soviet markings I've bought a Tamiya 72nd scale kit then a decal sheet and Eduard etched set to match. That was last Saturday. The kit arrived yesterday but still no sign of the decals and etch, have to give Hannants a shout about that, so once they land through my letterbox I'll likely be wanting to join in if that's alright. 2 Link to comment Share on other sites More sharing options...
Col. Posted August 6, 2016 Share Posted August 6, 2016 Those decals and etch arrived at last 1 Link to comment Share on other sites More sharing options...
vppelt68 Posted August 18, 2016 Share Posted August 18, 2016 FW 190 gurus please help me. I'd like to build an A-6 using one of those Eduard weekend kits. Is that possible? Which kit should I use? I know next to nothing about Wurgers and actually would be happy with precisely that much of information I need to build one each of an A-6 and a F-8, then that's it for me and back to Bf 109:s 😉. Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 19, 2016 Share Posted August 19, 2016 Not a guru but ready to assist. I have a couple of files from the IPMS Stockholm website that I will send (see the PM) that outline all the differences. Try here: http://www.ipmsstockholm.org/magazine/2004/11/stuff_eng_fw190_01.htm and http://www.ipmsstockholm.org/magazine/2004/12/stuff_eng_fw190_02.htm (Well that worked so don't worry about the email) As far as kits, I assume you are talking in 1/48 scale. If so, there is good news and better news. First the better news, Eduard produces an F8 (84111) in its weekend boxings (in fact that is the only boxing it does the F8 in) and that is marked as readily available. The good news is the weekend boxing of the A5 (8430) will be best for an A6, however, they are marked as discontinued as Eduard are tooling up for the release of the new tool kits. This means they may be hard to find. On a side note, the Fw 190 Nachtjager Profipack boxing (8177) contains parts for an A6 to A8 in the night fighter role, but no weekend boxing. You may be able to find weekend editions in your LHS, or on line. HTH and regards, 1 Link to comment Share on other sites More sharing options...
Arniec Posted August 19, 2016 Share Posted August 19, 2016 Exept there is also a F8 boxing from Tamiya. That is a bit easier to build than the Eduard ones. There was also a kit from Hasegawa and Eduard for the A6 version. Take a look here. https://www.scalemates.com/kits/130718-hasegawa-09965-focke-wulf-fw190a-6-sturmstaffel-1 https://www.scalemates.com/kits/115185-eduard-8171-fw-190a-6 I think that a A5 and a A6 aren't very different. The most noticable will be the outer canons. The A5 used the MG FF's and the A6 the MG 151 20 mm's with a long barrel. At scalemate you can look at the instructions PDF's from both kit's https://www.scalemates.com/search-solr.php?fkSECTION%5B%5D=Kits&q=1%3A48+Fw-190A* I hope this helps. Cheers, Cheers, 1 Link to comment Share on other sites More sharing options...
vppelt68 Posted August 19, 2016 Share Posted August 19, 2016 Thank you, both Kent and Arnold! Unfortunately - wait, no! - luckily I build in 1:72 scale, so I´ll read, learn and apply it in my scale . Regards, V-P 1 Link to comment Share on other sites More sharing options...
Arniec Posted August 20, 2016 Share Posted August 20, 2016 Than there is still a A6 version from Hasegawa and for a F8 the revell one. if I am not mistaken then the revell one is very good. Take a look here. https://www.scalemates.com/search-solr.php?fkSECTION%5B%5D=Kits&q=1%3A72+Fw-190* And don't forget the newish Airfix F8 It looks very impressive. This might help. Cheers, Link to comment Share on other sites More sharing options...
