Robert Stuart Posted December 8, 2015 Share Posted December 8, 2015 My first vingette was about this size or slightly smaller - I used Airfix ACW figures. Don't over load the space and it should be approachable. When you first raised the query, I thought you meant 1/35 scale. Something like a PaK 40 75mm anti-tank gun with crew in action would, I feel, be too big for a 6x6 base. A Napoleonic 6 or 8 lb canon might fit comfortably in tha same space. 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 8, 2015 Share Posted December 8, 2015 Looks like a great kit. I'll be interested to see what you do with it. What figures are you thinking of using? Link to comment Share on other sites More sharing options...
-Neu- Posted December 8, 2015 Share Posted December 8, 2015 Mixture of Revell & Preiser, possibly some others.....You know I like my figure butchery! PS - I think the carriage of this gun might be too big for the base, however I do have other options, but most of them are from ACE.....The 'dark place' beckons! Hey, I've got three BMP-2s from ACE, and I was thinking of having some soldiers do a dismount out of one. Some of their newer stuff is actually fairly good for short run. Cmon Sarge... lets see some brilliance out of you. My first vingette was about this size or slightly smaller - I used Airfix ACW figures. Don't over load the space and it should be approachable. When you first raised the query, I thought you meant 1/35 scale. Something like a PaK 40 75mm anti-tank gun with crew in action would, I feel, be too big for a 6x6 base. A Napoleonic 6 or 8 lb canon might fit comfortably in tha same space. I think you can probably do it... certainly if you make it like a 4X8inch it would almost certainly fit (as you proposed earlier). I actually would love to see a Pak40 in action vignette. 2 Link to comment Share on other sites More sharing options...
Joss Posted December 8, 2015 Share Posted December 8, 2015 I would like to put my name down for this I've got a bronco Willy's Jeep and a few alpine figures I would like to do and I this would be a good opportunity! Cheers Joss 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted December 9, 2015 Share Posted December 9, 2015 (edited) Tempting -Neu-, tempting ... Just come across this: An interesting mix of equipment - note the fallschirmjaeger helmets, except for the man on the right. Source: https://www.flickr.com/photos/deckarudo/sets/72157626465559197/(lots of Pak 40's) Edited December 9, 2015 by Robert Stuart 2 Link to comment Share on other sites More sharing options...
vppelt68 Posted December 9, 2015 Share Posted December 9, 2015 Well the Italeri PAK-40 is moulded in full recoil Yes that´s the original PAK 40 kit, today sold with a SdKfz 11 or in a triple gun set. The later, more wargam-ish snap kit that comes with servants isn´t in recoil. Rather good kit for it´s purpose, not a museum piece but keeps 1:72 T-34:s and Shermans off with ease. Damn I haven´t had a game in a to long time and it shows... 1 Link to comment Share on other sites More sharing options...
robw_uk Posted December 9, 2015 Share Posted December 9, 2015 looks like mine will be WWII RAF based (seems my son interpreted "any AIRFIX Tank is fine" to be "RAF Personnel"....) - thinking of a Hurricane (as I have never built one) on a grass base with a few figures - nothing exciting (unless he kept the receipt for he figures or someone wants to swap them after Christmas for a 1/76 tank (WWI Male/Female perhaps)) 1 Link to comment Share on other sites More sharing options...
Black Knight Posted December 9, 2015 Share Posted December 9, 2015 I have contacted a company which uses a roving satellite which has a high energy laser fitted. The satellite will sweep over the vignette and calculate the board area to 5 decimal places. Any board more than 0.24sq mm over the 23,225.76 sq mm area [= 36 sq inches] will be zapped out of existence by the laser. Similarly any bits that overhang the edges of the board will be blasted away by the laser. 2 Link to comment Share on other sites More sharing options...
