Head in the clouds. Posted January 18, 2015 Share Posted January 18, 2015 Hi all, I know there has been some talk here recently about washes but one thing confuses me still and it is this ; I thought enamal and acrylics should not be mixed as the former is solvent based and the second is water/thinners based and the solvent will attack the more delicate acrylic, yet, I see advice saying enamels thinned with weak white spirit over Future which is acrylic is ok. This is why I will not use washes yet as I am confused. Could anyone shed light on this for me, I know this will probably have been asked many times before so any replys will be gratefully received. Many thanks Gary. Link to comment Share on other sites More sharing options...
Breaker Posted January 18, 2015 Share Posted January 18, 2015 Future is more of a wax as far as I'm aware and seals the previous layers of paint beneath it, forming a barrier. If you're still worried, looking at the Flory Models or Ultimate Washes. They're a water based wash in various colours and can be used on top of any paint without reaction. If you've after just a panel wash, gloss coat first. If you're after staining, you can apply direct to matt coat but test this on a scrap model first. Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted January 18, 2015 Share Posted January 18, 2015 Hi Gary I often use oil-based washes over Klear and Winsor & Newton Galeria varnish without problem. If you have an old, scrap kit knocking around, you could experiment with your intended products before you commit to your intended model. Good luck. Link to comment Share on other sites More sharing options...
Head in the clouds. Posted January 18, 2015 Author Share Posted January 18, 2015 Thanks Breaker, so what is the difference between a panel wash and staining and pin washing, just to add an extra question and do you use the same materials to acheive your results.. The washes you suggested sound good like good choices. Link to comment Share on other sites More sharing options...
Head in the clouds. Posted January 18, 2015 Author Share Posted January 18, 2015 Thanks Alpha Delta, so it is all about experimentation which being inpatiant is not one of my strong points. Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted January 18, 2015 Share Posted January 18, 2015 Thanks Alpha Delta, so it is all about experimentation which being inpatiant is not one of my strong points. Ha ha! I'm the same - the stories I could tell of models ruined by my impatience! Link to comment Share on other sites More sharing options...
Head in the clouds. Posted January 18, 2015 Author Share Posted January 18, 2015 Ha ha! I'm the same - the stories I could tell of models ruined by my impatience! I don't know wether it is because I am anal or something but I dread making a mistake and ruining the model but I suppose that will happen from time to time and I will just have to accept it, pity though when you think of all that hard work that ha gone into it. Link to comment Share on other sites More sharing options...
Foghorn Leghorn Posted January 18, 2015 Share Posted January 18, 2015 I don't know wether it is because I am anal or something but I dread making a mistake and ruining the model but I suppose that will happen from time to time and I will just have to accept it, pity though when you think of all that hard work that ha gone into it. Same here, and it's probably the same for most, it come with the territory. But as the saying goes, you only learn from mistakes I use a pin wash (or panel wash or filter wash, they're all basically the same) on my models. To be strictly accurate the differences are the amount of oil paint used in the mix, a filter is almost clear in colour, a panel (or pin) wash has a stronger colour tint, dependent on your own style and requirements. Anyway, the thinners is the important point, I use MIG thinners as it seems fairly mild. My (old) tin of humbrol thinners is much the same . But DO NOT use distilled thinners, it's strong stuff. I've used Klear, Alclad Aquagloss and Vallejo varnishes on my models and then put an oil wash on top without problems. Invest in some cotton buds, I use them to wipe away the excess wash. I even dip them in thinners and use them on stubborn wash that won't come off. You do have to be a bit careful at that point as too much scrubbing will remove the varnish layer but you have to give it some welly for that to start happening. Neil Link to comment Share on other sites More sharing options...
Stuck Posted January 18, 2015 Share Posted January 18, 2015 Please dont take my word as gospel, but I have found that washes useing normal white spirit will have no effect on klear or acrylic paint finishes and as long as you dont go overboard you can safely use them.. But it will loosen enamel finishes and spirit based varnishes ie humbrol, , have also found that it will loosen Alclad klear kotes. so as long as you seal everything with klear you wont go far wrong Link to comment Share on other sites More sharing options...
Kiwidave4 Posted January 18, 2015 Share Posted January 18, 2015 The use of an acrylic over an enamel before using an oil or enamel wash is to prevent reaction with the base paint. Applying turps thinned wash to an enamel base will dissolve the enamel, ditto an acrylic wash over an acryic base. I use enamels for painting, then usually a coat of acrylic clear and then an oil wash. However I sometimes use an acrylic wash, in which case I dispense with the coat of clear. I fancy some of the paint reaction problems people experience is because they dont allow the paint to cure fully. It takes me weeks to paint a model, thus ensuring that each coat has had a fair chance to cure before the next is applied. Link to comment Share on other sites More sharing options...