stevehnz Posted August 21, 2016 Share Posted August 21, 2016 I'm intending to build the Hasegawa Fw 190A-5/6/8 kit as Nowotny's A-5. I've been threatening to get onto this for ages now & hope to this week but a conumdrum that keeps presenting itself is, is it really an A-5 or is it a A-6. I've seen kits & profiles that give it as both. If one accepts it is Wrk Nr 410003, then it must be an A-5 but I've also seen it shown as Wrk Nr 470003 which would make it an A-6. I'm leaning towards an A-5 as does most of modeldom but does anyone know if there is definite proof one way or another? It does make a difference to how the Hasegawa kit will be modified. Steve. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 21, 2016 Share Posted August 21, 2016 Not joined in with this yet, may have a crack at the airfix starter one, not much I choice as I don't own an Airbrush nor has my attempts to learn brush mottling proved remotely successful...... Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 22, 2016 Share Posted August 22, 2016 I'm intending to build the Hasegawa Fw 190A-5/6/8 kit as Nowotny's A-5. I've been threatening to get onto this for ages now & hope to this week but a conumdrum that keeps presenting itself is, is it really an A-5 or is it a A-6. I've seen kits & profiles that give it as both. If one accepts it is Wrk Nr 410003, then it must be an A-5 but I've also seen it shown as Wrk Nr 470003 which would make it an A-6. I'm leaning towards an A-5 as does most of modeldom but does anyone know if there is definite proof one way or another? It does make a difference to how the Hasegawa kit will be modified. Steve. Steve, I don't know if this proves conclusively but according to Smith and Creek Fw 190A (Vol 2) at p663 A5 werknummer 410000 to 410208 were built by Ago at Oschersleben. On p 664 the show A6 470001 to 470026 built at Arado, Warnemunde. The difference being these aircraft were assigned call signs VI+OA to VI+OZ. Everything I have seen thus far points to Nowotny's aircraft being an A-5 with werknummer 410004 not 410003. In fact there is an article in Classic Modelling Guide where Brett Green builds Nowotny's A-5: HTH Link to comment Share on other sites More sharing options...
stevehnz Posted August 22, 2016 Share Posted August 22, 2016 (edited) Hi Kent, thanks for that info, the 410003 was just me being lazy & trusting to an unreliable memory. I really did know it was 410004. If Brett Green is sure it was 410004 & an A-5. that'll do me. I've just googled for that book & its not too spendy so I might grab a copy, it'd be good to have. Steve. Edited for noughts. Edited August 22, 2016 by stevehnz 1 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 22, 2016 Share Posted August 22, 2016 Hi Kent, thanks for that info, the 41003 was just me being lazy & trusting to an unreliable memory. I really did know it was 41004. If Brett Green is sure it was 41004 & an A-5. that'll do me. I've just googled for that book & its not too spendy so I might grab a copy, it'd be good to have. Steve. Fear not matey,I have those moments too. Do grab the book, it has some nice builds. *edited because I cannot spell! Regards, Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted October 9, 2016 Share Posted October 9, 2016 Just a quick note to remind everyone that this STGB does not end tonight. Â Because of some technical issues with the forum upgrade it was extended for a week - until October 16. Link to comment Share on other sites More sharing options...
Arniec Posted October 17, 2016 Share Posted October 17, 2016 Thanxs Guys for a great GB. I enjoyed it very much. Â See you guys in the Bf-109 GB?! Â Cheers, 2 Link to comment Share on other sites More sharing options...
trickyrich Posted October 17, 2016 Share Posted October 17, 2016 yes I agree, thank you for another great STGB. Â It wasn't the easiest of builds but that's my fault as usual. Â Anyway there are some really lovely and interesting models in the gallery, everyone should be really proud of their builds. Â .....and the usual suspects roll on into the next GB.........will it ever end!! Â Â Â 1 Link to comment Share on other sites More sharing options...
Kahunaminor Posted October 18, 2016 Share Posted October 18, 2016 To echo the sentiments,  Many thanks for the GB, There was some great skills, intelligent conversation, interesting builds and respect shown to all.  Regards Link to comment Share on other sites More sharing options...
Fifer54 Posted November 9, 2016 Share Posted November 9, 2016 Where is the poll? Hosts, you promised us a poll! I want to vote for my favourite, but there is NO POLL! Â Thank you for running this GB, there are some lovely models, but no poll! Â Can we have a poll, please? 2 Link to comment Share on other sites More sharing options...
Fifer54 Posted November 24, 2016 Share Posted November 24, 2016 Still no poll, over 5 weeks after the GB ended? 2 Link to comment Share on other sites More sharing options...