robw_uk Posted December 9, 2015 Share Posted December 9, 2015 to confirm - if I built a Hurricane for the STGB next year, could I use it as part of the Vignette GB (plan was to build the Hurri for the STGB and then do the base, figures and equipment for this GB - would that be acceptable?) 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 9, 2015 Share Posted December 9, 2015 (edited) Hi all and welcome Joss. Just a quick update. There's obviously quite a few questions appearing about what can (or can't) be included. I have now drafted out some guidelines, based on what's been said in this thread, which I have initially passed to Mish to peruse. I know she's not going to be our glorious host anymore but this GB was originally her idea. Then, once the co-host(s) are confirmed I will run the guidelines past them and then I'll post them in this thread for general agreement. Rob - unless anything changes with the guidelines you will be able to use the Hurricane you build as part of the STGB in your vignette as long as it's not in 1/48 or bigger - pretty sure it won't fit on a 6" x 6" base if it is! Kind regards, Stix Edited December 9, 2015 by PlaStix 2 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2015 Author Share Posted December 9, 2015 I have contacted a company which uses a roving satellite which has a high energy laser fitted. The satellite will sweep over the vignette and calculate the board area to 5 decimal places. Any board more than 0.24sq mm over the 23,225.76 sq mm area [= 36 sq inches] will be zapped out of existence by the laser. Similarly any bits that overhang the edges of the board will be blasted away by the laser. Now why didn't I think of that Hi all and welcome Joss. Just a quick update. There's obviously quite a few questions appearing about what can (or can't) be included. I have now drafted out some guidelines, based on what's been said in this thread, which I have initially passed to Mish to peruse. I know she's not going to be our glorious host anymore but this GB was originally her idea. Then, once the co-host(s) are confirmed I will run the guidelines past them and then I'll post them in this thread for general agreement. Rob - unless anything changes with the guidelines you will be able to use the Hurricane you build as part of the STGB in your vignette as long as it's not in 1/48 or bigger - pretty sure it won't fit on a 6" x 6" base if it is! Kind regards, Stix Ideas run past me an approved, Stix is in charge 1 Link to comment Share on other sites More sharing options...
-Neu- Posted December 10, 2015 Share Posted December 10, 2015 to confirm - if I built a Hurricane for the STGB next year, could I use it as part of the Vignette GB (plan was to build the Hurri for the STGB and then do the base, figures and equipment for this GB - would that be acceptable?) Awesome idea! I've been building a series of them for a very similar diorama depicting the Czechoslovak 310 Squadron, which I intend to continue in the Hurricane STGB... I'm going to build four or five aircraft, which would make it completely ineligible for the vignette GB, but I'd be interested to see how you go about it, and perhaps we can share some ideas. 1 Link to comment Share on other sites More sharing options...
robw_uk Posted December 10, 2015 Share Posted December 10, 2015 Awesome idea! I've been building a series of them for a very similar diorama depicting the Czechoslovak 310 Squadron, which I intend to continue in the Hurricane STGB... I'm going to build four or five aircraft, which would make it completely ineligible for the vignette GB, but I'd be interested to see how you go about it, and perhaps we can share some ideas. trust me, the only idea I will have is "bin it".. .I am trying to find ways to use an unexpected christmas present (RAF Personnel) and this came to mind. I think it will just about fit on 15cmx15cm - was thinking plane, the WAAF, a couple of others figures standing talking, and then the 2 guys with the accumulator trolley on a simple green base (need to raid a friends train modelling stock for "grass") 2 Link to comment Share on other sites More sharing options...
Bonhoff Posted December 10, 2015 Share Posted December 10, 2015 trust me, the only idea I will have is "bin it".. .I am trying to find ways to use an unexpected christmas present (RAF Personnel) and this came to mind. I think it will just about fit on 15cmx15cm - was thinking plane, the WAAF, a couple of others figures standing talking, and then the 2 guys with the accumulator trolley on a simple green base (need to raid a friends train modelling stock for "grass") Something like this? It's progressed a bit further since - A Tilly has appeared and the figures are painted. All Airfix 1/72nd / 76th. 3 Link to comment Share on other sites More sharing options...
