Two comments;
Great work so far keep it up.
Be VERY careful using the screws in the axle ends. The plastic strips very easily. Just enough to bottom the wheel and not a twitch more.
Oh and make sure the drive sprocket turns because getting the track on otherwise is a nightmare.
Two comments;
Hi SleeperService. Thank you, I will try to!
And thank you for the sound advice - I've never made a kit where it relies on so many screws to hold plastic parts together. I will try to be really careful. Thank you.
Kind regards,
Stix
My morning's couple of hours on this project were far more relaxing than yesterday's five hours struggling with decals for my double Spitfire build!!
Wheels today - quite a few of them - and a lot of them attached with screws - which was different. I followed SleeperService's advice and attached all the screws carefully - making sure none of them were too tight.
I started the process with the idlers:
Once I'd got into a rhythm the whole process went relatively quickly. Two rows of wheels attached and the drive sprockets:
One thing I would mention at this point is that Skybow's instructions appear to be wrong in a couple of places. They suggest screws should be used a couple of times where they clearly shouldn't be and some of the wheel parts on the instructions are numbered wrong. The images on the instructions do show the correct parts to be used and with careful checking I was able to assemble everything in what seems like the correct order.
Third row:
Outer row:
Hub/screw covers fitted on one side:
And a couple of photos of both sides with everything in place:
Front view showing the drive sprockets:
Last job this morning was fixing the front hatches in place:
And a quick test fit of the upper hull with the lower hull:
So far I am very impressed with the detail and fit of the kit.
Kind regards,
Stix
Edited by PlaStix
This is looking great, and I've never seen road wheels attached with metal screws like this - interesting!
Just one detail I noticed, it looks the teeth on the drive sprockets are completely worn to a metallic colour?
Here's a close up of the Bovington Tiger, might give better idea how they wear, click the pic for larger view:
regards,
Jack
Edited by JackG
regards,
Jack
Thank you Jack. Yes I was a bit surprised by the screws but it seems to work well. And thank you for the picture. I'll take look a to see what I can do to modify the paintwork on the sprockets.
great work
Thank you Mick.
I wish weekends were longer!
Kind regards,
Stix
Edited by PlaStix
Thank you for your kind comment wimbledon. I have to say that, so far, I am thoroughly enjoying this build. I am looking forward to next weekend - but it's only Monday morning and I'm on the bus on the way to work! :-(
Kind regards,
Stix
Edited by PlaStix
Time to start chipping the zimmerit.
Yes I was wondering about that - any suggestions about how to do it without wrecking the whole thing will be gratefully received!
If you have dremmel or something of that ilk, gentle application of a burr bit would work. Failing that a flat chisel blade in your knife.
W
Edited by Wolfpack
Unfortunately I haven't got a Dremmel (or similar) or even a flat chisel blade. Might have to get out and purchase a blade. Can't justify the cost of a Dremmel!
Looking good so far, a Dremmel will be a great investment don't know how I coped without mine!!!
Darren
Darren
Hi Darren. Thank you for your comments. I've just had a quick look on Amazon. I could get a basic one with 15 tools for £38.24 - do you reckon they'd be suitable tools for what I need? Never even thought about getting one before.
Kind regards,
Stix
Ditto re. the Dremel.
I owned a Dremel Stylus for 7 years (used it all the time on my RC models). When the battery needed replacing recently I paid for the work to be carried out but there was an issue with the replacement battery. After 3 attempts at resolving the issue they replaced the Stylus with the new Dremel Micro as the Stylus isn't available any more. That's how good their Customer Service is :)
If you're definately going down the Dremmel route, look for one with variable speed control. Too fast and th plastic melts away before your eyes.
W
Thank you for the information. A Dremel Micro seems to start at over £100 so it's going to be while before I can get one. Sounds like I do need one of these though!
W
Having had the information from wimbledon and yourself it does seem like a Dremel would be a good idea - but I don't have that kind of dosh at the moment. I'll have an experiment on the Tiger at the weekend to see if I can clear some small areas of Zimmeriit. Having looked at some photos of actual damaged areas on the real thing I might have a couple of ideas.
Thank you both again.
Kind regards,
Stix
You could get one of those cheapo drills and run it off a railway transformer. That'll give you infinite speed control.
W
Cheers Wolfpack - I will investigate. I have a railway transformer or two.
Not had a lot of time on this today - in fact a lot less than I anticipated. It's my own fault - I decided to spend more time getting my two Spitfires closer to the finish line.
With the Tiger I thought I ought to start work on the damaged Zimmeriit. I decided to do a test section on the back where it could be out of the way if I made a complete hash of it:
To do this I just used a craft knife and wet'n'dry paper. I have some photos of damaged Zimmeriit to base this on. I thought this looked okay when compared to the photos so I tried a few sections on the front:
At this point I have a couple of questions for the tank experts:
First off - do these look okay or am I wasting my time?
Secondly, if they are okay, what colour should the areas be where the Zimmeriit has been removed? I've only got B&W images of actual Zimmeriit damage and the photos of tank kits with this damage have a wide variety of colours painted on ranging from steel through to reds and yellows.
Thank you in advance for any help offered.
Kind regards,
Stix
Edited by PlaStix
For chipped zimm, you have a variety of choices on what colour to place for the exposed surface - bare metal, primer, or the first layer of zimmerit (grey colour). It all depends on what caused it, that is, what degree of force that knocked it off. The easiest is to put it dark yellow and explain it away that the crew repainted the exposed patch.
regards,
Jack
regards,
Jack
Thank you for the information Jack.
Kind regards,
Stix
Thank you Wolfpack. More next weekend then!!! Can't wait!
