Sea Fury SR661 Colours?
Paul Bradley
So a project in the near future will be to recreate Sea Fury 1st prototype SR661. This had the shorter vertical tail, short hook and a four-bladed prop, at least at first, which is how I intend to model her. My question is - what colours was she painted in, specifically the undersides? During WWII, British prototypes were often painted with Yellow undersides, and that is how photos of her look. BUT these photos could also be interpreted as MSG or Sky, and I have seen profiles with both. What is the learned opinion of this forum?
Exactly my thoughts, Troy and Graham - those are two of the photos I've been looking at. These are from the period after she was modified, but I am making the assumption that she wasn't re-painted.
Warpaint has MSG, but these photos seem to show that the colour is much lighter than that. The second photo - in particular, the vertical undercarriage doors - shows that it is the same tonal value as the outside ring of the roundel and the circle P, so I'd assume Yellow as well.
Thanks, guys!
Hi Paul
one image that is related, the only colour photo of a WW2 era prototype I can think of, and it's yellow
De Havilland Sea Hornet F.20 Prototype during deck landing trails on HMS Ocean in April 1945.
from Etienne's photostream https://www.flickr.com/photos/8270787@N07/7381159974/
There was a photo in Aeroplane Monthly a while ago that i am sure was SR661 as a centrespread in full colour. It looked like TSS with yellow undersufaces
I remember seeing that photo in Aeroplane and also thinking it looked like TSS. I will try to have a look for the issue, if I can find it. It would have been from several years ago. The photo was from Aeroplane's archive, so it may be available elsewhere.
  • 5 months later...
  • 1 month later...
cheers bob
dang my memory is going as I have seen that pic before on Etienne Du Plessis flickr
https://www.flickr.com/photos/8270787@N07/8416363320/in/photolist-hyRwB9-dPJ4Aq
And it does look like Temperate Sea Scheme upper surfaces. Looks good in this scheme as well.
Hi,
only just found this thread so a bit late into the discussion I'm afraid.
I have a set of decals for SR661 (can't remember off the top of my head who the manufacturer was) but have a couple of questions that I wonder if anyone can help me with?
First if I wanted to model, in 1/48th, the early version of this airframe how would I model the shorter tail, different bladed prop and shorter arrestor hook? I assume the last is easy, just cut a section out of a long hook, but the other two have got me stumped. At first I thought the tail was from a Tempest but looking at the two it doesn't seem to be? Is the four bladed prop from a late mark Tempest though?
If after the airframe was modified the only difference from an early production Sea Fury was the shorter arrestor hook maybe I am making work for myself that's not necessary? :)
Second is there anywhere I can get information on paint equivalents for the 'Temperate Sea Scheme upper surfaces' and the Prototype yellow under surfaces?
Any help would be much appreciated,
Pete
The shorter tail is very similar in shape to the later Sea Furies and would be easy to reshape. Tony Buttlers book the Sea Fury published by Dalrymple and Verdun has a lot of useful photos. The four bladed prop seems to be the same as that on the Tempest II and so is different from that on Sabre engined Tempests. SR661 did not have folding wings. Temperate Sea Scheme consists of Extra Dark Sea Grey and Dark Slate Grey (which is actually a green grey colour). The underside yellow is the same as the yellow used for training aircraft. Some examples of the model colours available are
Extra Dark Sea Grey Xtracolour X005 Humbrol 123
Dark Slate Grey Xtracolour X025 Humbrol 224
Trainer Yellow Xtracolour X011 Humbrol 24
Other paint matches can be found at http://www.ipmsstockholm.org/colorcharts/colorcharts.asp
Edited by Martin T
Hi,
Pete
Well Pete
Martin has saved me typing, as that's what I was about to reply!
Xtracolor also do the same colors in Acrylic, as Xtracrylix.
Getting a Tempest II spinner might be tricky, as at the moment there are only conversions, though it can't be that hard to convert a 5 blade to 4 blade. The Eduard Tempest comes with two types of prop blade as well.
HTH
Just finished this last week. It's the PM kit, so not the best model you'll ever see! It was a for a GB over at UAMF, and due to other commitments, I had to blitz it....
Lacking definitive info, I used plans to shorten the tail by 5mm, then reshape it. The hook is a shortened version of the kit item. I filled the wingfold lines. The prop and spinner are from the Matchbox Tempest kit, with the blades suitably shortened. Paint is all Xtracrylix - a mix of EDSG and DSG, with Dark Slate Grey, over Yellow. Decals from my spares box. It really needs a panel line wash...
A bit of a rush job; nevertheless, SR661 is a project worth pursuing, as the look is so different from the standard Sea Fury. I might have to acquire another Hobbycraft 1/48 and do the same conversion in that scale, but detail the heck out of it this time.
Anyways, to the pictures:
Hi Martin,
I'm sorry for the late reply, the management at work wanted me to get on with some work rather than reading the Britmodeller forums, surely that's a contravention of my rights as a human?
Thanks for all the information and especially the colour callouts, am going to the Moorlands model show tomorrow with those Xtracolor numbers written on a piece of paper!
The decal sheet I could not remember was War Eagle WE4D021. It's curious as it only gives you the SR661 serials, and nothing else! I have had to source roundels, finflashes and Prototype P's from other sheets.
It (the decal sheet) does give a very nice 1/48 scale side view of SR661, trouble is comparing it to the Hobbycraft fuselage the tail fin is the same height and shape as the kit one. Are there any plans that you know of that show the shape of the smaller tail or am I going to have to reshape it and compare to old photos?
Again thanks for the information, much appreciated.
Pete
Well Pete
HTH
thanks for the reply Troy,
You mention there are conversions I assume from later mark Tempests to the Tempest II? Do you know who makes those and if the scale is 1/48th
Pete
lovely work Paul, the prototypes certainly did look different from the later Navilised versions.
You mentioned a plan that gave you the shape of the tail? Is that something that's available somewhere and could it be scaled up to 1/48th?
Again a lovely model, hope mine works out half as well.
Pete
Pete
Confusingly the Tempest V came first....
anyway, the conversions are 1/48th, (Matchbox did a 1/72nd Tempest II/VI kit back in the mid 70's) were done by Airwaves and MDC. Not sure how available they are at the moment, but they were both a fair chunk of change each.
I'd honestly look at modifying the kit spinner as a first option.
One possible source maybe the 4 blade spinner from the old Airfix Spitfire Vc/Seafire III kit, the spinner is too wide at the base as the kit nose is wrong, which may make it usable for this.
I can check when I can be bothered to have a hunt in the loft....
I don't know if there are accurate plans for the tail, this maybe a case of eyeballing the modifications, Paul said he shortened the tail fin by 5mm, which would be 7.5mm in 1/48th.
HTH
T
Thanks, Pete. I don't recall where the plans came from - I made a photocopy some years ago and I have no idea where they came from...sorry! They may (I stress may) have come from an old Scale Models mag.
BTW, I am planning on tackling this conversion in 1/48 shortly.
Edited by Paul Bradley
HTH
T
thanks for the offer of having a look in the loft for me, assume the Vc/Seafire prop/blades are a close-ish match the one used on the prototype Fury?
Have to study the photos that are available and as you say use some good old fashion guess-imating?
Pete