robw_uk Posted December 10, 2015 Share Posted December 10, 2015 Something like this? It's progressed a bit further since - A Tilly has appeared and the figures are painted. All Airfix 1/72nd / 76th. exactly like that (just 6"x6" so probably no Tilly).... i know its not original 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 14, 2015 Share Posted December 14, 2015 (edited) Good morning all. I've not had as much time to be on Britmodeller as I'd like over the past couple of weeks so I'm a bit behind with stuff. However, I've got a bit of time at the moment so I thought I'd update everyone with whats's been going on. First off I'd like to thank Neu and Blasvader for volunteering to co-host this GB with me. We've started discussing some definitive guidelines for this GB which we'll post soon - most of them are based on what's been discussed already in this thread - there are no real changes just some clarification of points. At the moment the list of people who have expressed an interest in taking part in this GB is as follows: 1. Mish 2. PlaStix (Host) 3. Silver Fox 4. Saints Phil 5. milktrip 6. Mitch K 7. Vppelt68 8. hgbn 9. Whitestar12chris 10. sean 11. Cookenbacher 12. Bangor Lad 13. badger 14. Rob G 15. moaning dolphin 16. Mottlemaster 17. AndrewE 18. Doug Rogers 19. Snapper_city 20. kwaterous 21. Wolwe82 22. Stew Dapple 23. Wimbledon99 24. fatfingers 25. Shermaniac 26. Radleigh 27. giemme 28. Biggles87 29. MAD STEVE 30. JackG 31. stevej60 32. SDK_K 33. Mark 34. Natter 35. nimrod54 36. Blastvader (Host) 37. Sgt.Squarehead 38. Worm 39. Kallisti 40. rob_uk 41. Bonhoff 42. Neu (Host) 43. Robert Stuart 44. Joss 45. Fatboydim 46. bull-nut 47. paganpete 48. Carius 49. Badder 50. 68 Squadron 51. masterqq 52. dreadeddrew 53. wkennerley 54. TonyTiger66 55. alxzinbox 56. brianthemodeller 57. Philp 58. CliffB 59. Paul Giles 60. LeeCarey74 We actually had 80 people vote for this GB in the ring fenced section of the 2016 GB voting - it would be great if we could get that many people (or more) taking part. If you think you'd like to take part let us know and I'll add you to the list. More soon. Kind regards, Stix Edited May 14, 2016 by PlaStix Link to comment Share on other sites More sharing options...
giemme Posted December 14, 2015 Share Posted December 14, 2015 Hi Stix; inspired by an earlier post of Stevej60 , I acquired this for the GB: I hope this suites the GB rules. Not very original, but I'll try to set up a decent vignette out of it. Ciao 4 Link to comment Share on other sites More sharing options...
Mottlemaster Posted December 14, 2015 Share Posted December 14, 2015 At the risk of showing my hand early ,does this idea work as a vignette. Going to have just the tail of the B17 after it has been choped off by the zeppelin rammer done in 1/72 Alistair 3 Link to comment Share on other sites More sharing options...
Rob G Posted December 14, 2015 Share Posted December 14, 2015 Works for me Alistair, great idea! 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 14, 2015 Share Posted December 14, 2015 Hi Stix; inspired by an earlier post of Stevej60 , I acquired this for the GB: I hope this suites the GB rules. Not very original, but I'll try to set up a decent vignette out of it. Ciao Hi Giemme. That looks great to me! As long as you can fit it on a base with a surface area no bigger than 36 square inches then that's a definite yes! I'm looking forward to seeing you use your amazing figure painting skills on these! At the risk of showing my hand early ,does this idea work as a vignette. Going to have just the tail of the B17 after it has been choped off by the zeppelin rammer done in 1/72 Alistair Hi Alistair. That looks like a fascinating idea - as I mentioned to Giemme above - as long it can fit on a base with a surface area no bigger than 36 square inches then it's in. I'll be interested to see how you do this one. Kind regards, Stix 2 Link to comment Share on other sites More sharing options...
Mottlemaster Posted December 14, 2015 Share Posted December 14, 2015 Thanks Stix i think i can do it in 5 x 5 inches and possible in 4x4 but will have to take a look at a b17 . This will all be an action sequence in the air with possible crew member falling out 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 14, 2015 Share Posted December 14, 2015 Thanks Stix i think i can do it in 5 x 5 inches and possible in 4x4 but will have to take a look at a b17 . This will all be an action sequence in the air with possible crew member falling out You don't have to make it too small......as long as it all within the 36 square inches you can include more sky! I'm fascinated as to how you're going to do this! Don't tell me now! - it'll be fun watching it develop during the GB. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Fatboydim Posted December 17, 2015 Share Posted December 17, 2015 Hello Stix, could I please join the Vignette Group Build. I've never built one, but I've got a copy of Sheperd Paine's, How to build Dioramas which I'm sure will be a great help. Joe 1 Link to comment Share on other sites More sharing options...
PlaStix Posted December 18, 2015 Share Posted December 18, 2015 (edited) Hello Stix, could I please join the Vignette Group Build. I've never built one, but I've got a copy of Sheperd Paine's, How to build Dioramas which I'm sure will be a great help. Joe Hi Joe. You certainly can - I will add you to the list in post #2. I look forward to seeing what you do. Kind regards, Stix Edited December 18, 2015 by PlaStix 1 Link to comment Share on other sites More sharing options...
bull-nut Posted December 27, 2015 Share Posted December 27, 2015 Hi Styx, any chance I could get in on this one please? 1 Link to comment Share on other sites More sharing options...
