Peter Marshall Posted December 27, 2014 Share Posted December 27, 2014 Tamiya 1/35th Sherman Easy Eight - this is a rebox of the Tasca / Asuka kit with the addition of some figures Work starts with the tracks, these are very nice, consisting of 2 parts per link and are workable once constructed. After assembling 40 links ( of the 77 per side ), took a break and made up the transmission cover, with some Mr Surfacer 500 for weld beads More track link assembly will follow tomorrow :-) Peter Link to comment Share on other sites More sharing options...
Tim B Posted December 27, 2014 Share Posted December 27, 2014 Nice start. Looks like a cool kit. Link to comment Share on other sites More sharing options...
Peter Marshall Posted December 28, 2014 Author Share Posted December 28, 2014 More done today - first finished off the first track, all 77 links so 144 parts :-) Then onwards with the second track - the first 40 links. Once again, taking a break at that point, to give the glue time to cure and retain a little sanity. So got on with some other bits - the drive sprockets and idler wheels And finally started construction of the lower hull Peter Link to comment Share on other sites More sharing options...
Peter Marshall Posted December 29, 2014 Author Share Posted December 29, 2014 Today's work - first finished off the tracks, and sprayed with a light coat of XF84 Dark Iron - works well as a base coat for tracks Then continued with the lower hull - fitted the transmission cover and the sponsoon bottoms Finally added the exhaust deflector and the tow hooks. Managed to lose one of the brackets for the tow hooks but just made a replacement out of plasticard. Peter Link to comment Share on other sites More sharing options...
Tim B Posted December 29, 2014 Share Posted December 29, 2014 Looking good Peter! Link to comment Share on other sites More sharing options...
Peter Marshall Posted December 30, 2014 Author Share Posted December 30, 2014 Today - bogies. No not full of cold, just lots of bogies :-) The tasca bogies are works of art - just loads of parts but ends up with workable suspension Glad that's done but they do look nice. Peter Link to comment Share on other sites More sharing options...
Hamden Posted December 30, 2014 Share Posted December 30, 2014 Really outstanding work. You certainly have lots of patients to build those tracks, well worth the effort though. Looking forward to watching this progress Roger Link to comment Share on other sites More sharing options...
mixup_1 Posted December 31, 2014 Share Posted December 31, 2014 Fantastic work so far. The easy eight was meant to be my first piece of armour, girlfriend bought me an M26 Pershing instead, I'm not complaining lol. This will def be next on list. Look forward to seeing it all come together..good luck Pearse Link to comment Share on other sites More sharing options...
Peter Marshall Posted December 31, 2014 Author Share Posted December 31, 2014 Today's work - started on the Upper Hull Continued but managed to break the bullet trap so replaced with some plastic rod. Similar problem with one of the travel lock brackets so made another out of plasticard Rear hull, replaced the grab handles with wire rather than using the plastic ones Finally added the fenders with all the fiddly little brackets Peter 1 Link to comment Share on other sites More sharing options...
mixup_1 Posted December 31, 2014 Share Posted December 31, 2014 Keep them coming buddy 😊 looking good!! Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 1, 2015 Author Share Posted January 1, 2015 Today's work - first the rear stowage rack Then on with the turret - the join between the lower and upper turret sections needed a little filler and sanding back. This removed some of the cast details. Finished adding the turret details, and added cast detail back with Mr Surfacer 1000 and a stiff brush Made up the 50cal - this is a wonderful piece of molding, better than some resin ones i've seen. Then a coat of Alclad Grey Primer over everything, including the running gear Peter 1 Link to comment Share on other sites More sharing options...
snapper_city Posted January 1, 2015 Share Posted January 1, 2015 Great job so far. Tasca .50 cals are some of the best in plastic. How did the Mr Surfacer casting turn out after primer? Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 1, 2015 Author Share Posted January 1, 2015 Great job so far. Tasca .50 cals are some of the best in plastic. How did the Mr Surfacer casting turn out after primer? The casting texture looks just about perfect under the primer - just like sand cast steel should 1 Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 2, 2015 Author Share Posted January 2, 2015 Today - Pretty drab day First Olive Drab Dark Base Then the Olive Drab Base Finally the Highlights First go at modulation as i'm not normally a fan of the technique, but being a single colour figured it was worth a go, and i'm quite happy so far. Last thing sprayed a coat of Satin Varnish over the top. Peter 1 Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 3, 2015 Author Share Posted January 3, 2015 Today's work - started with a problem. When I was going down to the shed, it started raining so the paint got wet. When it dried it left out of scale rain marks on the paint which didn't want to rub off, so out with the paints again ( heavily thinned ), and a slight touch up job. Then painted the wheels, and fitted the running gear. Then on with a filter - used Prussian Blue to cool the tone of the paint, as its a vehicle from December 44. Now as this needs to dry completely before I can do anything else, so I moved on to starting to paint some stowage. The wooden crates were sprayed Tamiya Nato Brown, then dry brushed with Ammo Old Wood, and finally some oils to dirty up. The other item is a metal box, sprayed with Alclad Steel, then AK Worn Effects, followed by Tamiya JSDF Olive Drab then rubbed back and some oils. Happy with how that worked out. Peter Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 4, 2015 Author Share Posted January 4, 2015 Not a lot today - just the decals, and another coat of satin varnish While that was drying I did start on the Jerry cans ( 2 petrol, 2 water ) but they've just been assembled and primed. Peter 2 Link to comment Share on other sites More sharing options...
Hamden Posted January 4, 2015 Share Posted January 4, 2015 Very nice work - not much more to do now! Roger Link to comment Share on other sites More sharing options...
magman2 Posted January 4, 2015 Share Posted January 4, 2015 Hi Peter, Great work and a great tank. I have the tasca Japan Army version, to make a Fury movie tank with rubber chevron tracks. Link to comment Share on other sites More sharing options...
FZ6 Posted January 5, 2015 Share Posted January 5, 2015 Great work in progress. I got this kit for Christmas and must admit I've enjoyed building it so far. Link to comment Share on other sites More sharing options...
Canuck63 Posted January 5, 2015 Share Posted January 5, 2015 Great work so far!CheersManu 1 Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 10, 2015 Author Share Posted January 10, 2015 Today's work - started with some dot filtering, however had a problem with the AK Interactive White Spirit. It seems to have attacked the paint, despite having been cured for a week and varnished. Then sprayed some more OD to repair the damage A dark wash and painted the tools. Used AK True Metal steel for the tools, which seemed very bright to me - i'll be toning it down later. On with more stowage - this is the basecoat and some dry brushing, still more work needed And Gasoline and Water Jerry cans - the darker olive drab are the water cans Peter 2 Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 11, 2015 Author Share Posted January 11, 2015 Today's work - first chipping Then a flat coat over the top, then started work on the tracks. First added some wear where the running gear will rub on the inside of the tracks. Then weathered the outside - used a mixture of Track Rust and Medium Earth pigments fixed with some white spirit then picked out the ridges on the tracks with Uschi metal powders. Peter 3 Link to comment Share on other sites More sharing options...
Stesca Posted January 11, 2015 Share Posted January 11, 2015 Very, very nice. Link to comment Share on other sites More sharing options...
GruntZone360 Posted January 17, 2015 Share Posted January 17, 2015 Looks great so far one thing though. You need to clean your desk. Link to comment Share on other sites More sharing options...
rom1 Posted January 17, 2015 Share Posted January 17, 2015 Nice work mate!! Link to comment Share on other sites More sharing options...
