1/32 Felixstowe
Gisbod
Ah thank you for the very kind comments! Makes it worth toiling over :D
Top wings on! ;D the fit is amazing - NO glue or Jig was needed for the wings and struts - all clicked together. Just requires a bit of thought re the rigging, this should hold the whole thing together as on the real aircraft. It's an incredible kit..
Guy
  • Like 9
Absolutely brilliant! What rigging material do you use?
Hi Mark, just good ol' monofilament (0.14mm) & Bob's Buckles..
Well done but what happens if the supports under the wing floats are removed?
Regards Toby
Nothing! The wings are very securely fixed in place - although the kit instructions say to leave for 7 days to settle - so they start slightly high then settle in their correct positions over time..
Guy
That transcends mere model making and enters the realm of craftsmanship. It is a singularly superb work of skill and precision.
Thank you once again for the kind comments - I'm calling this done now and the next post will be in the completed builds - if I can work out how to photograph this beast!
The kit is beautiful, and I'd thoroughly recommend it to all - although expensive, I think it's worth it. If you haven't tried a Wingnuts kit before - do yourself a favour and try one! You don't have to start with a Felixstowe! You can pick up a lovely single seater for about £60 and you won't need any aftermarket...
Hoping to take it to Telford this year, so hopefully you can see it in the flesh there..
Guy
